Old 04-22-2009, 04:52 PM   #1
Benchmark Tuning
Member#: 154444
2008 08 STi, Typhoon
06 STi, 847-960-8676
Default 02 WRX - Built Motor -GT35R - Pump Gas - 441WHP/375 WTQ
I am posting this up for my customer, the car was intially tuned by Phil at Element tuning, and after a few changes in mods the car needed a little work so we stepped in to get the car where it needed to be, and most of all safe. Before I got a chance to get out there their local guru Dan was able to get the car to solid safe state to drive around.
Originally Posted by Lil Shoaf
Last week Matt from 555 motorsports came to my area for a local tuning event and he talked me into heading out to ECS with him.
We spent all day at the shop which was pretty nice. I was able to squeeze (2) runs in on the dyno. We did no additional tuning just runs. We didn't log boost either to save time.. I'll post a link to the video once I edit it and host it up.. OK.. Now the number..
They use a Mustang MD-AWD-500-Euro chassis dynamometer at an elevation of 243' according to my GPS unit.
I put down 441whp and 375lbtq. I have to wait for ECS Performance to email my graph as they didn't have a printer hooked up to the dyno yet. I'll post it as soon as I get it.. The car hit boost hard and held 375lbtq almost to redline. It had a strong flat TQ curve..
My previous dyno was 425whp and 360lbtq on a DynaJet which most argue is 10-15% higher then a Mustang. I figure the front mount intercooler, Magnus Intake Manifold, Header, and Jethot piping added some decent power.. If calculated the old numbers would be about..
380whp and 330lbtq VS 441whp and 375lbtq.. I'm happy with the added power.. I put down the highest numbers on their dyno to date.. :P
ECS Performance
EWG Dump marked up the Dyno a little bit..
Benchmark Tuning is offline   Reply With Quote
Old 04-22-2009, 04:54 PM   #2
Benchmark Tuning
Member#: 154444
Here is the modlist straight from Ken:
Hydra Stand Alone EMS:
• Wide Band Add-on
• Launch Assist & Anti Lag Harness Add-on
• Tuned By:
o Phil @ Element Tuning
o Dan Mross aka “dmross” on NASIOC
o Matt @ 555motorsports
Forced Induction:
Blitz Power SUS Intake Filter
Custom Machined Aluminum Filter adapter with 4” Runner
Perrin Front Mount Intercooler
Custom Ported Tumbler Generator Valves
Garrett GT35R Twin Ball Bearing Turbo
Ultimate Racing Rotated Up-Pipe (Jet Hot Coated & Heat Wrapped)
TiAL 38mm External Wastegate (18lb spring)
HKS SSQV Blow Off Valve
TurboSmart Eboost2
Exhaust System: (All “HOT” piping Jet Hot Coated & Heat Wrapped)
Garret GT35R 0.82 Exhaust Housing (Jet Hot Coated)
Ultimate Racing 3” Catless Stainless Steel Rotated Downtube
Ultimate Racing External Wastegate Dump Tube
Greddy EVOII Catback Exhaust (not coated or Wrapped)
Megan Header
Motor / Heads:
Raw Performance Signature Series Block
• 2.5Liter STI semi-closed deck block
• Darton Ductile Iron Sleeves
• Forged EJ257 Crankshaft
• Pauter Machine Forged Connecting Rods
• ACL Race Series Main & Rod Bearings
• Coated short skirt CP Pistons
• CP Piston Rings
• Fully Balanced and Blueprinted
Cusco Motor Mounts
Perrin Light Weight Crank Pulley (OEM size)
Raw Performance Signature Series Cylinder Heads
• Custom Hand Ported
• 5 Angle Intake Valve Job
• 3 Angle & radiused Exhaust Valve Job
• SuperTech Stainless Steel Black Nitrided Oversized Valves (1mm Oversized)
• SuperTech Dual Valve Springs
• Titanium Retainers
• Shimless Buckets
• Kelford Camshafts
o 272 Intake with 10.5mm Lift
o 264 Exhaust with 10.5mm Lift (instead of 10.2mm OEM lift)
ARP Head stud kit
Cometic Head Gasket (0.051mm Thickness)
Fuel Delivery:
Walbro Intake Fuel Pump
Aeromotive Fuel Pressure Regulator
Custom Braided Kevlar Fuel Lines with AN fittings
Perrin Fuel Rails
1200cc RC Engineering Fuel Injectors
Transmission:
AndrewTech PPG 5 Speed Dog Box.
• PPG 1-4 Straight Cut Gears
• PPG Interlocker
• PPG Billet Selector Forks
• PPG Front LSD
• PPG Output Shaft
• Upgraded 5th Gear Hub
ACT 4 Puck Clutch Sprung Disk
ACT Heavy Duty Pressure Plate
ACT Street Light Flywheel
Kartboy Front Shifter Bushing
Kartboy Rear Shifter Bushing
Cusco Transmission Mount
Kaaz Rear LSD
Suspension Components:
Perrin Tuner Sport Springs
Perrin Front Sway Bar
Perrin Rear Sway Bar
Perrin Front End Links
Perrin Rear End Links
Perrin Rear Sway Bar Solid Mounts
Perrin PSRS
Cooling:
Polished Koyo Radiator
Perrin Radiator Hose Kit
Wheels:
18” SSR Comp (Competition Silver)
Toyo Proxies TS-1 (225/40Z R18)
Other Stuff:
Yellow Top Optima Battery
Autometer “Phantom” EGT gauge
Autometer “Phantom” Oil Pressure gauge
Autometer “Phantom” Fuel Pressure gauge
Autometer “Phantom” Boost gauge
Autometer Pro Shift Light (Blue)
Viper 760 Security System w/ Remote Start & Window Automation
Special Thanks to:
Dan Mross aka dmross on NASIOC
Ron @ Raw Performance - http://www.raw1performance.com/
Phil @ Element Tuning - http://www.elementtuning.com/main.htm
Andrew @ Andrewtech Automotive - http://www.andrewtechautomotive.com/
Matt Cater @ 555motorsports - http://www.555motorsports.net/
Dan @ Ultimate Racing - http://www.ultimate-racing.com/
Race Dezign - http://www.racedezigninc.com/shop/
PDX Tuning - http://www.pdxtuning.com/
Lou @ Kerven Subaru - http://www.kervensubaru.com/index.htm/
RC Engineering - http://www.rceng.com/
JSC Speed - http://www.jscspeed.com/
Old 04-22-2009, 10:36 PM   #3
rico_q808
Member#: 155896
Chapter/Region: HIIC
2006 WrX
bLuE
Cant wait till you come to hawaii and work your skills on our cars
rico_q808 is offline   Reply With Quote
Old 04-23-2009, 02:13 PM   #4
Benchmark Tuning
Member#: 154444
thanks hugo, look forward to the trip, I actually started a thread in the hawaii section for the trip, here is the link http://forums.nasioc.com/forums/show....php?t=1749464
Old 04-23-2009, 03:57 PM   #5
blakkboxer
Member#: 167244
2k3 WRX MBP
Clean & Simple
whoa this is sweet! subscribed for vid!!
blakkboxer is offline   Reply With Quote
Old 04-23-2009, 09:40 PM   #6
FunkRider
Member#: 195055
I really want to see some video of this thing bangin gears@ 440awhp!!!
FunkRider is offline   Reply With Quote
Old 04-23-2009, 09:51 PM   #7
LateGc8
Member#: 204564
98 gc8
grey
Dude and his cars a sleeper!!!
LateGc8 is offline   Reply With Quote
Old 04-24-2009, 11:21 AM   #8
lil shoaf
Member#: 93776
2002 Impreza WRX
Hey guys. Thanks for the props on my hard work. I'm sorry the Video and Dyno Sheet are taking so long. I'm working on it.. LOL..
Here are some more pictures of the car..
lil shoaf is offline   Reply With Quote
Old 04-24-2009, 11:35 AM   #9
Steve.804
Member#: 68647
07 STI 35R
05 BMW M3 ZCP
Great pics and nice ride. I really like the tiny burn out pic
Steve.804 is offline   Reply With Quote
Old 04-24-2009, 02:42 PM   #10
Benchmark Tuning
Member#: 154444
without further wait
Old 04-24-2009, 02:46 PM   #11
blakkboxer
Member#: 167244
2k3 WRX MBP
Clean & Simple
awd spin. nice.
Old 04-24-2009, 10:21 PM   #12
jmlaser
Member#: 125529
02 WRX 18G EJ205
1/4 mi stock block record
One day my car will grow up and be this angry,.. LOL
Nice work Matt and everyone involved
jmlaser is offline   Reply With Quote
Old 04-25-2009, 08:33 AM   #13
lil shoaf
Member#: 93776
2002 Impreza WRX
Old 04-25-2009, 09:36 AM   #14
TDagen
Member#: 163648
2002 Wrx,5.3L,S476r
FNF LSX Swap,E85 and more
Nice work 370/440 on a mustang is for real heh, also nice work tearing them loose a little I like ....
TDagen is offline   Reply With Quote
Old 04-25-2009, 12:23 PM   #15
zeropsi
Member#: 175453
AE86 GT-S coupe
i <3 alqonquin homosauce
Wow.
Surprised I didn't see this sooner. Very nice! Definitely like the sleepiness of the car too.
zeropsi is offline   Reply With Quote
Old 04-25-2009, 01:02 PM   #16
blakkboxer
Member#: 167244
2k3 WRX MBP
Clean & Simple
i think i just jizzed my pants
that was sick lil shoaf!!
Old 04-25-2009, 01:09 PM   #17
STiAlain
Member#: 134565
2006 STi
Originally Posted by zer0psi View Post
Wow.
lol me too i dont know how i missed it....great job matt and see you soon!
STiAlain is offline   Reply With Quote
Old 04-25-2009, 01:53 PM   #18
bettyblue
Member#: 90920
2005 2.0FPGREEN 6SPD
2002 bugeye Vf39
very sexy very sexy
bettyblue is offline   Reply With Quote
Old 04-25-2009, 05:32 PM   #19
lil shoaf
Member#: 93776
2002 Impreza WRX
Thanks for all the compliments guys..
Old 04-25-2009, 06:07 PM   #20
sopmoney
Member#: 146031
03 tomei ftw!
psm
very good work there man, nice sleeper looking rex!
sopmoney is offline   Reply With Quote
Old 04-25-2009, 09:25 PM   #21
LiquidForce
Member#: 12811
2002 2.5l Wrx
517whp/516wtq (Stage pi)
Nice car. Silver bugeyes rule.
LiquidForce is offline   Reply With Quote
Old 04-26-2009, 01:03 AM   #22
zeropsi
Member#: 175453
AE86 GT-S coupe
You won't be disappointed.
Old 04-26-2009, 02:34 AM   #23
FunkRider
Member#: 195055
Go do a 4 wheel burn out again but take video plz!
Old 04-26-2009, 02:46 AM   #24
WREX88
Member#: 166373
2002 WRX (VF-39)
BMW 330XI
yay for ECS, my home town shop, nice numbers man! thats good stuff on a mustang...not surprised your spinning those tires you need some meat with that torque!
WREX88 is offline   Reply With Quote
Old 04-27-2009, 11:23 PM   #25
Benchmark Tuning
Member#: 154444
great video ken, I still like to comment about getting the car running perfect... "Now I can drive my car to church"
one heck of a church car huh?
2004 Subaru STi - GT35R / PUMP GAS / STOCK MOTOR / AMR TUNED!!! AMR Proven Power Bragging 20 01-16-2012 09:16 PM
2004 WRX STI for sale built motor gt35r turbo tech145 Private Vehicle 'For Sale' Classifieds 18 03-05-2010 04:24 PM
02 WRX Built 2.5 long block, GT35R crippies42 Private Vehicle 'For Sale' Classifieds 29 10-21-2009 06:41 PM
EngineLogics Built Motor + GT35r JustA4 Proven Power Bragging 71 10-30-2007 06:27 PM
Back in the Saddle Again ! Gt35r pump Gas Power Dyno Flash Proven Power Bragging 81 02-05-2007 01:36 PM
