Old 04-18-2002, 04:38 AM   #1
JSiwek
Member#: 14909
Question Which NGK iridium spark plug # for 2.5 liter???
I'm sure it's on here somewhere, but I couldn't find it using the search. Also, the NGK part finder is crazy. It shows different plugs for different year 2.5 L engines and I can't find the iridium ones at all, but I know they make 'em for our application.
Anyway, if you know the part number for the correct NGK Iridium plugs for the 2.5, or thing you know of a better plug, please post! Thanks!
Jeremy Siwek
[email protected]
JSiwek is offline   Reply With Quote
Old 04-18-2002, 09:32 PM   #2
WRSport
Member#: 2060
00 2.5RS Coupe
01 black boxster hardtop
Do you mean Denso Iridiums?
WRSport is offline   Reply With Quote
Old 04-18-2002, 10:38 PM   #3
GLwagon
Member#: 16696
2002 WRX Sedan Stg2
2013 OBW roll'n at 30+mpg
Angry
I don't know BUT I do know I was quoted $19 EACH for the NGK PFR5-11 "lazer platinum" at my local NAPA...MY2K 2.5l wagon
The heat range should be simmilar "5" or "6"
they have 2 #ing systems NGK says
"B" 14mm thread
"K" 5/8" hex socket w/projected tip
"R" Restior
"5" "6" heat range 6 is safer
"E" 19mm thread reach
"?" UNKNOWN
"11" 0.44 gap
Contact them for the missing #'s
http://www.ngksparkplugs.com/contact/
even cheap Autolite Platniums are better than the JUNK factory "champions" BLAH
GLwagon is offline   Reply With Quote
Old 04-19-2002, 01:42 AM   #4
ImprezaRS dot com
over boosted again
Member#: 1458
2015 Forester 2.0 XT
2005 2.5 RS, 2013 Tribeca
BKR6Eix11
ImprezaRS dot com is offline   Reply With Quote
Old 04-19-2002, 11:00 AM   #5
NNeves
Member#: 4973
2000 2.5 RS
ohhh...pretty spark plugs, i want plat spark plugs.
NNeves is offline   Reply With Quote
Old 04-19-2002, 11:28 AM   #6
Peaty
Techno Sapien
Member#: 449
2010 Legacy 3.6R Lim
Azurite Blue Pearl
Copper conducts better than plat, plat if for people that don't care about performance but longevity and are too lazy to change the plugs more often. Plats are also for people w/ a lot of money I change my plugs every spring, they only cost 1.50 each.
From that NGK link:
Frequently Asked Questions
Q: How much of a performance improvement can I expect from changing plugs?
A: A common misconception is that changing spark plugs will result in a large power increase. In most cases, removing even seriously worn out spark plugs will only result in very modest power gains, typically about 1-2% of total engine output. This could be even less for computer-controlled vehicles, primarily because most newer vehicles have more powerful ignition systems and the vehicle's computer can make adjustments so that vehicle operation seems smoother and more seamless.
Many people think that simply supplying more spark to the firing tip can and will combust more fuel. What they don't understand is that most newer cars' engines are so efficient that they are already burning all of the available fuel. Simply adding more spark voltage can't burn more fuel because there is no more fuel to burn.
When a stock or near-stock engine is given a fresh set of spark plugs, peak efficiency is restored. The power gains that come from this restored state of tune are usually minimal. Any company that tells you that their spark plug will provide significant gains in power in a stock or near-stock engine is making blanket statements that may not be supportable.
Peaty is offline   Reply With Quote
Help with NGK Iridium Spark plugs one step colder # 6 for my 04 STi? heizzy Newbies & FAQs 9 02-26-2009 11:42 AM
FS/MN: NGK Iridium Spark Plugs (LFR7AIX) 2.5 STi/WRX - One Step Colder WRXEcho Engine/Power/Exhaust 4 09-01-2008 02:42 AM
[B]NGK IRIDIUM Spark Plugs for 2.5 STi - $19 SHIPPED!!![/B] Mr. Quick Engine/Power/Exhaust 1 11-28-2007 04:51 PM
Colder NGK Iridium Spark Plugs available yet for STI? Ricowrx Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 09-04-2004 11:25 AM
NGK Iridium spark plug gap for WRX? Ken Levin Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 10-27-2002 07:48 PM
