Old 04-23-2009, 03:11 AM   #1
akstud1983
Member#: 162000
2004 Impreza RS2.5
Dirty and Smashed!!!
Default STI strut install!!!
I just wanted to let all you RS'ers know. that i installed a set of 05 sti struts and springs and OMG!!! my car is faster(put the power down tot he wheel better) corners like mad!!! and stops shorter!!!
I lucked out and got a set of struts and springs for $100. don';t ask me how. but they have been by far the best investment!!!
akstud1983 is offline   Reply With Quote
Old 04-23-2009, 11:14 AM   #2
drdolil99
Member#: 154939
2007 Impreza 2.5
Were they direct bolt on or did you have to modify anything?
drdolil99 is offline   Reply With Quote
Old 04-23-2009, 02:39 PM   #3
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
congrats. and +1 on the question for modifying anything.
Old 04-23-2009, 02:43 PM   #4
Subydude81
Member#: 118266
2007 Lexus IS250 RWD
6MT
BS. Not possible the 05 sti struts will work with an 04' RS.
Subydude81 is offline   Reply With Quote
Old 04-23-2009, 03:23 PM   #5
Jerry Xu
Member#: 36629
07 2.5i
Regularly Being Modified
^^OP, Please answer that question for us. Haha.
Jerry Xu is offline   Reply With Quote
Old 04-23-2009, 03:46 PM   #6
fastenova
Member#: 38829
Not your usual 1997
Legacy GT
OMG!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!
No, your car is not faster. You have no less drivetrain loss than you did before, you just don't feel the rear end squat like it used to because of the stiffer suspension. I'm sure your car is quicker in the turns, but it's not any faster.
What was the point of this post? Is this a special application? Are you bragging? I don't get it.
Why, or why not? Strut top differences? Knuckle mounting differences? If you are going to say "BS" you should at least explain why. I have no more reason to believe your response than I do the OP. Not saying you're wrong, but you should back up a statement like that.
fastenova is offline   Reply With Quote
Old 04-23-2009, 03:54 PM   #7
Back Road Runner
Member#: 60082
2004 Forester STI
05 STI = not possible
04 STI = will directly bolt on.
Simply has to do with the wheel hub design between the 5x100 bolt pattern one and the 5x114 bolt pattern one. They are of different thicknesses and bolt spacing.
Congrats on the swap. It should be a considerable bump up from the stock RS setup, but in spring rate and dampening. Everything should feel a good bit firmer and more responsive, less roll, etc. It's a nice sport setup, most anything around the STI rate is be it direct take-offs or any aftermarket combination.
If you haven't upgraded the rear sway bar, grab an OEM 20mm WRX one from SubaruGenuineParts or similar, $85 new. That'll help neutral out the handling and knock out even a bit more of the roll. The car should feel pretty spiffy after that. I'm not really sure what comes stock on the 04 Impreza. If I were to guess a tiny twig of a 13mm bar that's better used as a placeholder then a real suspension device.
Old 04-23-2009, 04:20 PM   #8
akstud1983
Member#: 162000
2004 Impreza RS2.5
ok, let me clarify, I was told they were off and 05 STI, they mounted perfectly(which must mean they are 04's)
and if the rear and is squating less qouldn't that mean i am putting more power to the ground. BTW more horsepower is not the only way to make your caraster. it's also has to do with the ability to put it to the ground(DER!!!)i.e. clutch, lightweight wheels, mounts and bushings,and so on.
All I know is that they are the **** compared to RS stockers.
I do have a 20mm WRX Sway bar which also helps alot in the turns.
Old 04-23-2009, 04:27 PM   #9
fastenova
Member#: 38829
Not your usual 1997
Legacy GT
and if the rear and is squating less qouldn't that mean i am putting more power to the wheels. BTW more horsepower is not the only way to make your cra faster. it's also has to do with the ability to put it to the ground(DER!!!)
Were you breaking traction before you installed this suspension? If not, the same amount of torque is being applied to the ground through your tires, driveaxles, rear diff, driveshaft, center diff, and transmission. I suppose that one could argue that it takes SOME amount of energy to make the rear end squat, but I'd argue that the car is still trying to do that, but the new springs are just resisting that force. I don't think it's converting the inertia into increased drivetrain power. I'm sure the car feels much more responsive as the suspension reacts faster, meaning you feel the effects of acceleration sooner.
If you were, then if you increase traction through means of suspension modification then yes, you would end up putting "more power to the ground".
I absolutely know that increasing power is not the only way to go faster (think: sportbike with 150HP and GVW of 450 lbs).
Old 04-23-2009, 04:34 PM   #10
akstud1983
Member#: 162000
2004 Impreza RS2.5
LOL, yes i was able to break traction(with my Blizzacks) lol, I don't know if i can with my pilot sports.
All i know is that the car IS faster. not that i am making more hourse power. i'm just using it more effectively.
Old 04-23-2009, 08:57 PM   #11
chazly413
Member#: 151079
2005 2.5RS RBP
too many friction losses
Ahh, the good old butt dyno and how it can fool our minds. It's because you're squatting/diving less which makes braking and acceleration seem faster because you reach full squat/dive sooner.
chazly413 is offline   Reply With Quote
Old 04-24-2009, 01:48 AM   #12
semaj
I'm sorry for apologizing
Moderatour
Member#: 113533
2006 Pathfinder
Off Road
Easy way to tell is '04 STi struts = pink/red, '05-'07 STi struts = black. The springs are black on both.
The '05-'07 STi struts will bolt onto an '04 RS up front, but not in the rear. '04 STi struts are a complete bolt on.
semaj is offline   Reply With Quote
Old 04-24-2009, 02:42 AM   #13
akstud1983
Member#: 162000
2004 Impreza RS2.5
ok, mine are pink. thanks for clearing that up!
no is it takes longer to reach the bottom of the squat doesn't that mean your wasting more HP??? if you shorten the amount of squat then you wil achieve forward movement faster...right???
Old 04-24-2009, 05:06 AM   #14
jamal
Member#: 71875
98 Legacy GT
my wheels fit
other way around. front struts don't fit.
1. why is this in n/a powertrain
2. this is very well documented in the suspension section.
jamal is offline   Reply With Quote
Old 04-24-2009, 10:58 AM   #15
bnr34rb26dett
Member#: 188424
2012 640WHP STI
did sti springs on rs lower it at all?
bnr34rb26dett is offline   Reply With Quote
Old 04-24-2009, 11:48 AM   #16
Boxer4Dad
Member#: 137226
2005 Saabaru 2.5i
OBP, or Black
imagine that...
Boxer4Dad is offline   Reply With Quote
Old 04-24-2009, 11:59 AM   #17
scoby41
Member#: 134737
2000 CC PSD on 38s
Does it matter what year? I know some guys with wrx's who've upgraded and could get a cheap one
scoby41 is offline   Reply With Quote
Old 04-24-2009, 02:14 PM   #18
formula91
Member#: 102984
2005 2.5RS 4EAT
Platinum Silver
http://forums.nasioc.com/forums/show....php?t=1746644
I don't know why this thread didn't turn into epic fail like the other one.
formula91 is offline   Reply With Quote
Old 04-24-2009, 02:16 PM   #19
chazly413
Member#: 151079
2005 2.5RS RBP
It'll lower it to stock STI ride height.
Old 04-24-2009, 02:58 PM   #20
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
yes it does - only the 02 and some (early) 03 WRX sedans got the 20mm rear bar
but I agree this really does not belong in the NA Powertrain forum
UkNuck is offline   Reply With Quote
Old 04-25-2009, 12:36 AM   #21
semaj
Moderatour
Member#: 113533
2006 Pathfinder
Off Road
Oh, good thing I didn't try it then
Old 04-25-2009, 03:43 AM   #22
akstud1983
Member#: 162000
2004 Impreza RS2.5
sorry for posting in the wrong forum.
BTW, my struts own your mom. so, ha!
mods close please!
Old 04-25-2009, 12:24 PM   #23
EdHilario
Member#: 137398
2004 Impreza 2.5RS
mods close please!
lol epic fail
EdHilario is offline   Reply With Quote
04 sti struts.... wilownu Newbies & FAQs 11 06-05-2010 12:24 AM
v.8 sti strut install... ckb1985 Brakes, Steering & Suspension 4 09-18-2008 10:36 PM
Has anyone installed STi Strut tops on a '02 RS 2.5? ThinkTank Brakes, Steering & Suspension 5 07-15-2002 03:46 PM
DMS 40 and STI strut mounts installed Shoelace Brakes, Steering & Suspension 1 06-20-2002 10:48 AM
DMS 40 - STI strut mount install Shoelace Brakes, Steering & Suspension 4 06-12-2002 07:53 PM
