Old 04-23-2009, 01:46 PM   #1
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
Question Aluminum rad on a forester
Well I am fixing mom's forester again. She has already replaced the radiator once. So I was thinking there has to be a aluminum replacement for this. Yet there is not direct replacement I can find. Can a n/a impreza one fit? Is there any potential problems to watch for?
hybrid gti 2 is online now   Reply With Quote
Old 04-23-2009, 01:50 PM   #2
rougeben83
Member#: 115154
2003 Legacy L Turbo
where are your rad hoses? Is your top rad hose in the middle of the radiator or on the passenger side? Is your bottom hose on the driver's side?
rougeben83 is offline   Reply With Quote
Old 04-23-2009, 01:54 PM   #3
00LGTP
Member#: 172618
2000 RS
BRP
depends on what the hoses look like.
what year forester? if the hose is in the middle on both the OEM rad and the aluminium one, then i wouldnt see what it would not FIT. the bottom mounts will line up, but im not 100% sure on the top mounts.
dont forget about the PSI/bar of the rad cap, i wouldnt get anything over what OEM pressure is.
hell i put a lower PSI rating cap on my car (its rated for a 1.1 bar, i put a .9 bar cap on) and its fine.
i put a 04 WRX rad in my 95 RS, i had custom mounts made for the top, and i needed to get a different hose. NAPA part # 9128
00LGTP is offline   Reply With Quote
Old 04-23-2009, 01:55 PM   #4
00LGTP
Member#: 172618
2000 RS
BRP
IIRC all EJ motor rads have the bottom hose on the drivers side
Old 04-23-2009, 02:00 PM   #5
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
01 forester
Old 04-23-2009, 02:11 PM   #6
00LGTP
Member#: 172618
2000 RS
BRP
Originally Posted by hybrid gti 2 View Post
01 forester
i dont know what it looks like off hand, but does it look like this?
if it does i would say that you can use a RS radiator (with the hose on the passenger side.
(if it was my car, i would try to get the alum rad, i would take the chance, but then again i am cheap so i would shop around for a used one that i know for a fact will work and will be a true plug and play)
Old 04-23-2009, 03:17 PM   #7
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
^ yes that looks like it
Old 04-23-2009, 03:59 PM   #8
rougeben83
Member#: 115154
2003 Legacy L Turbo
alum rad for a GC impreza will fit then.
ALUMINUM RAD f/s Derek King Engine/Power/Exhaust 2 08-22-2007 05:22 PM
Leaking rad on new car ralliharri Factory 2.0L Turbo Powertrain 3 09-12-2005 05:26 PM
Aluminum control arms for Forester XT? wadejg Brakes, Steering & Suspension 2 09-12-2004 08:46 PM
2002 WRX Aluminum Flywheels on sale. B-SpecUSA Southern California Impreza Club Forum -- SCIC 0 02-28-2001 07:05 PM
WRX Aluminum Flywheels on sale. B-SpecUSA Bay Area Impreza Club Forum -- BAIC 0 02-28-2001 06:42 PM
Message Board Statistics All times are GMT -4. The time now is 12:23 PM.
