Old 04-23-2009, 01:46 PM   #1
own3db
Member#: 120667
02 20g'd ewg wrx
platinum silver metallic
Default 2.0 to 2.5 swap questions
hi i tried searching but couldn't find what i need to know. I am about to swap a 06 complete 2.5 into my 02 wrx i was wondering if the wiring harness from my 02 would work and also if the ecu would work to any help would be greatly appreciated
own3db is offline   Reply With Quote
Old 04-25-2009, 02:35 PM   #2
BoostInc
Member#: 176520
1994 Legacy SS
black and mud
if its the whole longblock then no, you can just swap shortblocks.
BoostInc is offline   Reply With Quote
Old 04-25-2009, 05:29 PM   #3
own3db
Member#: 120667
02 20g'd ewg wrx
ok well i found out that its takes way to much work to make the whole long block work so im going to do a hybrid build whould i put cams or something becuase i heard that the stock 2 liter head fall off bad at high rpms
Old 04-25-2009, 06:00 PM   #4
jet8300
Member#: 115844
02 WRX
99 Forester
Look around in the "Built Motor" section, rather than his one. There's TONS of 2.5l Hybrid info in there.
jet8300 is offline   Reply With Quote
Old 04-25-2009, 08:47 PM   #5
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
You can run the long block. You just won't be able to control AVCS. Run your intake manifold. Take off and cap the air pump system. Retune.
FuJi K is offline   Reply With Quote
Old 04-27-2009, 05:24 PM   #6
own3db
Member#: 120667
02 20g'd ewg wrx
so it is possible to run the whole long block some one told me that it cannot be done with out tons of wiring issues and other stuff is there a write up or something i can look at for disabling the avcs or would i just be better off doind a hybrid build
Old 04-28-2009, 02:12 AM   #7
SegaWrx
Member#: 203618
Check the built motor section like renegade said.
SegaWrx is offline   Reply With Quote
Old 04-28-2009, 08:54 PM   #8
own3db
Member#: 120667
02 20g'd ewg wrx
i spent a good 45 min in the built motor section and my question pertains more to a subaru conversion then a built motor
Old 04-29-2009, 05:34 AM   #9
xrturbo
Member#: 86298
98 LGT Wagon
Full WRX driveline & dash
If you do a hybrid build, be sure to research pcv/breather system setup due to the dual breather 25 vs single 20 and also cometic is making a big bore 20 gasket to work with the hybrid.
xrturbo is offline   Reply With Quote
Old 04-29-2009, 06:33 PM   #10
wrx03.4wz
Member#: 122375
03.7 I own 2 of them
White & Black
I own a hybrid engine,for 1 the only reason you can't run a STi long block is becuase it is drive-by-wire!!! thats is it, you can bypass the AVCS but the car will run like crap, 2nd head p/p SERIOUS P/P THE 2.0 HEADS HAVE TO BE JUST RIGHT FOR THIS TYPE BUILD!!! hits bottom end has crazy torque misses falls flat on high end thus p/p heads.
wrx03.4wz is offline   Reply With Quote
Old 05-01-2009, 03:04 AM   #11
gordini69
Member#: 119591
2.5l sti heads use hall effect cam sensors. wrx has one reluctor style cam sensor on front of left head. if using original ecu, front cam sensor is needed. cosworth makes a bracket to adapt a front cam sensor to 2.5l heads. however avcs will still not work.
gordini69 is offline   Reply With Quote
Old 05-01-2009, 09:37 AM   #12
rocketsled
Member#: 35223
2002 WRX Wagon
WR Blue
I recently purchased an 06 baja turba 2.5l motor to swap into my 02 wrx wagon with similar mods to you. Under the impression I can use whole long block and just swap out the intake so the throttle body will work and possibly the cam sensor. AVCS will not work without changing ecu's but heard it just loses a little power (still have more than 2.0 though) in the lower revs... shouldn't idle/run badly. Curious to hear more info on this particular swap as well so please keep in coming guys.
rocketsled is online now   Reply With Quote
Old 05-04-2009, 11:09 PM   #13
robwrx19720
Scooby Scammer- Do Not Buy From User
Member#: 180582
I'm doing a sti longblock swap into my 02 wrx in it "WILL WORK" in run fine with a wrx ecu and wiring harness but the AVCS will not work in there is not much of a power lost without the AVCS. all you have to do is use your 02 intake manifold cause its drive by wire. My sti longblock is getting built by agile auto as i speak in it will work with no problem.
robwrx19720 is offline   Reply With Quote
Old 05-31-2009, 06:07 PM   #14
turbored02
Member#: 119471
2002 Impreza
Sedona Red Pearl
I am in the same spot as the OP. I have a full 05 STi swap from engine to the rear sub-frame. But I didn't swap out to the STi harnesess. My only problems besides a tune is, it idles at 2k. And of course I don't have AVCS. I am waiting for my cam sensor bracket to come in. Does anyone know if I can use the 2.0 cam sensor ? Or do I have to run a 2.5 cam sensor ? Also if I have to swap them out. Are they the same connector ?
turbored02 is offline   Reply With Quote
Old 06-02-2009, 01:06 PM   #15
rocketsled
Member#: 35223
2002 WRX Wagon
WR Blue
You will need to reuse old 2 wire cam sensor from WRX. STI is 3 wire and won't work. You apparently already know about the cosworth bracket which you'll need if your head doesn't already have the casting. Some of the older models do and you just have to drill out the hole. Good luck!
Old 06-06-2009, 12:38 AM   #16
turbored02
Member#: 119471
2002 Impreza
Sedona Red Pearl
Well I am getting frustrated with my car. Since the 2.5 LB went in. I have been having nothing but problems. 1 major problem is I have an oil leak...Not a real bad one. Just a nuisance. I think it's from, too much crank case pressure maybe. The shop that droped the motor in caped off 1 of the ports for the PCV/Breather System. I have changed it 4 times. Always leaks and in the same stop. Near the lower cam on the front. Leaks onto the header and causes alot of smoke.
2.0 to 2.5 Swap 02WRXSTiImpreza Subaru Conversions 2 12-13-2006 02:02 PM
2.0 to 2.5 block swap SLO_02WRX Subaru Conversions 2 11-06-2006 09:39 AM
2.0 to 2.5 swap - engine suggestions hybrid gti 2 Subaru Conversions 3 05-18-2006 12:23 PM
2.0 to 2.5 block swap, what's the ideal Compression ratio? 516_WRX_V2 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 10-25-2003 12:44 AM
Forester 2.0 to 2.5 engine swap???help Breen Subaru Conversions 14 10-15-2003 10:01 PM
