Old 05-10-2009, 05:53 PM   #26
HamFist
Member#: 2112
2000 Impreza 2.5RS
BRP
Does this combo survive over 18psi of boost?
HamFist is offline   Reply With Quote
Old 05-10-2009, 05:57 PM   #27
sniper512
Member#: 189923
1993 JDM WRX
Ummm yes its a USDM STI block I should hope so .
Well I guess it would also depend on which turbo is providing the 18psi as well lol.
sniper512 is offline   Reply With Quote
Old 05-10-2009, 06:13 PM   #28
HamFist
Member#: 2112
2000 Impreza 2.5RS
BRP
No guessing. Does it live...or does it crush pistons due to ****ed up quench and detonation?
Old 05-13-2009, 12:54 AM   #29
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
1994 BC4, 2015 Outback
With correct gasket thickness (ie. matching pistons rather than compression ratio) quench will be OK with these heads, combustion chamber design is not far off from EJ257.
Marnix is offline   Reply With Quote
Old 10-23-2012, 10:59 AM   #30
kimokalihi
Member#: 186972
91 Legacy SS EJ20G
Pearl White
Old thread but I'm curious how this would apply to 97 jdm forester ej20g heads? What gasket do I use for these heads? I think the CC of these heads is different from the wrx heads. I've already got them though and I have a 257 shortblock so I'd like to rebuild it with forged pistons and put these hads on and see how my robtune handles it. Rob said it'll be fine and the ecu won't know the differemce. It'll just see more airflow and add more fuel accordingly. Its tuned for 550s and td05.
kimokalihi is offline   Reply With Quote
Old 10-24-2012, 02:43 AM   #31
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
You will need the forged pistons for EJ205 WRX heads then compression ratio is acceptable. If you go for EJ257 STI pistons compression ratio is too high to run even moderate boost.
Old 10-24-2012, 01:45 PM   #32
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
I'm curious about the 25D gasket. I can't remember for sure but is it quite thick because the 25D piston pokes out above the deck at TDC? So that would be the gasket to go for when mating a 25D to 20H heads?
i_c_the_light is offline   Reply With Quote
Old 10-24-2012, 03:30 PM   #33
kimokalihi
Member#: 186972
91 Legacy SS EJ20G
Pearl White
Ok cool. Which head gasket?
Old 01-30-2013, 11:57 AM   #34
eph
Member#: 83120
1992 SS EJ225T
cj91legss
Kimo, Looks like we'll both be in for a 257. Subscribed!
eph is offline   Reply With Quote
Old 01-30-2013, 10:16 PM   #35
RallyColtTurbo
Member#: 16819
If you haven't rebuilt the shortblock yet, why not go with custom pistons? The cost over an off-the-shelf piston is marginal (+20%ish).
That way you can use a standard off-the-shelf head gasket and choose your exact desired compression ratio. All it takes is a bit of math.
RallyColtTurbo is offline   Reply With Quote
Old 02-10-2013, 03:23 PM   #36
Subbiespeed
Member#: 276493
2005 STI
you should look up the thread i had posted about this it should answer a lot of questions
Subbiespeed is offline   Reply With Quote
Upgraded 2.0 heads with 2.5 block MS WRX Built Motor Discussion 3 01-11-2008 08:21 PM
WRX with 2.5 Sti Block 293whp 13.5k! awdvf22 Private Vehicle 'For Sale' Classifieds 5 03-21-2007 03:19 PM
WRX with 2.5 Sti Block 293whp awdvf22 Private Vehicle 'For Sale' Classifieds 4 03-17-2007 05:12 PM
help with 2.5 sti block breather holes plugged? ktmbass85 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 03-07-2006 04:37 PM
2.5 sti block with 2.0 regular wrx heads serious Normally Aspirated with bolt-on Forced Induction Powertrain 21 08-03-2003 12:36 PM
