Welcome to the North American Subaru Impreza Owners Club Saturday July 2, 2016
Old 04-23-2009, 05:26 PM   #1
The Satch
Member#: 149174
that 's cool. i
have a goldfish.
Default Bad Idea? testing for boost leak
im not hitting target boost, missing by about 6 pounds, i have already checked all gaskets and hoses, and i dont have a smoke/fog machine. i saw an idea when i searched of using dry ice to fog the system. the idea was take a coke bottle, insert dry ice and water, and seal it with tape to the turbo inlet. this would force the fog down the charge pipes and pressurize the system allowing me to spot any leaks. any reasons i shouldnt do this?
The Satch is offline   Reply With Quote
Old 04-23-2009, 05:42 PM   #2
jack klompus
Member#: 152885
2014 Malibu LTZ
Have you used compressed air to see if you even have a leak? Compressed air & soapy water is usually good enough.
jack klompus is offline   Reply With Quote
Old 04-23-2009, 05:44 PM   #3
The Satch
Member#: 149174
that 's cool. i
have a goldfish.
less enthusiastic about soapy water. i have put a vacuum pump on a lot of lines and found no leaks.
Old 04-23-2009, 05:44 PM   #4
The Satch
Member#: 149174
that 's cool. i
have a goldfish.
Old 04-23-2009, 05:51 PM   #5
jack klompus
Member#: 152885
2014 Malibu LTZ
vacuum wont find a boost leak. at least not one pre throttle body. Soapy water is fine, plus it cleans your engine bay. Compressed air boost leak will check your intake system, turbo to intercooler, bov and IC to throttle body.
Old 04-23-2009, 05:54 PM   #6
The Satch
Member#: 149174
that 's cool. i
have a goldfish.
makes sense. is there one line i can hook the compressor up to to check the entire system in one go?
Old 04-23-2009, 06:09 PM   #7
RealiTnh
Member#: 191452
2004 ej20 18g 303whp
@ 20psi Synaptic tuned
starter fluid
RealiTnh is offline   Reply With Quote
Old 04-23-2009, 06:10 PM   #8
jack klompus
Member#: 152885
2014 Malibu LTZ
Search for boost leak test, theres a ton of threads on it. You have to construct a plug to plug up the intake hose, right after the air filter. All you need is a 2 or 2 1/4 or 2 1/2 (cant remember size) pvc end cap and attach a fitting on it to hook up to a air line. I just used a 1/8 npt copper fitting with a nipple on it and i connect it to my air blower / floor sweeper with a rubber vacuum line
If theres no leaks it will hold pressure solid, if theres leaks you hear hissing where its coming from.
Read up on the threads, and make sure you use a regulator and set it low, 15 psi is good enough to find leaks. You dont want to pump 90 psi into your intake system
how to test for boost leaks? subylove8 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 07-17-2007 04:21 PM
Need help testing for FMIC leak... az03wrx South West Impreza Club Forum -- SWIC 6 02-02-2007 10:02 AM
Checked for boost leaks, purge valve leaks, any ideas? overdose Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 07-05-2005 03:55 PM
How to test for boost leak? trex1200r Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 10 04-13-2005 03:46 AM
Testing for air leaks Aaron'z 2.5RS Technical Forum Archive 2 05-21-2000 06:55 PM
