Old 04-18-2002, 10:41 AM   #1
Rich10
Member#: 14934
Default Pulley and engine damage
Can anyone mention a case in which a lightened or underdriven pulley caused engine damage on a Subaru boxer 4 engine?
Rich10 is offline   Reply With Quote
Old 04-18-2002, 11:22 AM   #2
live311
Member#: 10801
2008 Outback
Maybe it threw the crank out of balance. Is your question hypothetical or did it really happen?
live311 is offline   Reply With Quote
Old 04-18-2002, 11:59 AM   #3
99OBSter
Member#: 14324
1999 OBS 4eat
I've never heard about any problems from properly installed pulleys, either lightened or underdrive. Now, if you don't tighten the retaining bolt for the crank pulley right, it can start to wobble and cause problems. That would be bad.
99OBSter is offline   Reply With Quote
Old 04-18-2002, 12:40 PM   #4
RaceCarRiot
Member#: 6542
1997 Ver IV
lightened or underdriven pulleys usually cause problems on other cars, because the crank pulley incorporates a harmonic balancer...which a lightened one eliminates. the added vibration from removing the balancer can lead to premature crank bearing wear.
subarus don't have this problem because of the opposed engine layout.
i seem to be the only one experiencing any problem with my pulleys, but it's certainly nothing major...just annoying.
http://www.i-club.com/forums/showthr...hreadid=173962
-adam-
RaceCarRiot is offline   Reply With Quote
Old 04-18-2002, 12:46 PM   #5
Rich10
Member#: 14934
My question is hypothetical. I have read threads in which people warn of catastrophic engine failure from pulleys. I haven't heard of a single case in which this has occurred. I am trying to see if this is a problem.
Old 04-18-2002, 01:41 PM   #6
tmat3
Member#: 2817
2001 Impreza 2.5RS
BRP
On Miatas and BMWs, using aftermarket pulleys caused a load of problems. Miatas appearently have weak cranshaft design in the first place.
On our cars, because of the horizontally opposed engine layout, the vibration theoretically gets cancelled out. Also, unlike other 4 cylinder engines, the length of the cranshaft is shorter. Thus, the crankshaft is stronger.
That being said, there had to be a reason why Subaru decided to use a harmonic damper though. Probably as a safety measure.
tmat3 is offline   Reply With Quote
Old 04-18-2002, 05:43 PM   #7
obyone
Member#: 16523
Would make sense if you think about it....Subaru's logic was probably "Put a piece of rubber there, save on the lawsuit"
obyone is offline   Reply With Quote
Old 04-18-2002, 06:41 PM   #8
RawCode
Member#: 3115
2002 Impreza 2.5RS
If you notice, it is a REALLY tiny peice of rubber...
RawCode
RawCode is offline   Reply With Quote
Old 04-18-2002, 07:38 PM   #9
Richard L.
Member#: 8465
'00 2.5RS Coupe, AW
'93 GMC Typhoon AWD
Folks, vibration still exists in Subaru 4-cylinder horizontally opposed engine. To be specific, there are still free moments of 2nd order acting on the engine. On the other hand, in-line 6, horizontally opposed 6, and 60 V-12 engines are naturally and completely balanced because these do not have free forces and moments acting on them. So don't get overly confident. Yes, there is a reason why we have a harmonic damper.
Richard L. is offline   Reply With Quote
Old 04-18-2002, 10:43 PM   #10
Rich10
Member#: 14934
I don't know why Subaru put the harmonic damper in the car. One explanation that I have heard is to help with NVH. I have asked my original question several times in several posts, "Can anyone mention a case in which a lightened or underdriven pulley caused engine damage on a Subaru boxer 4 engine?"
I have yet to hear of a single instance of damage to a Subaru horizontally opposed engine caused by a lightened or underdriven pulley.
Old 04-19-2002, 11:23 AM   #11
maciek
Member#: 11216
1991 SS 1998 BG
1996 BD
I don't know if it is true, but I talked to a Subaru technician and he thought that the rubber piece on the stock pulley was mainly to take out vibrations from the belts.
maciek is offline   Reply With Quote
Old 04-19-2002, 12:45 PM   #12
Richard L.
Member#: 8465
'00 2.5RS Coupe, AW
'93 GMC Typhoon AWD
Here is a very informative table from the Bosch Automotive Handbook, 5th Edition, posted by Jon [in CT] back in January 8th of 2002:
As you can see, there are free moments of 2nd order in all H-4 engines. You can learn more about this in a good college automotive engine design course.
3 gramlights 57 pro and 1 damaged one ! laruffa SCIC Private Classifieds 92 01-28-2010 10:30 PM
question about over revving and engine damage sburck Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 30 01-18-2009 10:35 AM
pulleys, pulleys and more pulleys msingell Transmission (AT/MT) & Driveline 5 12-22-2007 11:27 PM
High EGT's and engine damage Rich10 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 11-03-2003 09:37 PM
Pulley and engine damage Rich10 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 23 04-19-2002 05:56 PM
