Old 04-18-2002, 10:51 AM   #1
Jademonkey
Member#: 9213
2000 RS
Red
Question Problem with Magnecor's ?
Okay, so I'm driving to work this morning. I'm gong up hill, and I notice my engine starting to studder. Hmm....this seems odd. It stops then i continue on my way. Concerned, I decide to drive some more, seeing if I can recreate the problem. I turn around, go back up the hill...then it happens again. My engine starts to shudder. My CEL flashes. By the time I'm starting to pull over, the CEL turns off. I pop my hood, and the wires on the passenger side (where the connect to the plug) are like 1/2 in. out of the hole? ***? I made sure i pressed VERY hard when I put those on, (last week).
Does anybody else have this problem? My brother said he used to run Magnecor's but switched to MSD, because they didn't fit right and would come out while he drove. Any suggestions to alleviate this problem?
PS i did a search already. There is just too much info!
Thanks!
Jademonkey is offline   Reply With Quote
Old 04-18-2002, 05:17 PM   #2
tcs007
Member#: 4103
2003 WRX Wagon
Reddish
Mine used to do it until I used the end of a ratchet to press them on.
Push as hard as you need to till you hear an audible "click", then you know its on there. Take your battery if you need to to get extra leverage.
tcs007 is online now   Reply With Quote
Old 04-18-2002, 05:55 PM   #3
AJ711
Member#: 6178
98 GM67 + 03 SG6
2 whls > 4 whls
The battery and if you can, the windshield washer fluid reservoir. That'll give you plenty of extra space to move around there. You can unbolt the tank without disconnecting it, it's up to you. That'll give you plenty of room to get the wires properly seated.
AJ
AJ711 is offline   Reply With Quote
Old 04-18-2002, 06:05 PM   #4
Jademonkey
Member#: 9213
2000 RS
Red
Cool, i'll try the rachet. Thanks for the advice!
Old 04-19-2002, 09:58 AM   #5
Retsyn
Member#: 1910
When I first got mine I did the same thing... You REALLY have to mash those things on...
Retsyn is offline   Reply With Quote
Thread for 2006 WRX's with Stock Transmissions with no problems with more WHP/WTQ rhinotech Transmission (AT/MT) & Driveline 233 07-19-2013 09:33 PM
Got a little problem with the speakers, needs help to pinpoint the problem. SilentShadow Car Audio, Video & Security 4 12-03-2006 09:34 PM
Problem with AT - 2 gears, problems shifting. mrmephistopheles Transmission (AT/MT) & Driveline 0 07-10-2006 05:35 AM
04 WRX fixed most of my Knock problems with UTEC. Just 2 problems now! kitbar Engine Management & Tuning 10 11-15-2003 11:23 AM
Question about the problem with Magnecor's live311 Normally Aspirated Powertrain 1 03-08-2003 02:31 PM
