Closed Thread
Old 04-24-2009, 09:47 AM   #1
07Suby
Member#: 146747
2007 TR
Urban Grey
Angry Ligthing & CEL Issue
Im having a intermittent cel light issue with my boost control solenoid i had a P0244 for boost control solenoid "a" out of range replaced solenoid same issue. the same cel light is tagged with a p0442 code for evap leak. now when i get the cel the right highbeam bulb intermittenly malfunctions. the boost solenoid code just comes on doesnt fuel cut me or anything just the light. Wtf is wrong here??? i have an 07 tr by the way.
07Suby is offline
Old 04-24-2009, 10:47 AM   #2
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
For the problem with the headlight and CEL troubles happening at the same time I would guess the trouble is with a connector in the engine compartment. It sounds to me there are some connections in it. Try pulling the main connectors apart and reconnecting them to see if that will help.
For the solenoid issue it sounds like the trouble is with whatever the solenoid is controlling, not the solenoid itself.
Cougar4 is offline
Old 04-24-2009, 10:55 AM   #3
07Suby
Member#: 146747
2007 TR
Urban Grey
Cool
ive checked the connectors and there ok. wiring diagram does not show solenoid having anything to do with headlamp which boggles me. what does the boost control solenoid control so i can track that down??
07Suby is offline
Old 04-24-2009, 11:16 AM   #4
jdubya301
Member#: 139076
2002 stg2 wagon
03 suzuki sv650s
could be a ground? maybe they share similar grounding points?
jdubya301 is offline
Old 04-24-2009, 11:25 AM   #5
07Suby
Member#: 146747
2007 TR
Urban Grey
all grounds are tight and snug, no corrosion.
07Suby is offline
Old 04-24-2009, 12:18 PM   #6
Cougar4
Member#: 53443
Winestone
The headlights don't have anything to do with the solenoid but the two circuits very well may pass through the same connector somewhere. I don't know how you checked the connectors. If you just looked at them and saw they were connected that isn't good enough if that is the trouble. They have to be seperated and reconnected to make the connection better. The same goes for the grounds. They can look ok but still not make a good connection. The wire needs to be removed and the surface areas cleaned.
I think the boost solenoid controls the amout of air getting to the turbo.
Cougar4 is offline
Old 04-24-2009, 12:52 PM   #7
07Suby
Member#: 146747
2007 TR
Urban Grey
Subaru Stars
tommorow morning i will be deleting my TGVs so having most items out of the way ill check grounds and make sure no wires have melted together.
07Suby is offline
Old 03-20-2011, 09:14 AM   #8
MortenWRXSTI
Member#: 277334
2003 WRX STI
Wrc blue
Default Big problem with my 03 STI
Suddenly the engine with humbling a couple of times and the car was making too much boost.... not boost cutting as usual. and 3 codes is in the ECU.... p0123 throttle position circuit high input, p0118 engine coolant input too high and p0244 wastegate solenoid range input high. something like that
There has never been any problem in the last two years... Only mods are exhaurst system, manifold and decat downpipe. And it has been runing great until this problem suddenly has appeared.
Really hope anyone can help me or has a clue?
Here in Denmark there is not driving a lot of Subarus, so there is no a lot of experts to help
MortenWRXSTI is offline
Old 03-20-2011, 01:27 PM   #9
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Why did you bump a two-year-old thread in the wrong forum to post this?
Also I see you crossposted the same thing in a few different places, that is not permitted here.
Mulder is offline
Closed Thread
Dash board ligths & clock flashing 07STI redfoxn1 Electrical & Lighting 4 01-10-2009 01:21 AM
FS: Florida: Divored Catless Downpipe w/ 02 Sensor & CEL Fix & Braket xdescrubx Engine/Power/Exhaust 4 05-17-2008 09:12 AM
CEL & Idle issues after tune muffnbluff Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 11-23-2007 04:44 PM
Got P0120 CEL after emanage install & other issues mxpunk Normally Aspirated with bolt-on Forced Induction Powertrain 27 07-27-2007 12:27 PM
PDM Racing CAI. What CEL issues, now? Siper2 Normally Aspirated Powertrain 9 07-22-2002 02:39 PM
