Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 04-24-2009, 10:15 AM   #1
dauss
Member#: 108369
2005 CGM WRX Wagon
68HTA
Default What causes tire cupping?
So I got my tires balanced last week and the tech said that my tires were cupped, mainly on the passenger side of the car. I got them balanced after 8000 miles, and they were brand new Goodyear Eagle F1-DS G3.
A friend said that my struts might be blown. I have Koni Sport shocks with STi Pink wagon springs. I jacked up the car, pulled off the wheel, and looked at the shocks. No hydraulic fluid anywhere. Any other way to check to see if they're blown?
Another friend said it just might be my alignment. I'll just got an alignment 1 week ago and I can post up my before and after numbers when I get home. I have Whiteline 22mm FSB and their 24mm RSB.
Thanks,
David
dauss is offline   Reply With Quote
Old 04-24-2009, 12:58 PM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
bad alignment
ya want '0' toe
a blown strut may cause this as well....or damaged suspension
Old 04-24-2009, 02:43 PM   #3
dauss
Member#: 108369
2005 CGM WRX Wagon
68HTA
Can they still be driven on or toss them and get a new set? They have 6/32nd's tread left on all 4.
Old 04-27-2009, 09:49 PM   #4
Subydude81
Member#: 118266
2007 Lexus IS250 RWD
6MT
I'd check your alignment numbers. If toe is off would cause uneven wear. You might as well keep the tires till there totally out of tread then buy a new set and get a correct alignment.
Edit: I was thinking feathering not cupping.
TurboL is correct.
Subydude81 is offline   Reply With Quote
Old 04-27-2009, 10:42 PM   #5
turboL
Member#: 111735
96 Legacy2.0GTSOLD
Bimmer Tech
alignment wont cause cupping. Cupping is from the tire striking the ground harder at one spot. bad struts will cause random cupping all over the tire. An out of balance tire will cause cupping in one or two spots. You could also have a damaged tire. Ask for a road force balance and see if they can match the tire to the wheel.
ive seen BAD struts that never leak. good way to tell if they are bad is to jounce the suspension. It should go down, and come back up. Thats it. If it does that like 2-3 times, your struts are weaksauce.
turboL is offline   Reply With Quote
Old 04-28-2009, 11:21 AM   #6
drivin blind
Member#: 73043
2011 STI/2010 370Z
Black/Black Cherry
After checking and finding out your alignment is ok, which you did, (you didn't say if any corrections were made) I'd just put the fronts on the back. They should be fine. They may make noise, but should wear down flat. (eventually) RP
drivin blind is offline   Reply With Quote
Old 04-28-2009, 07:02 PM   #7
flukewrx
Member#: 75081
2003 WRX
Here's some diagrams that might help out.
http://tireguides.com/print_friendly...tails&ttcid=10
flukewrx is offline   Reply With Quote
Old 05-10-2009, 08:10 AM   #8
dauss
Member#: 108369
2005 CGM WRX Wagon
68HTA
Sorry it has taken so long for me to get back to this thread. So the suspension has a lot of mods. 22mm adj. Whiteline FSB set @ 22mm, 24mm adj. Whiteline RSB set @ 24mm, Kartboy Endlinks, Koni Inserts, STi Pink wagon springs, Group N "STi" Strut mounts(front and rear), GT-SPEC rear tower brace, Whiteline steering rack bushings.
I do mostly highway driving, and I put on about 23,000 miles a year.
Old 05-10-2009, 12:20 PM   #9
Sir-Knight
Member#: 73636
2007 Impreza 2.5i SE
newport blue pearl
your toe should be fine now, there's not a lot, there was a bit before which was probably what was causing the cupping. I'd keep an eye on it though the next little while. If the cupping is particularily bad you can flip the tires on the wheels so it's on the outside of the wheel.
Are the tires directional or can they rotate either way? If they're not directional you can flip the cupped ones to the other side of the car and see if the ones that are fine get cupped again, but if both tires were having issues on the one side, it's not really a strut issue.
You ever hit a pothole hard or anything hard on the driver's side? caster is off just at tiny bit...
Sir-Knight is offline   Reply With Quote
Old 05-10-2009, 06:15 PM   #10
dauss
Member#: 108369
2005 CGM WRX Wagon
68HTA
Yes, an especially nasty pothole destroyed my driver's front suspension. Had to get a new wheel, control arm, strut, strut mount, control arm, fender liner, and a few other things.
shot struts causing tire cupping? Glockperfection Brakes, Steering & Suspension 32 09-27-2010 06:05 PM
Tires cupped, from what? ralliharri Brakes, Steering & Suspension 22 11-08-2007 09:10 PM
Rear tires going bad? What caused it? What are some good tires? elitescouter Newbies & FAQs 46 05-02-2007 11:14 AM
tire cupping Heavy Fuji Brakes, Steering & Suspension 4 11-18-2002 06:52 PM
Plus 1 upgarde:Now tires cupping zabutter Brakes, Steering & Suspension 1 02-26-2002 02:03 AM
