Old 04-11-2001, 06:59 PM   #1
Ethan
Member#: 246
Post Dry Crank? help quick!
Could someone please tell me how to dry crank the engine. I don't want the engine started at all. if I pull the plugs out of the distributer cap will that allow me to do it?
Ethan is offline   Reply With Quote
Old 04-11-2001, 07:08 PM   #2
Craig W
Member#: 643
1999 2.5RS
WRX powered
Post
That'd work, just make sure you keep track of which plug wire goes where. Or you could pull the plug wires from the plugs on the heads and just leave 'em dangling. That'd be easier to keep track of which goes where.
Craig W is offline   Reply With Quote
Old 04-11-2001, 07:13 PM   #3
Ethan
Member#: 246
Post
Wow that was fast, thanks.
Old 04-11-2001, 07:14 PM   #4
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
Post
Unplug the coil pack. (there's no distributor)
If you have stock plug wires, they are numbered 1-4.
ColinL is offline   Reply With Quote
Old 04-11-2001, 07:15 PM   #5
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Post
I take it this is for the initial clearing of burrs in a newly-built engine?
Old 04-11-2001, 07:16 PM   #6
Avenger
Member#: 1234
Post
Make sure you don't crank too long, becuase if you crank too long a lot of fuel will be sprayed into your engine and will flow to your cat. This could case a melt down of your cat when hot enough. Best thing to do is to pull the connector off the cam sensor.
Avenger is offline   Reply With Quote
ej20g dry crank to build oil pressure NO PRESSURE!!! GregBolby Pre-2002 Factory Turbo Powertrain 4 07-23-2009 01:56 PM
Need help quick crank pulley brandonbeeb Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 05-01-2007 01:57 AM
drag racing with dry ice....help downsti Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 17 08-18-2005 01:44 PM
piston/rod/crank help for my frankenstein Chuck Normally Aspirated with bolt-on Forced Induction Powertrain 16 04-16-2002 05:43 PM
('93-'01) Need HELP quick please... kaos200 Impreza Forum 2 04-21-2001 08:22 AM
