Old 04-24-2009, 11:48 PM   #1
esmekiller
Member#: 208724
02 WRX
Default Good oil temp
Ok been looking around and seeing that somepeople say 200 to 210 is a good oil temp. I have also seen 220 to 230. I think the factory said 245 is the max.
I'm at 220 with the oil plug in the front with the oil filter. Is this to high? If so what can i do about?
esmekiller is offline   Reply With Quote
Old 04-25-2009, 02:55 AM   #2
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
I've always been taught that 220-230F is a good target, as that will boil off any moisture that gets entrained in the oil.
The factory oil cooler that goes between the filter and the block seems to hold oil temps around 205-215F on my N/A EJ25 in normal driving.
Max oil temp depends on what oil you're running. In track use I see 260-270F, but I'm not too worried about it. I know guys who run 300+F on track. As long as you're using good quality synthetic and you've maintaining sufficient pressure at those temps it's not an issue.
Pat Olsen
Old 04-25-2009, 09:31 AM   #3
MasterKwan
Member#: 98961
2003 WRX
Yeah, and change it fairly often. I saw an oil analysis once that showed 100 track miles was the same as 3-4000 regular miles wear wise. I change the oil every 2 track days.
Old 07-19-2009, 10:08 PM   #4
Rallly2000
Member#: 91600
2000 RS(JDMSTI REP)
Silverthorn
I use Amsoil 5-30W and my peak oil temp on track day was 245F. Is this cool?
Rallly2000 is offline   Reply With Quote
Ca Fs:60mm Oil Temp, Boost, Water Temp, Oil Pressure Gauge woaiwrx Interior/Dressup/Audio & Security 11 08-28-2007 06:51 PM
FS SoCal: DEFI oil temp, oil press, water temp gauges and DEFI meter hood Dforce Interior/Dressup/Audio & Security 32 08-24-2007 04:37 PM
FS: DEFI oil temp, oil press, water temp gauges and DEFI meter hood Dforce SCIC Private Classifieds 33 08-24-2007 04:37 PM
Idle/city driving oil temp higher than highway cruising oil temp? Cusco Normally Aspirated with bolt-on Forced Induction Powertrain 7 01-17-2003 04:33 PM
Oil Temp or Oil TANK Temp from Autometer EnderW Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 11-04-2001 08:17 PM
