Old 04-25-2009, 01:47 AM   #1
BAN SUVS
Member#: 28685
2004 FXT 4EAT
very STi'd
Default Help- frankenstein radiator hose!
So I've got an EJ251 in my RS with an upgraded radiator that I presume fits GC8s (as in actual WRXs). The lower outlet for the radiator is on the bottom corner on the driver's side. Right now I've got a patched together splice of two random hoses I found at Kragen, but I don't trust it permanently. So, does anybody know of a hose part number that will fit? It needs to be a pretty tight S shape. Universal bendy hoses won't bend small enough to make it. Alternatively, I'd be okay with a nice non-plastic 1.5" hose coupler. That's all Kragen stocked and they were the only ones open when I found the leak. I'd have put it off til tomorrow, but I have to head out of town for autocross around 6:45. I'm packing some spare hose bits and a few gallons of water, just in case, though I think this version will hold up after 20ish shakedown miles.
BAN SUVS is offline   Reply With Quote
Old 04-25-2009, 02:23 AM   #2
00LGTP
Member#: 172618
1995 EJ253/D25 GC
371hp/355tq 1.5xtr 93oct
so your trying to put a WRX rad on a RS engine.
i did that!
NAPA part # 9128 for the upper hose.
00LGTP is offline   Reply With Quote
Old 04-25-2009, 06:37 AM   #3
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
My DOHC 2.5GT has the lower hose on the lower driver side corner of the radiator. The hose may be what you need, as it is S or Z shaped. The Navy for some reason won't let me browse to my website, but if you check www.submariner.org/thepno95 and then go to the Pictures -> Subaru -> Underbody pics (I think that's what the folder is called) you may be able to see the hose. If not there, check the Engine folder, look for files regarding my Samco hose install.
If I log in elsewhere I'll try to remember to come back to this and post pics.
Pat Olsen
Old 04-25-2009, 09:50 PM   #4
BAN SUVS
Member#: 28685
2004 FXT 4EAT
very STi'd
i did that!
I need a lower hose, the upper is fine.
Pat Olsen
I couldn't get to your portion of the site (I get a forbidden message) but it sounds like what you have will do it. I know there's a hose out there that works for this, I just haven't had a chance to look before today's autocross. As it is, the second version of the patched hose held up. I suppose it will at least last long enough for me to find a metal coupler or the right shape hose.
Old 04-25-2009, 11:56 PM   #5
rougeben83
Member#: 115154
2005 Outback XT
White on grey
From pat's site:
Maybe you need WRX rad hoses? The lower one (on the left) is shaped differently from above it seems
rougeben83 is online now   Reply With Quote
Old 04-26-2009, 12:32 AM   #6
BAN SUVS
Member#: 28685
2004 FXT 4EAT
very STi'd
Nope, won't work. The EJ251 thermostat housing points forward, directly at the radiator.
Old 04-26-2009, 07:23 AM   #7
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
Bummer. Of course, if you can't find the hose you need, you could always install the thermostat housing like mine and use my style hose. (Since taking that pic I have upgraded to the OEM oil cooler, so I have the metal water neck with a hose nipple off it for the cooler).
Good to see someone can get to my website, though - when BAN SUVS said he couldn't see it that started to make me wonder if it's not the Navy filtering that's preventing my access, but is instead something wrong with the site.
Pat
Old 04-27-2009, 01:47 AM   #8
BAN SUVS
Member#: 28685
2004 FXT 4EAT
very STi'd
I'll have to check again, but I remember looking at it and thinking that something would conflict. Maybe the EL header I have.
Old 04-27-2009, 04:42 AM   #9
rougeben83
Member#: 115154
2005 Outback XT
White on grey
fwiw, my car had an ej251 and the lower wrx rad hose will work with some trimming on the end.
Old 04-28-2009, 12:50 AM   #10
BAN SUVS
Member#: 28685
2004 FXT 4EAT
very STi'd
Yeah, I'm starting to think I figured it out- I stole the t-stat housing from the EJ20 I took out, assuming it bolted the same way. If I get one from an EJ251 I think I'll be able to go back to the WRX hose.
Old 04-28-2009, 08:56 AM   #11
Aegean93L
Member#: 103162
04 RS Sedan
I was gonna say, the t-stat housing on my 99 RS engine points to the right, just like in rougeben's pic.
I think that will fix all your problems.
Aegean93L is offline   Reply With Quote
FS: NoVA: Samco Radiator Hoses in Black and 4 No Tear Clamps for 02-07 WRX / STi. adjasont Engine/Power/Exhaust 5 11-27-2011 03:06 PM
Help. Borked radiator hose. robbieshonda Mid West Subaru Owners Club Forum -- MWSOC 0 03-14-2009 05:59 PM
HELP!!! Upper Radiator Hose mcmanalot South West Impreza Club Forum -- SWIC 10 09-08-2008 01:51 AM
HELP! Radiator Hose Pulling Off SPeeDSiN Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 10-05-2001 08:09 AM
