Welcome to the North American Subaru Impreza Owners Club Saturday November 21, 2009
Old 04-25-2009, 03:41 AM   #1
MRSTI28
Member#: 163534
2005 STI
CGM
Default how do i debadge my 05 sti trunk???
so just like it say's ...i need to de-badge my trunk but i am not sure how to do it right!!! i have heard of alot of ways to do it but i want to get this right the first time cause well i wont be getting a second you know!! so i need to take off the letters that read subaru and the wrx and sti emblems ...
please point me in the right direction......
thank you for taking the time to read this!!!
-jerry
MRSTI28 is offline   Reply With Quote
Old 04-25-2009, 04:48 AM   #2
akstud1983
Member#: 162000
2004 Impreza RS2.5
Dirty and Smashed!!!
you can use a piece of dental floss and saw through it and pour wd-40 while sawing(disolves the glue)
or you can use a hair dryer and heat them upa nd pry them off.
since its an 05 you may want o get some kind of polish and buff it up when our done(there may be oxidation around the badges)
akstud1983 is offline   Reply With Quote
Old 04-25-2009, 06:26 AM   #3
Uncle Buck
Member#: 140062
2005 STI ATP3076r
365hp/95' Eclipse140chp!!
i've done it to four trunks and have found that the heat gun and prying with your hands works the best. make sure to wear gloves, it gets damn hot. then just use some goo gone to get the rest of the adhesive off then wax after that.
Uncle Buck is online now   Reply With Quote
Old 04-25-2009, 07:51 AM   #4
gausy66
Member#: 147494
2007 WRX Ltd. 4EAT
WRB Stage 3 VF39
Here i uses this video as a tutorial and it worked really well.
http://videos.streetfire.net/video/d...-sti_22344.htm
gausy66 is offline   Reply With Quote
Old 04-25-2009, 12:02 PM   #5
BretskieSubie
Member#: 200793
06 ...stock WRX/B
View Member's Myspace Profile
fingernails work good to get the rest of the goo off. wont scratch the paint either.
BretskieSubie is offline   Reply With Quote
Old 04-25-2009, 12:23 PM   #6
Simes
Member#: 138641
2002 STi
Fishing line works much better than dental floss. As mentioned, it does help to heat the badge up with a hair dryer or heat gun on a low setting first.
3M also make a really good aerosol adhesive remover too - you can get it at Pep Boys and Murrays.
Simes is online now   Reply With Quote
Old 04-25-2009, 12:32 PM   #7
dubya-R-ex
Member#: 113698
REAL FRIENDS DON'T
LET FRIENDS BUY ROTAS!
This gets asked far too often. Search debadge. All your answers are in there.
dubya-R-ex is offline   Reply With Quote
Old 04-25-2009, 01:21 PM   #8
Le Saboteur
Member#: 142244
2004 wrx
ld2c
Just get an angle grinder and 30 grit sandpaper. Works everytime.
Le Saboteur is offline   Reply With Quote
Old 04-25-2009, 02:14 PM   #9
mowatt15
Member#: 206743
05 WRX
Platinum Silver Metallic
thanks. that video was very helpful
mowatt15 is offline   Reply With Quote
Old 04-25-2009, 03:26 PM   #10
holycheezit
Member#: 188885
2004 Forester XT
Java Black Pearl
I heated mine up with a hair dryer and then ran fishing line behind it then heated the remaining adhesive up with the hair dryer so it would come off. Then I clayed and waxed the trunk.
holycheezit is offline   Reply With Quote
Old 04-25-2009, 06:06 PM   #11
MRSTI28
Member#: 163534
2005 STI
CGM
thank you all for the replys
Old 04-25-2009, 10:51 PM   #12
07imprezadrifter
Member#: 147720
2007 Impreza 2.5i
Urban Metallic Gray
I think you left a "C" shaped badge on the right....
07imprezadrifter is offline   Reply With Quote
Old 04-25-2009, 11:00 PM   #13
darknightohio
Member#: 50523
2010 GTI
United Gray
search please.
darknightohio is offline   Reply With Quote
Old 04-26-2009, 09:41 AM   #14
Ryan314
Member#: 82989
Black on Black
The "SUBARU" letters came off pretty easy on my 02 WRX, had to do some polishing but nonetheless fairly easy. But my "WRX" badge was an absolutely PITA! Don't know why. Just make sure you have some good polish and a buffer to really clean it up afterwards.
Ryan314 is offline   Reply With Quote
Old 04-26-2009, 11:02 PM   #15
snowmants
Member#: 112608
1997 BlackS14 Silvia
'04 Silver WRX Wagon
Someone will actually try this.
snowmants is offline   Reply With Quote
Old 04-27-2009, 01:40 PM   #16
robbocoppp
Member#: 191231
2004 Impreza 2.5RS
Dental floss, bug and tar remover, a hairdryer, wax, and a buffer....that's all you need.
Oh and a lot of elbow grease
robbocoppp is offline   Reply With Quote
Old 04-27-2009, 02:12 PM   #17
Ogden
Member#: 1748
'09 Outback Sport
OBP over DGM
Did my OBS yesterday. All it took was a hot day in the sun and dental floss, though if I had thought of fishing line that would have been better. I used goo-gone and my fingernail for the remaning adhesive.
Personally, I felt better cutting them off, rather than prying them off.
A quick wash and a bit of wax and it was all good.
Ogden is offline   Reply With Quote
Old 04-27-2009, 07:05 PM   #18
BoostinIX
Member#: 136701
2005 PSM STi
04 WRX-RIP Stitch!
Did mine this past weekend. Lil floss, lil adhesive remover, lil claybar, lil wax....puuuuuuurdy
BoostinIX is online now   Reply With Quote
Old 05-10-2009, 10:34 PM   #19
gindobuck
Member#: 141650
how this video makes it look easy, which would you use the bug tar or the wd40?
also my friend tried a hair dryer on his bmw and the paint the next day just started looking faded afterwards, i saw the vid use a hair gun but i just want to make sure hours later and days later the paint will still look good?
gindobuck is offline   Reply With Quote
Old 05-11-2009, 12:46 AM   #20
The Beej
Member#: 99677
2002 AW Impreza WRX
VF-39, 06 5spd, 20psi
get the letters off with wet hemp...i kid you not. then use bug and tar remover to get rid of the residue...works like a charm
The Beej is offline   Reply With Quote
Bookmarks
Message Board Statistics All times are GMT -4. The time now is 03:45 AM.
