Old 04-25-2009, 07:17 AM   #1
onslot19
Member#: 191753
2003 Baja, legacy ss
Baja Yellow & black trim
Unhappy ej22t legacy idle problem
i just swapped a new stock vf11 turbo because the other one i had in ther crapped out. my problem is since i installed the turbo my idle is racing to 3 grand. and it is pushing maximum boost??? i dont know why i hooked all vacuum line back up the same way and the stock b.ov the same way.
any input would be helpful
onslot19 is offline   Reply With Quote
Old 04-25-2009, 09:02 AM   #2
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Sticky wastegate?
Old 04-25-2009, 09:32 AM   #3
Abest10
Member#: 190962
00 STM RS
04 FXT
Maybe a bad idle air control valve. Also you said you checked for vacuum leaks. Just double check. I know that's what happened on my buddy's 91 ss. He was idling at 2.5k rpms. Hope you figure it out. Good luck!!
Abest10 is offline   Reply With Quote
Old 04-25-2009, 10:33 AM   #4
Matt Monson
Member#: 832
99 2.5RS, '85 911
IAC wouldn't make it overboost like that. It's something related to the turbo itself or the routing of the lines.
Weird idling problem - Very high idle Oodles-of-Noodles Mid Atlantic Impreza Club -- MAIC 21 02-04-2010 10:25 PM
Crap Idle Problem, Can't hold idle, sometimes dies when I push clutch in TROLL Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 91 09-02-2008 09:40 PM
Help! '90 legacy L off-idle problem Sloewag'n Legacy Forum 15 01-13-2007 12:48 PM
EJ22T rough Idle/ stalls DrunkenDragon Pre-2002 Factory Turbo Powertrain 12 02-24-2006 10:32 AM
1990 Legacy Idle problem mhj Legacy Forum 2 08-14-2001 02:40 PM
