Old 04-25-2009, 02:35 PM   #1
bdj238
Member#: 207561
2005 WRB WRX WAGON
PPG Trans
Default Help troubleshoot windshield washer
I recently purchased a 2005 WRX and have since noticed that the windshield washer wont spray fluid. I checked the fuse and it was good so I changed the pump thinking that with 70K miles it may have just gone out, no big deal.
After changing the pump it still didn't work. I checked the pump by take the ground directly to the battery which engaged the pump spraying fluid. I do have +12V going to it so I assume that the switch (toggle) connects ground not VCC. Any one have any suggestions as to what I can do to trouble shoot this, I travel a lot and the bugs are starting to get bad! Note: Yellow/Blk wire to power.
thanks
bdj238 is offline   Reply With Quote
Old 04-25-2009, 03:26 PM   #2
DustinTarditi
Member#: 139798
2005 WRX Wagon
pulling the stalk to you is a "wipe clean" mode (no wash) - pressing the button on the stalk activates the washer... I guess you knew that, but I forgot one time and was pulling the stalk wondering why the stoopid WW wouldn't work... my problem was between the steering wheel and the seat.
DustinTarditi is offline   Reply With Quote
Old 04-25-2009, 07:04 PM   #3
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
the hose getting pinched on the strut top when the hood is closed is a common thing with this
Old 04-26-2009, 01:09 AM   #4
bdj238
Member#: 207561
2005 WRB WRX WAGON
PPG Trans
oh my god i cant say that i have EVER had such a loong and more true blonde moment in my life! There is a BUTTON!!!!!! I seriously never saw that.... I guess thats the military training in me - - "If it ain't broke, fix it till it is!"
I just walked down after reading DustinTarditi's comment and low and behold it works like a charm, thanks man. hope everyone gets a good laugh from this one!
Old 04-26-2009, 02:20 AM   #5
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
Put a different hose on it. See if it still fails to spray.
If you have voltage and fluid. You have a bad pump, likely a bad seal on the veins. If you go to the dealer. Expect to pay $100.
I have a $10 fix.
Go to the junkyard. Find a pump in almost any japanese car. It's likely the same type of pump and will work with no mod needed. The rear pump on the wagon is a bit different. Yet will work if rewired. Spent $10 and even got the wire and clip. I pulled mine from a 90 legacy.
Hope that helps.
LED Windshield Washer.. Leonardo Interior & Exterior Modification 9 06-13-2001 12:58 AM
Blue LED Windshield Washer Nozzles dug-e-fresh Interior & Exterior Modification 20 05-23-2001 07:31 PM
('93-'01) Windshield washer spray adjust? all4wheels Impreza Forum 6 04-07-2001 12:27 AM
Windshield washer fluid? tahrndt Legacy Forum 4 02-20-2001 07:07 AM
