Old 04-25-2009, 10:33 PM   #1
kewlboxer2
Member#: 161322
06 2.5i
Regal Blue
Default Spark plugs
i went to advanced auto today for some new plugs. figured id seafoam then get some new plugs and change oil. well i got advance auto and they dont have fr5ap-11 plugs at all and none of the their other stores have them. should i just get the plugs from the dealership? or is there any other plugs to use?
kewlboxer2 is offline   Reply With Quote
Old 04-25-2009, 11:58 PM   #2
Eyedoc Orlando
Member#: 146216
2007 Impreza 2.5i SE
Newport Blue Metallic
Ive had great success with the new Bosch Iridium fusion plugs. They fire well and I've not lost any fuel economy or power with them. I got the model 4501 and replaced them at 30K. I plan on replacing them again at 100K since they're long lasting plugs.
http://www.amazon.com/Bosch-4501-Pla...=1PL4XUCH6ABIH
Eyedoc Orlando is offline   Reply With Quote
Old 04-26-2009, 01:50 AM   #3
kewlboxer2
Member#: 161322
06 2.5i
Regal Blue
ouch $40 for plugs?
Old 04-26-2009, 12:03 PM   #4
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
$40 for once every 50-70k miles is pretty good investment. Try a serach, there are a few threads with plug discussions.
Old 05-03-2009, 11:18 AM   #5
wicked13
Member#: 196627
2002 Legacy OB Sedan
I did the same thing yesterday. Instead I of the factory numbered NGK's I got the NGK G power. I think they were $2something a plug. Everything is running fine so far. I've only put 20miles on it since I changed them. Anything would be better in my car, when I pulled the plugs they ranged from 37-49 on the plug gaps! Factory is 39.
wicked13 is offline   Reply With Quote
Old 05-03-2009, 04:39 PM   #6
kewlboxer2
Member#: 161322
06 2.5i
Regal Blue
i went with the bosch iridium fusion and working fine so far
Old 05-03-2009, 07:22 PM   #7
msingell
Member#: 153097
2012 CRZ
PWP
i bought the oem ones from the dealer. figure, if something goes wrong, id like the part to be oem.
msingell is offline   Reply With Quote
Old 05-03-2009, 07:48 PM   #8
only1agam
Member#: 56183
plus if you have a NA car, you're supposed to change them every 30k miles
only1agam is offline   Reply With Quote
Old 05-04-2009, 08:24 AM   #9
msingell
Member#: 153097
2012 CRZ
PWP
word.
Old 05-04-2009, 11:12 AM   #10
watchunglava
Member#: 168862
2007 ej253n/a 5speed
Red Sox Nation Lifer
oem ones are just ngk's . go to sparkplugs.com .
watchunglava is offline   Reply With Quote
Old 05-04-2009, 07:08 PM   #11
tenderloin
Member#: 147102
I use NGK G Power and they work great. Just a few dollars a plug.
http://www.ngksparkplugs.com/part_fi...uv/results.asp
tenderloin is offline   Reply With Quote
Old 05-04-2009, 09:29 PM   #12
07ImprezaMB
Member#: 153861
2008 WRX hatch
WR Blue
I also am looking at replacing my spark plugs and i was looking at these brisk silver racing plugs from perrin. Check them out let me know what you think and if anyone has heard or used these.
http://www.perrinperformance.com/pro...ory=4&model=19
07ImprezaMB is offline   Reply With Quote
Old 05-05-2009, 06:41 PM   #13
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
Brisk are nice plugs but usually very expensive and not necessarily a long lasting plug. you lose some durability for the higher performance. usually these plugs are used where high rpm and high coil voltage is needed, because the coil has a short time to "recharge" between firings the faster the engine speed, so these minimize the voltage drop across the plug itself, to make up for some loss in the coil. I have seen some Brisk plugs that were almost $50 each.. and perrin doesnt cut any corners when it comes to pricing.
Old 05-05-2009, 06:58 PM   #14
rivman05
Member#: 159986
1994 Acura Integra
Milano Red
has anyone researched Pulsar plugs, formerly directhits ignitions?
rivman05 is offline   Reply With Quote
Old 05-06-2009, 08:16 AM   #15
06OutbackSport
Member#: 160318
2006 Outback Sport
Same deal with mine. The old ones were way out of factory gap, between 44 and about 50 on all 4 of them. Put the new gap on my NGK standards down to 32 and haven't noticed any ill effects 8,000 miles later. I've yet to check how they're wearing, but throttle response immediately after changing them was like going from night to day.
06OutbackSport is offline   Reply With Quote
Old 05-06-2009, 01:06 PM   #16
Buck Rogers
Member#: 139234
05NA Lifted Baja MT
Brilliant Silver
I ran them for almost a year before they started breaking down. Not worth the money IMHO.
Buck Rogers is offline   Reply With Quote
Spark Plug FAQ: Read if you want spark plug information! Unabomber Service & Maintenance 708 06-22-2016 10:58 AM
Replacing Spark Plugs - What else Compliments Spark Plug replacements? FIlters? jungleman Service & Maintenance 2 02-09-2009 03:45 PM
NEED: Plug/Clip that plugs into WRX spark plug coil BeBop86 Private 'Wanted' Classifieds 16 07-16-2008 03:05 AM
Help! Sparks between distributor cap and spark plug wires! Stickee Normally Aspirated Powertrain 13 04-23-2003 11:23 AM
Ignitions, spark plugs & plug wires? scubaracer Normally Aspirated Powertrain 8 03-19-2002 04:17 AM
