Welcome to the North American Subaru Impreza Owners Club Sunday July 31, 2016
Old 04-18-2002, 04:27 PM   #1
dyswtric27
Member#: 404
2000 Audi S4
endless.night
Unhappy J&S problems
I got my Ultra Safeguard this past week and decided to install it today. I got all the wires hooked up by following Jewbaru's instructions on scoobymods.com. Once i fired up the car, the motor was shaking really hard and the idle was extremely rough. When i would push on the gas a little sometimes i would hear a pop and it would be extrememly slow to rev.
I disconnected the Ignition wires from the J&S and put them back to stock and the car works fine, just like before i started the install.
I am thinking that it is constantly retarding it and im not sure why. I had the sensitivity set all the way to the left (min), i had the first 4 pins up, just like in the instructions, and the 5th down. Now the light above the monitor jack would flash, and the light on the far right would turn on as soon as i would push the gas. I have no idea what could cause this. Any ideas?
Jason
dyswtric27 is offline   Reply With Quote
Old 04-18-2002, 06:23 PM   #2
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Are the switches on the new units set differently then the old ones? Have you tried the instructions provided with the unit to make sure?
Old 04-18-2002, 07:34 PM   #3
Graham
Member#: 11931
2001 2.5 RS Turbo
257/FMIC/T3-T04S
Isn't timing already programmed into the unit when you buy it, alon with the knock sensor?
Maybe you are retarding way too much, but at idle?
Definetly double check and make sure the switches on this unit are the same as the old one.
Graham
Graham is offline   Reply With Quote
Old 04-18-2002, 08:27 PM   #4
John at J&S
Member#: 2036
2000 Intrepid
Switches 3, 4, and 5 down. Please.
John at J&S is offline   Reply With Quote
Old 04-18-2002, 11:33 PM   #5
dyswtric27
Member#: 404
2000 Audi S4
endless.night
Yup, switches 3 and 4 were up, because thats what the instructions say. Put them down and all works well, thanks John.
Old 04-19-2002, 12:23 PM   #6
AaronB
Worst Mod Ever
Member#: 369
12 Vagon
Instructions that come with the J & S or the regular safeguard instructions that are on ScoobyMods?
As soon as I get mine I will have instructions up for the Ultra safeguard.
Regards,
Aaron
http://www.AzScooby.com
http://www.ScoobyMods.com
AaronB is offline   Reply With Quote
Old 04-19-2002, 03:06 PM   #7
dyswtric27
Member#: 404
2000 Audi S4
endless.night
The ones that come with the Safeguard. it doesn't look like they were made for the Ultra, but rather the other one. O well.
Old 04-20-2002, 12:51 PM   #8
John at J&S
Member#: 2036
2000 Intrepid
Aaron and Dr.Nick: Your units will ship on Monday.
Old 04-21-2002, 12:30 PM   #9
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
woohoo! sweet, thanks john
Old 08-09-2004, 03:08 PM   #10
ituner
Member#: 34476
88 civic
subyless for now
Is it true that the ultra safeguard Version 1 doesn't work w/ subaru's?
ituner is offline   Reply With Quote
Old 08-09-2004, 03:21 PM   #11
PHATsuby
Member#: 13617
2001 Legacy GT back
to stock is a project too
ituner, good find, as you can see i am having issues as well, and mine is a version 1. the version 1 should work if its a 2 channel, i told John i had a version 1 and he never said it wouldnt work.
the only thing i am wondering about is that i have read that the switches need to be up for 3,4 for version 1's but down on later versions, but up above john says they need to be down.
John told me up on the phone but maybe he was confused.
i'll call him this afternoon.
Ben
Old 08-13-2004, 11:28 AM   #12
Joncas
Member#: 5349
The version 1 should work just fine if it's a two channel unit but as I recall it doesn't have boost retard capability - just knock. I can't remember what the switches should be on that one (I've had a few of them) but I know you can send John an email and he's really good at getting back to people.
Joncas is offline   Reply With Quote
Old 08-13-2004, 12:41 PM   #13
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Well... is it an Ultra Safeguard, or a version 1 Safeguard?
Really, if you call J&S, John will answer any question you have without even a hesitation. He's probably one of the coolest guys I've talked to in the aftermarket domain, and smart as hell, to boot.
j&S question/problem? insanesuby Normally Aspirated with bolt-on Forced Induction Powertrain 1 01-05-2004 03:00 PM
Problems with J&S Safeguard lotusTT Normally Aspirated with bolt-on Forced Induction Powertrain 5 09-11-2003 07:00 PM
J&E Pistons.. Possible problem. DoodieHead Normally Aspirated with bolt-on Forced Induction Powertrain 17 06-25-2003 03:48 PM
J&S problem, please help TaiChih Normally Aspirated with bolt-on Forced Induction Powertrain 4 09-23-2002 12:32 PM
New J&S Version II unit vs Original J&S - spec & order info here ludespeed Normally Aspirated with bolt-on Forced Induction Powertrain 29 03-18-2002 02:16 AM
