Go Back   NASIOC > NASIOC General > Motorsports > Autocross
Old 04-26-2009, 02:33 PM   #1
penderperson
Member#: 172370
2006 STI
Default Who's running 245's on their WRX?
I just got some mounted up and they are massive. I'm wondering how you guys keep them from rubbing on the rear fenders? There's almost a 1/2" between the tire and shock, so plenty of room there.
I've only got 1.1* camber right now, so i think that will be the first step, will 1.4 be enough? I don't want to put in much more than that b/c my tire temps are very close!
The other alternative is to use a pillowball mount or group N top hat that's not camber adjustable and then use lateral links at the bottom to help pull in the wheel.
Depending on cost, I may also be able to trade for some higher offset wheels( currently 45mm on my 17x8 kosei's), but they need to be 17lbs or lighter(15.5 currently)
thanks guys,
Rob
penderperson is offline   Reply With Quote
Old 04-26-2009, 03:37 PM   #2
Patrick L
Member#: 634
2000 Impreza 2.5RS
Becasue ITS racecar
You roll your fender lips yet? How much clearance to you have between the tire and strut?
Are you going coilovers?
One thing I used to do on my GC to get a 245 Hoosiers to fix was a customized camber plate up top Maxed out. Then camber bolts to bring the camber back out to where I needed it. It gave me more clearance on the strut and I had my fenders rolled.
Patrick L is offline   Reply With Quote
Old 04-26-2009, 04:28 PM   #3
Storm
Member#: 5218
96L Most Over-
Developed Beater
The 245 will provide more grip. More grip means more roll. More roll means you can stand to use a little more rear camber. -1.4 should be enough, but you may find you need even more to keep a good balance.
Patrick L's advice above is also spot on.
Jay Storm
Old 04-26-2009, 04:46 PM   #4
digitalseance
Member#: 104400
169k mile race car
I ran 245 A6s for two years and it was a great setup. I had -3.5 in the front and -1 in the rear and it was a great setup. I never had rubbing issues anywhere nor did i have to roll fender lips, etc.
If you think 245s are massive, I just sold my 285/18s... those are massive lol
digitalseance is offline   Reply With Quote
Old 04-26-2009, 06:43 PM   #5
PitwrkzZ1
Member#: 94316
I'm running 245 RE01Rs on a 45 offset on my WRX with rolled rear fenders. No problems thus far. ROLL ZE FENDERS!
PitwrkzZ1 is offline   Reply With Quote
Old 04-26-2009, 06:59 PM   #6
mla163
Member#: 104922
2013 BRZ
I am running 245/40/17 on RPF1s - 45 offset WITHOUT rolled fenders. No rubbing unless there are people in the back and I am cornering heavy
2006 WRX
RCE blacks
D-specs
stock rear strut tops
24mm FSB 22mm RSB
~1.7* camber
mla163 is offline   Reply With Quote
Old 04-26-2009, 07:31 PM   #7
penderperson
Member#: 172370
2006 STI
So even with 1.7* you still rub sometimes? Its a very competitve STX autocross setup so i'm planning on pulling some mad G's on my new RE-11's.
I'd really like to get by without rolling the fenders if i can. I'd go with lateral links or camber bolts or widening the holes in my coilovers.
2006 WRX
RCE blacks
D-specs
24mm FSB 22mm RSB
~1.7* camber
Old 04-26-2009, 07:47 PM   #8
JavaBot
Member#: 156723
05 crp foresterX
rip 2.0i/2.5rs
Pics of 245's!
JavaBot is offline   Reply With Quote
Old 04-26-2009, 08:13 PM   #9
mla163
Member#: 104922
2013 BRZ
I only rub on the fender when I have two big guys in the back seat AND I am cornering hard. I really have to try hard to make it happen. I haven't pulled out the rubber lip that runs around the inner lip. Oh, I am also on 17x8s. Anything wider would probably rub.
edit: yes I do autocross (too much). I am using camber bolts in the rear for the camber.
Old 04-26-2009, 08:15 PM   #10
digitalseance
Member#: 104400
169k mile race car
This was my setup:
No rubbing at all.
Old 04-26-2009, 08:23 PM   #11
DJSuperSoul
Member#: 120004
2xx8 STI
grey
i ran 245 40 17 NT01's with minor rub at full lock.
DJSuperSoul is offline   Reply With Quote
Old 04-26-2009, 09:46 PM   #12
Butt Dyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 03 IS300
Same here:
245-40-17 Dunlop Z1 *specs
17x8 +45 gold RPF1s
-1.3 rear
500 lb/in springs
Vorshlag rear camber plates
Rear fenders totally OE, not rolled or massaged in any way
After spinning through the finish at Hershey I noticed that my rubber fender lip thingie was messed up on the driver's side (it was long gone on the passenger side) so I pulled it off. That was the first event on the 245 Dunlops so I'm guessing it was related.
Old 04-26-2009, 09:53 PM   #13
mla163
Member#: 104922
2013 BRZ
...so they have to be gold
Old 04-26-2009, 10:37 PM   #14
CamaroFS34
Member#: 6850
1996 Camaro Z28 1LE
& 2006 IAG WRX (ForSale!)
I ran 245/40R17s on my DS WRX on 17x7" Kazera KZ-Vs (and KZ-Ss), which have an offset of 50. I had no rubbing issues at all, and did not use a spacer. I would have to check my alignment sheet for exact specs, but I think it was about 1.8* negative camber in the rear and 1.2-1.3ish up front, just a hair of toe out all around.
I'll be bumping the size up to 295s on 17x9.5" rims with the ESP build.
Karen
CamaroFS34 is offline   Reply With Quote
Old 04-27-2009, 09:55 AM   #15
sureshot007
Member#: 142405
#716 G2 OBS
275s on my wagon.
sureshot007 is offline   Reply With Quote
Old 04-27-2009, 10:01 AM   #16
mccanixx
Member#: 60566
2005 XT 5sp, 02 WRX
01 Legacy 95 Impreza L
I ran 245 bridgestones and dunlops on mine. Never rubbed and that was with the rear lateral pushed out a .5" and 20mm spacers on the front.
The rears were rolled. I don't think it would've hit though.
KX V3's
-3.8 fr 560lb 10k
-.5 rr 672lb 12k
Sorry + 45 enkei rpf 1's
and +48 rota tq's
mccanixx is offline   Reply With Quote
Old 04-27-2009, 10:45 AM   #17
Chiketkd
Member#: 71634
In hibernation...
I ran 245/40/17 Hoosiers on my former '06 WRX that I ran in D-stock. I used stock offset wheels and had no rubbing issues when my alignment was -1.5 Front, -1.2 Rear. I ran the whiteline 27/29mm adj FSB on the car.
Chiketkd is offline   Reply With Quote
Old 04-29-2009, 01:16 PM   #18
stil2stock
Member#: 51870
06 STI
I ran 245/40/17 Hoosier A6s on my 02 sedan with no rubbing problems on my old suspension set up: AGXs and prodrive springs, cobb sway bars, ~1.5* camber. I just upgraded to BC inverted coilovers, so I may have to roll the fenders now.....don't know yet because I need to get aligned. I may just get them rolled to be safe.
stil2stock is offline   Reply With Quote
Old 04-29-2009, 05:45 PM   #19
sigurd
Member#: 128721
2002 impreza WRX
psm
245/40 re760's 1.5* front camber 0.5* rear. Bcracing coilovers.
rear fenders are rolled.
sigurd is offline   Reply With Quote
Old 04-29-2009, 08:49 PM   #20
DragNRacing
Member#: 172801
2006 WRX TR
I ran the 245 Hoosier A6 on 17x8's and never had any rubbing problems in back on my 06 WRX TR. Stock ride height.
DragNRacing is offline   Reply With Quote
Old 04-30-2009, 04:21 AM   #21
SiFuSpEc
Top Scoob 008
Member#: 77299
'05 2.5RS
#78 ST, MAXIMUM ATTACK!
245/40/17 Direzza Z1 on 17x8" +48 Only rubbed at full lock full load.. Worked just fine! Didn't roll fenders either.
SiFuSpEc is offline   Reply With Quote
Old 05-08-2009, 12:17 PM   #22
penderperson
Member#: 172370
2006 STI
Alright, thanks for all the replies! Here's the update:
Race tires-RE-11 245/40/17
Mounted on-17x8 45mm offset kosei K1TS
Current alignment 1.5* camber in the rear.
(picture is with my street tires, but rubbing is from the new race tires)
They're officially rubbing, this was race configuration with about 2 hard turns in each direction, got the exact same rubbing on each side.
Tire to shock clerance:
Comaprison of what i was running to what's on now:
-I'm going to take a couple measurements and see
what 1.7-1.9 camber will do for me and possibly try that.
-I'll look into some 48+offset wheels, that will help a tiny bit.
-I don't want to roll the fenders if at all possible, anything im' missing?
Old 05-08-2009, 12:24 PM   #23
mla163
Member#: 104922
2013 BRZ
Either:
Moar camber
Moar height
Moar offset
Or just roll the fender, it's cheaper than new wheels
Old 05-08-2009, 01:06 PM   #24
sigurd
Member#: 128721
2002 impreza WRX
psm
You gain quite a bit just removing those rubber linings on the fender. If your not rubbing much that might be all you need.
Old 05-08-2009, 02:32 PM   #25
penderperson
Member#: 172370
2006 STI
That's a good idea...i could even remove them for autox and leave them on for street.
With 1.7* camber and removing the liner, i bet i won't have any rub.
Who's running E85 in their Wrx and Sti's? wuuusaa Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 03-23-2007 08:06 PM
So who's running OSX on their PC? mexicanpizza Off-Topic 39 08-23-2005 09:49 AM
Anyone running 18's on their WRX (NOT STi) obxtoy Tire & Wheel 5 08-19-2005 05:01 PM
OK, so who's running 18x8's on their wagons? JavaBlack358 Tire & Wheel 21 07-19-2005 08:57 AM
Who's running 18's on a WRX wagon? JB1 Tire & Wheel 2 04-15-2003 12:30 PM
