Old 04-26-2009, 08:13 PM   #1
nikesb1111
Member#: 206369
1993 impreza
blue
Default gauge problems
So what kind of plug should i be looking for to go into the back of the gauge cluster? Is it just for the tach? Also the fuel gauge doesnt work and the gauges dont light up. What could be the problem? Thank you
nikesb1111 is offline   Reply With Quote
Old 04-26-2009, 08:30 PM   #2
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
If none of the dash lights are working then check for a bad fuse. If just some of the gauge lights are out then there may be some burned out bulbs. You get to them by turning those black bulb sockets. Most of the problems with fuel gauges are due to sensor problems in the tank. I would check that area first.
Old 04-26-2009, 09:08 PM   #3
nikesb1111
Member#: 206369
1993 impreza
blue
Do you know what the plug in the back is for? it looks like just a plastic hole. Not sure
boost gauge problem scoobi02 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 01-12-2002 09:08 PM
Boost gauge problem, need some help! datdudedennis Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 11-15-2001 11:01 PM
Boost Gauge Problem BurtonCR Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 06-12-2001 10:02 AM
('93-'01) Gauge problem!? MichiganRS Impreza Forum 0 05-27-2001 10:40 PM
a\f gauge problems please help fast brendon Normally Aspirated Powertrain 3 02-20-2001 10:04 AM
