Welcome to the North American Subaru Impreza Owners Club Sunday July 31, 2016
Old 04-26-2009, 09:50 PM   #1
Blamecanada999
Member#: 142774
2007 Impreza 2.5i
Default Does This Look Normal To You?
See that red spot right there...
So I bought a set of Borla UEL's off of Boxer4Racing (good turnaround, would recommend). First off, being a welder myself, let me say that I'm not too impressed with Borla's craftsmanship. Porosity, craters, rollover....
I'm sure those guys have a large number of exhausts to weld in any given shift, but at least clean the spatter up.
That's not what this thread is about though. My question is about where the tubing is welded to the outside face of the flange. Or rather, the lack of weld. It's only held together with small tacks on that side.
Now, I don't have any experience in fabricating exhausts myself; but in all of the other headers I've seen, there's a full bead run around that joint to seal it. Is this standard practice, or there a reason they only left it tacked? The only reason I can see for doing this would be to prevent cracking during thermal expansion. I know the early Borlas were prone to this. Would running a bead around the tubing increase the chances of cracking? Am I better off just leaving well enough alone?
Blamecanada999 is offline   Reply With Quote
Old 04-26-2009, 10:21 PM   #2
smithrcing17
Member#: 193195
2005 Ty Tuned 2.5RS
i have the borla reps and mine are tacked the same way like that.. mine has like 4 though but im not sure why they are done like this, but they dont leak so i guess its all good haha
smithrcing17 is offline   Reply With Quote
Old 04-26-2009, 11:33 PM   #3
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
there should be a full bead around the ID inside the flange. My TWE's are similar, as in they are just tacked around the OD under the flange, but they dont look like a 2nd grader on meth welded them. I think they just tack them to hold everything together then they can take them out of the jig and run a bead around the inside much easier. There is a thread that addresses exactly this, i read it a few weeks ago, and everyone else who has any headers said they had similar construction. a call to borla would clear this up in a couple minutes, too. good luck.
Old 04-26-2009, 11:54 PM   #4
jamal
Member#: 71875
98 Legacy GT
my wheels fit
yeah I was pretty disgusted by the borla's I handled. You'd expect some quality out of a name brand, especially at the price.
And it's not just the n/a headers. WRX parts are just as bad. Those collectors are junky too.
jamal is offline   Reply With Quote
Old 04-27-2009, 09:15 AM   #5
polish steve
Member#: 193861
2006 impreza 2.5i sd
obp
looks like they fired the welders before they could finish.
polish steve is offline   Reply With Quote
Old 04-27-2009, 06:32 PM   #6
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
Yeah, those collectors are pure trash.
Old 04-28-2009, 04:10 PM   #7
WcW
Member#: 209963
People with Turbo engines should be very careful about any slag or bits of metal in their headers. When in doubt, grind it out. Also not a bad plan to run a sock on a string through the hidden parts of the manifold to try to detect any hidden crap. If the sock hangs up you should investigate. When a weld "drops through" a big drip of slag can form and then chip off destroying your turbo. **** happens. If you saved a lot of money, put in the due diligence inspecting the product before you install it. pressure or solvent testing the welds is not an excessive measure on crudely produced products.
WcW is offline   Reply With Quote
Old 04-28-2009, 04:40 PM   #8
GEE-OTTO
Member#: 201277
2009 Legacy GT
The cheapest ive seen the Borla brand headers for are like $350 NEW plus shipping. i am always searching for a header for my 08 2.5i but i dont want to spend money ad get that ill just wait till a one of you all gets tired of the header and want to sell it hahahaha that way i know its been tested well
GEE-OTTO is offline   Reply With Quote
Old 04-29-2009, 03:08 AM   #9
pobre
Member#: 84358
2001 Impreza RS 2Dr
well at least they come with million mile warranty...
pobre is offline   Reply With Quote
Old 04-29-2009, 08:29 AM   #10
GEE-OTTO
Member#: 201277
2009 Legacy GT
yeah and to ship them back for a replacement will take about 10K miles in car time speak
Does this look normal to you? jpsimon Vendor Reviews 11 09-24-2009 10:24 AM
Does this look sketchy to you? rjrutzky Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 07-27-2005 11:45 AM
Does this look right to you? Jitenshakun Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 15 12-19-2004 08:12 PM
uhm.. What does this look like to you? *lmao* Sauceboy01 Off-Topic 19 07-09-2004 01:40 AM
Does this look ricey to you? AWDball Member's Car Gallery 83 02-20-2003 06:39 PM
