Welcome to the North American Subaru Impreza Owners Club Monday December 5, 2016
Old 04-10-2014, 05:38 PM   #1
dirtcollector
Member#: 357347
2005 wrx sti
aspen white
Default Question regarding the DAM after ecu reset
Hey guys I was doing some maintenance on my vehicle (05 sti) and disconnected my battery prior to me working on it which of course reset my ecu and put it in learn mode. So... when the value in the DAM column goes back to 1 does this mean my car is back to normal so to speak and has regained full power or am I way off here. Right now my DAM is at 0.6 and I am seeing positive corrections in the fine knock learning from 0.3 to 1.4 while cruising. Is this normal after an ecu reset? Can someone shed some light on this for me. Thanks!
dirtcollector is offline   Reply With Quote
Old 04-11-2014, 08:19 AM   #2
DeviAnt985
Member#: 374488
2014 WRX Hatch
Dark Gray
Don't take this as me offending you but have you watched this video yet? It explains a little bit of what you're asking about. Just trying to help any way I can without my personal input and/or lack of knowledge on the subject, as I am learning as well
http://youtu.be/rjEGZ-4dsDY
DeviAnt985 is offline   Reply With Quote
Old 04-11-2014, 08:25 AM   #3
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
it depends on how the tune was made.
for example, the tuner may have decided that with full ignition advance (DAM=1) there should still be some knock margin left on the table. this will create a situation in which given repeatable octane the car never knocks. however, it also means that the ecu will not attempt to increase advance and net additional torque.
the tuner may have also decided to rely on the knock detection and ignition learning to pull back timing a little bit during average octane/driving. this is how FHI sets up the maps, so it is a perfectly viable method. it DOES mean that the ecu will continually attempt to push the timing back up and will do so until knock is detected. that knock will show up as DAM<1, and may show some fine learning corrections, either positive or negative. the advantage here is that you know you're pretty much running the maximum timing advance (iow, torque) for a given set of conditions.
Old 04-11-2014, 10:10 AM   #4
dirtcollector
Member#: 357347
2005 wrx sti
aspen white
Double post..
Old 04-11-2014, 10:12 AM   #5
dirtcollector
Member#: 357347
2005 wrx sti
aspen white
Thanks ride5000 good info! That clears things up for me!
