Old 05-17-2009, 02:55 AM   #26
Mr.ShenaniGaNs
Member#: 153498
2002 ImpreZa WRX
Championship BLUE!
heh..yah the dongle does get in the way sometimes. i thought about routing the wire where the turbo timer wire goes and just pull it through underneath.
Mr.ShenaniGaNs is offline   Reply With Quote
Old 05-17-2009, 02:57 AM   #27
boostin23
Member#: 204172
---- 05 STi
mine sits in my cupholder
boostin23 is offline   Reply With Quote
Old 05-19-2009, 10:15 PM   #28
adamlavender
Member#: 144938
30R'd wrb
My car is in the shop, but I bought an adhesive "cell phone magnet" set about the size of a quarter, and mounted it just to the left of the left center vent. No vent obstruction. Not only does the AP stay put regardless of "driving conditions", but it can easily be pulled off and closer when stopped and scrolling through maps, etc. (Assuming the relocation and routing of the cable allows some movement.) Looks clean and is easily removed/stored. After two years, no screen discoloring or other noticeable negative affects from magnet.
adamlavender is offline   Reply With Quote
Old 05-20-2009, 11:00 AM   #29
Drake13
Member#: 153927
2004 STI
WRB TBE, TiaL 44mm EWG
I still haven't had the time to mount my AP to my car and everyones input has been awesome on here. The only problem I still face is the constant connection making the AP stay on while the car is turned off... so here is my proposed solution.
or
Yes.. i'm feeling creative and going to figure out how to mount a USB to a toggle switch. Just so I don't mess up the AP's orignal wiring i'm going to buy a USB port sharing switch then some extra wiring. If all goes well, should look freaking awesome... Mount location will probably be the empty spot by the DCCD Auto/Manual button on my center console, should look cool.
EDIT: This should be easier then I thought. Here is a diagram of the USB layout.
Pin Name Color Notes
1 VBUS Red Power
2 D- White Data -
3 D+ Green Data +
4 GND Black Ground
input?
Drake13 is offline   Reply With Quote
Old 05-20-2009, 11:04 AM   #30
UFOpilot
Member#: 189525
2007 WRX Wagon
Invisible Plain
At an event, it's in the toolbox. Otherwise it is at home on a shelf.
UFOpilot is offline   Reply With Quote
Old 05-20-2009, 01:24 PM   #31
Drake13
Member#: 153927
2004 STI
Question to those who have thier AP's mounted on the vent. During the winter when you have your heater blasting, how does the AP hold up to the heat blowing continuously on it?
Old 05-20-2009, 09:13 PM   #32
2.5 turbo hyped
Member#: 158810
2005 STI and Baja
or
1 VBUS Red Power
2 D- White Data -
3 D+ Green Data +
4 GND Black Ground
input?
Run the red wire in the usb through your switch or through an automotive relay, either will work.
Don't worry about messing up the usb cable, they can be had on ebay for less than 5 bucks shipped. It is a very common usb cord.
2.5 turbo hyped is offline   Reply With Quote
Old 06-10-2009, 07:20 PM   #33
nme187
Member#: 117763
nme187 is offline   Reply With Quote
Old 06-10-2009, 07:52 PM   #34
sputsxt
Member#: 209173
2012 4Door STI
Wink
That is one sweet set up..........
sputsxt is offline   Reply With Quote
Old 06-10-2009, 08:09 PM   #35
El Capitan
Member#: 121261
06 STG 2+ STi
CGM
El Capitan is offline   Reply With Quote
Old 06-24-2009, 08:43 PM   #36
rallyracersti
Member#: 147522
2015 wrx
Wrb
that is so badass. looks like a p.i.n.a. to mount it where the clock is. tight though
rallyracersti is offline   Reply With Quote
Old 06-25-2009, 12:00 AM   #37
GLD247
Member#: 207789
2003 WRX EJ257 Swap
velcroed it to the silver strip next to the cup holder, to the right of the steering wheel under the vent.
GLD247 is offline   Reply With Quote
Old 06-25-2009, 08:17 AM   #38
Suby Noob
Member#: 60890
1994 Toyota Pick-Up
2009 DGM WRX Sedan
Originally Posted by El Capitan View Post
ok.... what does the switch do
Suby Noob is offline   Reply With Quote
Old 06-25-2009, 09:07 AM   #39
ragejed
Member#: 76817
2005 WRX
In my closet...
ragejed is offline   Reply With Quote
Old 06-25-2009, 09:59 AM   #40
El Capitan
Member#: 121261
06 STG 2+ STi
CGM
Warp Drive
Seriously though, it puts the ECU into test mode. I put the green wires on a switch so I didn't have to reach up under the knee bolster each time I needed to flash a base map... which isn't often.
Old 06-25-2009, 10:18 AM   #41
rexspeedworthy
Member#: 26965
2013 XV crosstrek
Originally Posted by beedee View Post
i have that same exact type-s universal phone/mp3 holding device in my 08. i used the double sided tape to mount it between my two vents. it sits low enough to where i can still see and use all stereo functions.
i dont use my AP all the time, only once in awhile. for example when i first got it i used it here and there for a couple days. then when i went stage 2, same deal. the nice thing about the Type S holder thing is it kind of matches the interior of my 08 so it doesnt look too out of place. it holds my samsung blackjack just fine as well. the wire from the dongle to the AP can be a tad annoying, but just be careful with your feet/legs when driving and you will be fine. btw, i NEVER exit my car without my AP.
There is a screw that holds where you plug in the huge dongle. Remove it, and your can swing the dongle up, and it will hold in there by the plastic. Run wire through dash and out air vent for stealthyness.
rexspeedworthy is offline   Reply With Quote
Old 06-25-2009, 08:26 PM   #42
SnailShell
Member#: 215238
2005 STi
Well this might not be much help but I saw one of those gauge pods that mount in the glovebox that had space for 3 gauges a turbo timer then like a cell phone mount that an accessport would fit into but i cant find the website now. Im pretty sure its just one of those adhesive backed holders though..... Just an idea
SnailShell is offline   Reply With Quote
Old 06-25-2009, 08:29 PM   #43
Suby Noob
Member#: 60890
1994 Toyota Pick-Up
2009 DGM WRX Sedan
Warp Drive
That is cool as hell. I love this forum, so many creative people on here. Nice stuff... but yea, stick with telling people its warp drive. haha.
Old 07-09-2009, 03:36 PM   #44
beevnessmonster
Member#: 146254
2007 Wrx
crystal grey metallic
[IMG]http://i115.photobucket.com/albums/n317/stcroixrp/STi/APv2/IMG_1517.jpg[/MG]
[IMG]http://i115.photobucket.com/albums/n317/stcroixrp/STi/APv2/IMG_1528.jpg[IMG][IMG]http://i115.photobucket.com/albums/n317/stcroixrp/STi/APv2/IMG_1529.jpg[IMG]
Here is how I mounted it.
How do you get the "analog" style gauge face?
beevnessmonster is offline   Reply With Quote
Old 07-13-2009, 07:05 PM   #45
Leadfinger
Member#: 201850
Leadfinger is offline   Reply With Quote
Old 07-13-2009, 07:10 PM   #46
Leadfinger
Member#: 201850
Originally Posted by nme187 View Post
VVN!!! I can tell that took some time to get it right.
Old 07-16-2009, 05:56 PM   #47
bdj238
Member#: 207561
2005 WRB WRX WAGON
PPG Trans
I got my AP mounted it and looking good. Decided to follow suit and installed a switch on my usb so I would have to constantly unplug and replug in the AP. Took my time and soldered up all my connections, works like a champ. Thanks for everyone who posted on this for the ideas!
bdj238 is offline   Reply With Quote
Old 07-19-2009, 05:34 PM   #48
Subiebobby
Member#: 181046
2002 wrx wagon
psm aps s/r55, meth 6 spd
here's mine
Subiebobby is offline   Reply With Quote
Old 07-19-2009, 08:23 PM   #49
Suby Noob
Member#: 60890
1994 Toyota Pick-Up
2009 DGM WRX Sedan
Originally Posted by Subiebobby View Post
here's mine
-Picture-
That is pretty slick, double sided tape? The contour looks like it fits perfectly there.
Old 07-19-2009, 08:47 PM   #50
rexspeedworthy
Member#: 26965
2013 XV crosstrek
Post your LOCATION please... Longitude Private 'For Sale' Classifieds 16 03-17-2006 03:39 PM
Picture Request. Your Ps2 mounting Location Crump Member's Car Gallery 19 04-13-2005 06:47 PM
Can you sellers please post your location in the subject line pha qed Private 'For Sale' Classifieds 14 06-02-2004 03:39 AM
New antenna location pic, post your pics too IA Performance Interior & Exterior Modification 0 08-22-2003 11:42 PM
