Old 07-19-2009, 10:30 PM   #51
metroscub
Member#: 121273
06 WRX TR
Superblack Gold Micapearl
I like all of these locations! especially the ones on the windshields, however, I am about to relocate mine to ebay.
metroscub is offline   Reply With Quote
Old 08-06-2009, 12:56 PM   #52
resisTm3
Member#: 115435
2005 sti
Aspen
post up some more locations for 08/09 wrx/sti
resisTm3 is offline   Reply With Quote
Old 08-16-2009, 01:13 PM   #53
down_for_the_scooby
Member#: 78314
04 PSM WRX
Audi mask the right way
Originally Posted by El Capitan View Post
Warp Drive
Seriously though, it puts the ECU into test mode. I put the green wires on a switch so I didn't have to reach up under the knee bolster each time I needed to flash a base map... which isn't often.
So the wires are constantly hooked up and the switch acts like a resistor?
down_for_the_scooby is offline   Reply With Quote
Old 08-18-2009, 09:38 PM   #54
down_for_the_scooby
Member#: 78314
04 PSM WRX
Can someone tell me how to get the **** obd plug unplugged so it can be put behind the dash piece allowing me to drive without fear of disconnecting the accessport?
Old 08-20-2009, 01:01 AM   #55
racer580
Member#: 202667
2007 STi
OBP on Gold
I had to put a lot of force to get the plug off. That, and a flat blade and it eventually popped out. Thought I was going to break it but it worked out ok.
Oh and heres where I mounted mine. Made the bracket custom
And heres a pic of the back where I double stick taped a slider piece.
And from the driver seat:
You would think that the wiper button stick would get the way, but it really doesn't. I really like the location because its seriously right there and so you don't have to look too far away to the side to check. I usually have it on the boost gauge or something and it all works out.
*update*
Since a few of you guys have asked me about mine, here are a few closer pictures of the mount itself. I found it lying around my house out in the garage, but Im sure you can pick one up at a local hardware store. Sorry for the ****ty cell phone camera quality in advance
Last edited by racer580; 05-06-2010 at 09:08 PM. Reason: new pictures of the mount
racer580 is offline   Reply With Quote
Old 08-21-2009, 01:25 AM   #56
get'erdone
Member#: 67200
2004 WRX
TiC Tok'd evoIII
Version 1, under my seat!!! Mount? Who needs a steenking mount?
get'erdone is offline   Reply With Quote
Old 02-14-2010, 06:52 PM   #57
CGM_SCOOBY
Member#: 129314
2003 EVO VIII
2012 Veloster
Back from the dead...picked up this holder today from Autozone for $8....now waiting for my Accessport and turboback to come in
CGM_SCOOBY is offline   Reply With Quote
Old 02-14-2010, 11:13 PM   #58
ProdriveDreams
Member#: 146819
'02 WRB VF-39'd WRX
W/06 STi Drivetrain swap
... no... the switch in a suprising turn of events..... works like... a switch... not a resistor. Hence no, the wires are not connected all the time.
ProdriveDreams is offline   Reply With Quote
Old 02-14-2010, 11:49 PM   #59
ProdriveDreams
Member#: 146819
'02 WRB VF-39'd WRX
Originally Posted by wrxdrvr View Post
You shouldn't have to re-locate the OBD2 plug, the plug in wire should have the wire coming out of it sideways so it doesn't hang down...
You can buy a right angle plug that will get you closer to this scenario...
http://www.usbfirewire.com/ucablecam5b.html
I'm gonna buy one cause I don't want to move my OBD plug as I also use a tactrix.
Also considering an OBD extension and then stuffing the dongle in the dash... but my dash is getting pretty full these days with aftermarket DCCD controllers, heated seats, preliminary wiring for possible Mac Mini Mobile, and other various goodies...
Just thoughts.
edit:
After a few minutes of looking this looks like the best option
That way I can remount one of the Y's and still have my regular OBD plug, and have the AP connected hidden int he dash... weeeeeeeeee!
Old 02-20-2010, 01:12 AM   #60
Sandhawk
Member#: 223863
2004 STi
Ordered the above Y cable ^. Thanks for the idea! Installing tomorrow
Sandhawk is offline   Reply With Quote
Old 02-20-2010, 11:22 AM   #61
Nickarub
Member#: 230509
06 vf39 wrx
ugm
subscribed
Nickarub is offline   Reply With Quote
Old 03-05-2010, 12:36 PM   #62
bpcrally
Member#: 208408
2004 WRX Wagon
so the OBD plug isnt screwed in/clipped in? i tried pulling mine out and not so much as a wiggle.. am i missing something?
bpcrally is offline   Reply With Quote
Old 03-05-2010, 12:48 PM   #63
2.5 turbo hyped
Member#: 158810
2005 STI and Baja
It is clipped in. A small flat tip screwdriver is your friend for depressing the clip actuator on one of these bad boys.
2.5 turbo hyped is offline   Reply With Quote
Old 03-05-2010, 12:55 PM   #64
bpcrally
Member#: 208408
2004 WRX Wagon
so its just one clip? where it is located? towards the front of the car? and im assuming its all on the underside of the dash.. its pretty difficult to crawl in there lol
Old 03-05-2010, 01:17 PM   #65
USAFwrx05
Member#: 239614
2016 WRX
i keep mine in my closet. but after seeing this, i may have to find a place in my car. im going to look at doing the clock mount with the buttons near the ash tray
USAFwrx05 is offline   Reply With Quote
Old 03-05-2010, 04:04 PM   #66
2.5 turbo hyped
Member#: 158810
2005 STI and Baja
Get under there with a flashlight and check it out. Any good technician, such as yourself, will figure it out with a little bit of investigating.
Old 03-05-2010, 07:16 PM   #67
tolnep
Member#: 18602
2005 Moller Skycar
glow in dark purple
HAR!
i keep mine at home.. or if im using in my car and get out.. in my pocket it goes..
crackheads will steal it thinking is some sort of nintendo game, or cell phone or who knows...
once stolen you's gotta buy a whole new unit so i understand. and if you switch maps with it.. say from e85 to 93 (as i do) then you are outta luck...
also unless you use one of the extension mountings for the odbII port or push it up inside the dash.. its not impossible you will break the dongle.. or worse.. break the subaru odbII port itself you i understand is expensive to repair..
tolnep is offline   Reply With Quote
Old 03-06-2010, 08:45 PM   #68
BrianMR2
Member#: 238679
2007 WRX TR
Nice job mounting guys, cannot wait to get mine should be here wend. I need 2 more posts to make a new topic as well so +1.
BrianMR2 is offline   Reply With Quote
Old 04-07-2010, 10:32 AM   #69
Xawn
Member#: 214441
2012 STi
Wow! Not a single person used the Backetron hard mount? I'll have to get a picture to show off. I didn't know people were using all kinds of crazy things.
First you buy this: (http://www.bracketron.com/index.php?...catid=2&pid=11)
Then you buy this: (http://www.bracketron.com/index.php?catid=5&pid=40)
I found both for cheaper at Advance Auto and on Amazon. It might not look like it in the picture, but that second one squeezes down to the size of the AP and holds it very firmly with room for the USB cable.
So you take the holder form the second link and it mounts directly on the bracket from the first link. It looks almost factory! Pics to come later tonight. My dash is in pieces. I'm installing a switch for a remote mounted radar detector.
Xawn is offline   Reply With Quote
Old 04-09-2010, 12:05 PM   #70
Xawn
Member#: 214441
2012 STi
Bump with picture of the Brackettron mount:
Old 07-02-2010, 02:35 AM   #71
tyscat
Member#: 196438
2006 STI
Crystal Gray Metallic
I really like your setup but the links aren't directing to the actual bracket / holder. I'm wondering what bracket you actually use (I can't figure it out from your pictures). Any help?
tyscat is offline   Reply With Quote
Old 07-04-2010, 01:25 PM   #72
Blue_Rex
Member#: 236954
2010 WRX Base
Where are you guys hiding the coiled up extra wire? and what is the easiest way to route into the vent on the driver's left without pulling the dash apart?
________
Medical marijana dispenserys
Blue_Rex is offline   Reply With Quote
Old 06-08-2011, 07:28 PM   #73
rimuladas
Member#: 76561
2005 WRX STI STG 2
WRB /gold
rimuladas is offline   Reply With Quote
Old 06-09-2011, 11:26 AM   #74
olazy
Member#: 263322
2011 WRX Limited
WRBP
using
olazy is offline   Reply With Quote
Old 06-27-2011, 12:25 AM   #75
lykemeyet
Member#: 283890
2002 impreza
Default location
Here's my location. spliced the wires under the dash to two switches. easy tune!
lykemeyet is offline   Reply With Quote
Post your LOCATION please... Longitude Private 'For Sale' Classifieds 16 03-17-2006 04:39 PM
Picture Request. Your Ps2 mounting Location Crump Member's Car Gallery 19 04-13-2005 07:47 PM
Can you sellers please post your location in the subject line pha qed Private 'For Sale' Classifieds 14 06-02-2004 04:39 AM
New antenna location pic, post your pics too IA Performance Interior & Exterior Modification 0 08-23-2003 12:42 AM
