Old 04-27-2009, 01:22 PM   #1
STizzIE
Member#: 189562
2011 STi Limited
Obsidian Black Pearl
Default Car keeps cutting out/stalling help?
So I have this 94 Legacy turbo that some of you might have seen for sale on here recently. Anyways the guy I bought it from thought there might be a leak on one of the y pipe connections so I took off the BPV then intercooler tightened all the connections and put it all back together. Now when I give it gas the car dies and now Check Engine is on. (all electrical still works but car dies) I went back through and re looked to make sure I connected everything. It appears I did. Anyone have any ideas? they would be greatly appreciated!
thanks!
STizzIE is offline   Reply With Quote
Old 04-27-2009, 01:23 PM   #2
JasonLHall
Member#: 111318
can you determine what CEL is causing the check engine light?
JasonLHall is offline   Reply With Quote
Old 04-27-2009, 01:25 PM   #3
STizzIE
Member#: 189562
2011 STi Limited
unfortunately I dont have access to a code reader
Old 04-27-2009, 01:29 PM   #4
driftorgrip
Member#: 172188
SOUNDS like your airflow meter is unplugged, bad, or got a bunch of crap on the sensor wire.....
GET A CODE READER!....there only like 60 bucks off the mac tools truck (basic no frills code reader)
driftorgrip is offline   Reply With Quote
Old 04-27-2009, 01:33 PM   #5
lancelucas
Member#: 124282
04 WRX Wagon PSM
13 STI Sedan SWP
Sure, for an OBD-II scanner...
lancelucas is offline   Reply With Quote
Old 04-27-2009, 01:55 PM   #6
STizzIE
Member#: 189562
2011 STi Limited
now its doing it even without actually hitting the gas...just ridiculous idle...then dies
Old 04-27-2009, 02:01 PM   #7
Black07STiGuy
Member#: 155930
2008 WRX Josh Tuned
VF39+JoshTune=330hp/350tq
defiantly an after maf air leak. my 08 was doing that and the very bottom of where the top mount goes into the intake manifold wasn't on all the way and it took me forever to figure it out.
Black07STiGuy is offline   Reply With Quote
Old 04-27-2009, 02:15 PM   #8
jma_1000
Member#: 151694
what youre describing sounds exactly how a disconnected bpv or other major air leak. Black07STiGuy has a good idea - check your intake connector thing, and your bpv gasket. maybe it got squished weird.
jma_1000 is offline   Reply With Quote
Old 04-27-2009, 02:19 PM   #9
Black07STiGuy
Member#: 155930
2008 WRX Josh Tuned
my car still ran for the most part (like crap) when mine was doing this and everytime i hit boost my car would actually slow down because all that pressure was leaking out of that intake manifold gasket connector thing.
Old 04-27-2009, 02:22 PM   #10
STizzIE
Member#: 189562
2011 STi Limited
maybe i will just disconnect everything again and re connect it all
Old 04-27-2009, 02:27 PM   #11
seventhsign
Member#: 123305
1999 E36 M3
Cocaine Cowboy
check for cracks in piping/coupling for the intercooler. a decent noticeable sized crack/boost leak would cause the motor to just crank/start then die. a small leak would cause symptoms that you described. this should be your first thing to do.
if anything is found doing this and problem is fixed then alright!
if not... borrow a compatible MAF sensor off a friends car. my car had a bad MAF but didn't pull CEL's regularly.
check to see if this could be your next problem but be careful with this as MAF's from Subaru are generally 200-240 bucks! if yours doesnt work and your buddies good runnin MAF fixes the problem you will need to replace this
a cheap temporary fix would be MAF aerosol cleaner, but i do not recommend it if this is the case.
then thirdly, i would check for spark. maybe fouled plugs or cracked ceramic housing? these can lead to misfire causing your car to run CEL and in "limp" mode causing sputtering/back firing / rough idle / etc.
the OBD scanner can help you greatly, but if you don't have access to that, try some of those out!
hope this helps and hope you figure it out.
-Nick.
seventhsign is offline   Reply With Quote
Old 04-27-2009, 03:40 PM   #12
subi_360
Member#: 204889
im the guy you bought it from. sorry to here this, glad you tightened down the y-pipe. i might be a vacuum hoes thats lose or something. if nothing works might want to try to put that v4 tmic back on and see if that works. but i dont know why the check engine light is on. so it wont idle at all?
subi_360 is offline   Reply With Quote
Old 04-27-2009, 07:52 PM   #13
azn0boi04
Member#: 164172
97 OBS EJ20G ZILLA
87 GL
wel... i have a Ej20G u can swap in there... full swap. motor/tranny/ECU...
azn0boi04 is offline   Reply With Quote
Old 04-28-2009, 02:28 AM   #14
STizzIE
Member#: 189562
2011 STi Limited
Dude that skinny TMIC barely fits I cant imagine how I would get that V4 in there
Old 04-28-2009, 11:30 AM   #15
Tizzle
Member#: 44472
Ver2 Legacy StiRA
88 RX, 87 RX, 07 FXT
I'm having similar problems with my legacy. I haven't checked everything yet, but things I am going to check for are: Bad MAF, IAC valve leak or cracked air hose, then check spark plugs/coils.
Tizzle is offline   Reply With Quote
Old 04-28-2009, 12:48 PM   #16
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
Are you familiar with pressurizing the intake and spraying soapy water on the joints to find the leak?
Old 04-28-2009, 06:40 PM   #17
DSM_Outback
Member#: 56345
93 Swapped L
Green
Intake leak test it and check your engine grounds.
DSM_Outback is offline   Reply With Quote
car keeps cutting out and bogging nikesb1111 Service & Maintenance 10 12-02-2009 08:22 PM
Help! 05 RS Keeps Cutting Out!! 05subylah Normally Aspirated Powertrain 12 06-07-2007 06:51 PM
92 Legacy turbo cuts out, stalls, hesitates etc. turbodrive Pre-2002 Factory Turbo Powertrain 102 04-30-2006 07:04 AM
Amp keeps cutting out, fades back in DeusExMachina Car Audio, Video & Security 2 08-26-2003 12:41 AM
Car is cutting out, sometime stalling smokey Warranty Issues & SOA Problems 6 06-13-2002 05:45 PM
