Old 04-18-2002, 08:13 PM   #1
racerwad
Member#: 2564
Question waste gate question
i just picked up an IHI turbo from a junkyard and it comes with an integral wastegate. i want to get a remote wastegate, ala tial or deltagate. in order to disable the integral wastegate, all i need to do is remove the actuator, or simply not hook it up to any boost source, right?
also, how can i tell which are the oil supply/drain lines and which are the water supply/drain lines? thanks.
andy
racerwad is offline   Reply With Quote
Old 04-18-2002, 08:57 PM   #2
STiTuner
Member#: 5778
09 135i
Jet Black
If you remove the wastegate you have to weld the door shut. but you can bypass it by just not letting the vacum lines run to it.
Brad
STiTuner is offline   Reply With Quote
Old 04-18-2002, 09:02 PM   #3
blaster88
Member#: 1109
1999 Suzuki Samurai
Blackish
Oil lines come in the top and exit straight down out of the bottom.
Water lines are on the side. Doesn't matter which way the water goes.
blaster88 is offline   Reply With Quote
Old 04-18-2002, 09:16 PM   #4
racerwad
Member#: 2564
could i simply bypass the valve altogether and forget about it?
also, i know that the oil goes top to bottom; the thing is, this is in the context of its installation, and that depends on the application. how can i tell by look at the inlets/outlets? i'm fairly certain i know which are which. i guess i could take it all apart and try and figure it out that way. thanks for the help guys.
andy
Old 04-18-2002, 10:47 PM   #5
Legacy GTR
Member#: 9316
1997 Legacy GT
[email protected]
for mine oil inlet you have to bolt the oil line. For the outlet, there is a flange (for lack of a better term) that you would attach the oil drain line to (like you would a water line).
For the wastegate, I would just not plug it into anything. If you put a cap over the end, won't it (by itself at leased) make as much boost as the turbo can?
Mike
Legacy GTR is offline   Reply With Quote
WRX Internal Wastegate question... OKRS25 Normally Aspirated with bolt-on Forced Induction Powertrain 3 08-07-2003 09:40 AM
Downpipe/Wastegate Question Egan Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 01-16-2003 03:27 PM
WRX Turbo Internal Wastegate Question seven881 Normally Aspirated with bolt-on Forced Induction Powertrain 12 08-29-2002 12:56 AM
Turbo and Wastegate question yebokmj Normally Aspirated with bolt-on Forced Induction Powertrain 5 10-28-2001 01:28 AM
Blow off valve and wastegate question 2.5GT Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 06-06-2001 04:58 AM
