Welcome to the North American Subaru Impreza Owners Club Sunday February 7, 2016
Old 04-28-2009, 01:12 AM   #1
oversteer
Member#: 14923
2007 Subaru turbo
Default STI piston installation. How long?
How many hours should a good mechanic charge to install new forged pistons in a 2.5L STI engine? Assuming the engine doesn't need to be dropped are there any other parts that make sense to upgrade "while you are in there"?
oversteer is offline   Reply With Quote
Old 04-28-2009, 02:01 AM   #2
godfather2112
Papi Chulo
Member#: 53794
Cams, turbo there is alot of stuff to upgrade.
godfather2112 is offline   Reply With Quote
Old 04-28-2009, 02:05 AM   #3
Scooby-King
Member#: 180499
2007 SRT8-Cherokee
2008 Sierra Denali
wow . . . . Just wow . . .
Scooby-King is offline   Reply With Quote
Old 04-28-2009, 03:30 AM   #4
neat-0-wrx
Member#: 175975
the join date, and the questions, they do not compute
neat-0-wrx is offline   Reply With Quote
Old 04-28-2009, 10:10 AM   #5
oversteer
Member#: 14923
2007 Subaru turbo
Hence the Newbie posting forum. Forget the "other" stuff since the question was obviously too general. I was referring to items such as improved rod bolts, oil pump, upgraded timing belt, etc.
How many shop hours to install new pistons in a 2.5L turbo engine?
Old 04-28-2009, 10:33 AM   #6
Fetteichhornchen
Member#: 105689
2009 STI Hatch
call LOCAL shops and get and estimate. Market varies from place to place and each shop is gonna tell you something different. You also don't have a location in your profile so no one can estimate for you based on proximity.
I had a block swap done in early 06 in Florida... PM if you want details. And in response to the while you're in there, you could do everything! list a budget or goal before you make a generic question like that or people will tear you apart. My wish list includes over 10K of work that COULD be done if my motor were ripped apart.
Lance
Fetteichhornchen is offline   Reply With Quote
Old 04-28-2009, 01:43 PM   #7
Defiant Autospeed
Vendor
Member#: 155450
2007 FXT
The engine has to come out of the car to do pistons. There is no way around it. Not possible to do it inside the car in any way shape or form.
Defiant Autospeed is offline   Reply With Quote
Old 04-28-2009, 02:29 PM   #8
djosbun
Member#: 202176
2004 WRX wgn P1RANHA
'07 Tribeca
If he's a good mechanic, he'll hone the cylinders so the piston rings will seal (along with purchasing new rings). He'll also replace the rod bearings. Both aren't expensive but the motor must come out. To hone the cylinders, the heads are going to come off, so take into account a full engine disassembly (and reassembly).
Dave
djosbun is offline   Reply With Quote
Old 04-28-2009, 03:53 PM   #9
Speedette
Member#: 104272
ClubWRX Ambassador
Dave
What?! There is no need for machining a block to make cylinders fit well....
And there is no need to replace bearings either unless he plans on taking his engine into even higher RPMs.
Speedette is offline   Reply With Quote
Old 04-28-2009, 03:55 PM   #10
Speedette
Member#: 104272
ClubWRX Ambassador
Wow man, you have awesome deduction skills. Perhaps the STI engine doesn't need to be dropped because it hasn't been put in his non-STI Subaru yet?
Old 04-28-2009, 04:42 PM   #11
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
You're going to want a fresh build with honing and such. While in there you're going to want to do nicer bearings as well.
To give you an idea it takes us about 5 hours from putting the car in the bay to having the engine torn down to the bearings.
With hone and measurements and assembly - well that depends on what you're doing.
engine install, fill and test is going to be another 3 hours for us.
Old 04-28-2009, 04:59 PM   #12
djosbun
Member#: 202176
'07 Tribeca
Do you know how to read?? Where did I state "machining a block to make cylinders fit well?" If you want to give the piston rings a fighter's chance to seal well, you'll want to hone the cylinders. And what idiot wouldn't replace the rod bearings since you're in there already?? It has nothing to do with rpms............sheesh!
Old 04-28-2009, 06:24 PM   #13
vrusso
Member#: 207074
2015 STI
You know you're jealous
What ever you do don't take it to this guy to have the work done.
I would second calling around to any local shops. Ask around your area for any reputable mechanics for after market installs.
vrusso is offline   Reply With Quote
Old 04-28-2009, 06:55 PM   #14
Turn in Concepts
Member#: 93646
Many Track Records
OP - where are you located?
Spring install instale, how long? 06 wrx Newbies & FAQs 11 10-10-2008 10:34 AM
How long does it take to install Springs on a STi? zigger Brakes, Steering & Suspension 3 11-01-2005 01:02 AM
04 STi Pink Install How to and Review RoninSTI Brakes, Steering & Suspension 47 10-06-2004 12:25 AM
EJ22 w/ 112k has piston slap. How long will it last? ws6fiero Legacy Forum 4 11-18-2003 10:49 PM
How hard, how long (to install everything!) Verist Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 10-01-2001 09:43 PM
