Old 05-13-2009, 04:55 PM   #51
RaceComp Engineering
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Shocks are decent. Will plug in some numbers and get cranking.
Myles
RaceComp Engineering is online now   Reply With Quote
Old 05-13-2009, 06:51 PM   #52
LEXtoWRX
Member#: 187098
11 STI Sedan
SSM
Everyone make sure you e-mail or PM RaceComp. I want this to happen. So don't just say your interested in this thread. E-mail them and tell them how you feel.
LEXtoWRX is offline   Reply With Quote
Old 05-14-2009, 01:36 PM   #53
saphro
Member#: 209793
+1 from me too, but make sure they will fit on the NA's 2.5i
saphro is offline   Reply With Quote
Old 05-14-2009, 02:42 PM   #54
BIGSKYWRX
Member#: 7958
09 GH B+
they'll "fit", you'll need dampers (09 WRX+) though, same w/ the 08 WRX guys- even the stock 09 WRX springs would be too stiffly sprung for either damper
Old 05-20-2009, 04:59 PM   #55
WRBear
Member#: 207171
2009 WRX
How's it coming?
WRBear is offline   Reply With Quote
Old 05-21-2009, 12:25 AM   #56
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Originally Posted by WRBear View Post
How's it coming?
Its coming.
mw
Old 05-22-2009, 07:57 PM   #57
aross
Member#: 831
11 Blurple WRX
03 BH MBP
Announcement?
aross is offline   Reply With Quote
Old 05-28-2009, 12:36 AM   #58
reaper702
Member#: 191827
2016 WRX
CWP
Bump! Any news yet
reaper702 is offline   Reply With Quote
Old 05-28-2009, 02:43 PM   #59
JohnnyG
Member#: 164671
2009 WRX 265
Originally Posted by RaceComp Engineering View Post
wont know until Monday. The STi shocks are made by Showa which makes the Cusco Zero 2R and most of the Japanese domestic market oem dampers. These are NOT made by Showa but feel "decent" when pressing in on them.
Just letting you guys know I had them.
Myles
Any info regarding the dyno numbers for the dampers?
JohnnyG is offline   Reply With Quote
Old 05-28-2009, 04:25 PM   #60
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Ok so the reality here is the 09 shocks are MAXED from the factory with the OEM rates. They are very matched with no headroom like the STI shocks have. I have bought shocks, hacked the front to work on our Roehrig dyno and they just wont be able to handle really ANY increase in rate. Period.
I dont believe in increasing the rate 10lbs, making it more progressive and lowering it within a few mm of the bump stops. YOU WILL see other companies that do this and it WILL feel like crap. FOR SURE. If it cant be functional no need to make it.
On a brighter note...........our STI springs will work with the Koni inserts that are probably in the works already for the 08-09 WRX. So thats the deal. Buy some Koni's and call it a day OR be happy with the 09 OEM setup.
Trust me if it worked we would make it.
Thats the long and short of it.
I really appreciate the response we got from this. I wish we had some mega oem press machines to make some OEM shocks with good travel and good valving and oh...affordable. Man wouldnt a 2 way fixed perch be the BOMB !!
Myles
Old 05-28-2009, 08:03 PM   #61
BIGSKYWRX
Member#: 7958
09 GH B+
Myles- it's much appreciated by the community that you took the steps to purchase, hack and test the oe units AND the integrity to say what no one really wanted to hear too bad. You and I both know that very likely no one else is going to even consider doing that. Get some springs, provide a drop and pick a rate out of the air- is unfortunately not that unusual
I got to peek at the dyno's and agree completely w/ Myle's assessment- the dampers are fine w/ the oe springs, but they didn't build in any extra rebound/compression for firmer (or lower and firmer) springs. Evidently that is not the case w/ the Showa inverted dampers for the STi, thus the success w/ the RCE GR springs.
As Myles mentioned, Koni is probably going to be an option (I should know pretty soon )- the damping is MORE than ample in the units I have.
Old 05-28-2009, 09:32 PM   #62
reaper702
Member#: 191827
2016 WRX
CWP
sucks to hear but atleast there is good explanation for the bad news. Guess I'll have to wait for the konis but that may be a while
Old 05-29-2009, 12:11 AM   #63
Brack
Member#: 12445
13 Accent
Red
I ditto what Big Sky says .
Brack is offline   Reply With Quote
Old 05-29-2009, 01:41 AM   #64
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Thanks Mike.......I had high hopes too and was disappointed to say the least.............But with that said..................we would love to do some 08 WRX sways....esp with our GR STI bars in the works already. So if anyone is interested let us know.
Myles
Old 05-29-2009, 02:06 PM   #65
Mind
Member#: 109216
08 STI DGM
76-77 Lancia Scorpion(s)
Great info RCE.
So, with the incoming Konis - would the RCE STI springs still work on the WRX w/konis even with the spring length discrepancy?
Mind is offline   Reply With Quote
Old 05-29-2009, 03:13 PM   #66
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Originally Posted by Mind View Post
Great info RCE.
We will have to see how the Koni's effect this smidge of a difference. I mean its "secure" in the perches, so this could make it better or a hair worse. None the less, for that we can make a special spring to be honest. The Koni's are capable of some MEGA rates, so who knows....we could go up ALOT in rate.
Myles
Old 05-30-2009, 03:12 PM   #67
niscur29
Member#: 208306
2009 WRX
Myles
Weird that the shocks/struts you got aren't made by showa, Mine are both front and rear. See pic that clearly shows Showa stamped on them.
niscur29 is offline   Reply With Quote
Old 05-30-2009, 10:06 PM   #68
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Dude do me a favor............take the part # off of those. We cross referenced this at 3 different Subaru dealers. Plus I will take a super close look at the shocks I have AGAIN.
email me the part # of the rears if you can.
[email protected]
Myles
Old 05-30-2009, 10:09 PM   #69
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
edited
Old 05-30-2009, 11:05 PM   #70
BIGSKYWRX
Member#: 7958
09 GH B+
Myles do you think they could have given you 08 dampers by any chance?
my oe 09's are Showa as well
Old 05-31-2009, 08:45 AM   #71
aross
Member#: 831
11 Blurple WRX
03 BH MBP
My 08's were Showas too I still have my rears - could send one down - if interested.
Old 05-31-2009, 12:47 PM   #72
niscur29
Member#: 208306
2009 WRX
Ok the rears are 20365FG060...I cant see the front without jacking up the car. When I typed this part number into some online retailers it shows:
20365FG060 $116.78 $0.00 $86.19
SHOCK ABS COMPL R
Old 05-31-2009, 02:43 PM   #73
reaper702
Member#: 191827
2016 WRX
CWP
could it be the springs originally tested are not the oe 09 wrx springs??
Old 05-31-2009, 10:07 PM   #74
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Trust me I will be ALL Over them tomorrow. I just wonder WHY all 3 local dealers showed the same part # that I ordered.
well the good thing is ....if this is a goof...then its a GREAT GOOF !! Because hypo....the "correct ones" would be able to handle more and then I can save all my info I had in mind for these.
On the flip side if they did send me the WRONG ones...I will send them all large "FAIL" stickers.
Myles
Old 05-31-2009, 10:09 PM   #75
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
SHOCK ABS COMPL R
do me a favor....can someone get me the front ones too.
Mw
09-10 specific Eibach Springs ...cAs... Brakes, Steering & Suspension 0 04-02-2010 11:29 PM
How About Getting Some RCE Wagon Springs Made? (Gauging Interest Thread) hklatte Brakes, Steering & Suspension 77 11-19-2009 02:36 PM
FS SD : 08/09 WRX hatch turboback custom made 4 rally $250 and more ricepapertiger SCIC Private Classifieds 8 10-15-2009 03:34 AM
foooooood... lets get some fooooood nateconnella North West Impreza Club Forum -- NWIC 18 04-09-2003 06:33 PM
LI meet! Lets get some ideas here. Keith General Forum Archive 31 07-11-2000 07:15 PM
