Old 01-14-2009, 10:16 PM   #1
suby_do
Member#: 154711
1997 swap rotated
ppg impreza L
Default wiring for swap
will the wiring harnesses swap directly over from a 06 wrx to a 97 impreza or do i need to merge them?
suby_do is offline   Reply With Quote
Old 01-14-2009, 10:24 PM   #2
beaviscih
Member#: 123362
'93 Crapcan, '98L
Sold, '04 STi - Sold
Which dash will you be using? Using the '97 will require some merging, but I'm not sure how much. And IIRC you still need to address tail lights and some other accessories if you swap in the WRX dash. I found this thread helpful when planning my swap. http://forums.nasioc.com/forums/show...light=Brighton
beaviscih is offline   Reply With Quote
Old 01-14-2009, 11:24 PM   #3
elislider
Member#: 133923
03 Legacy GT wagon
I love goooollllllllddddd
you can swap over the ENTIRE harness from car to car... but if you just want to swap the engine and/or dash harness it will be a huge task merging with the stock harness
elislider is offline   Reply With Quote
Old 01-15-2009, 01:28 AM   #4
suby_do
Member#: 154711
1997 swap rotated
ppg impreza L
im sure what dash i will use. how does the dash line up with the door pannels for a coupe. i can figure out the lights pretty easy. i have hids now so the head lights will be easy because i only have highbeams. taillights will mainly be swapping the conecters.
Old 01-16-2009, 01:06 AM   #5
MY00Forest
Member#: 75451
2000 Forester
black
you will at least need to change out the dash beam and probably do a little bit of merging for the rear lights etc.
MY00Forest is offline   Reply With Quote
Old 01-16-2009, 04:27 PM   #6
powerneedy
Member#: 161242
Look at my thread, i havnt updated it but everything is good to go and as far as lining up there is a small gap at the a pillers. You have to use 98+ door panels, and the hvac system does go in there with some tweaking...
http://forums.nasioc.com/forums/show....php?t=1579928
powerneedy is offline   Reply With Quote
Old 01-16-2009, 10:23 PM   #7
StrictlySubarus
Member#: 199648
04 Swapped GC
too many colors to list
Merrrrrgggge if you wanna keep your 96 stuff or just swap it all
StrictlySubarus is offline   Reply With Quote
Old 01-18-2009, 01:44 AM   #8
suby_do
Member#: 154711
1997 swap rotated
ppg impreza L
well i bought the car today. im gunna swap the entire dash. im just gunna do it all since i have a complete car.
Old 04-27-2009, 08:31 AM   #9
kensworth
Member#: 177915
sorry for bringing this thread back but its not too old. I am doing an 04 sti engine swap and as of right now I plan on keeping my stock dash. I Have the bulkhead harness for my stock one and I believe the one for the sti along with the sti engine harness. Can anyone just pm me an overview of what needs to be merged?
Thanks, Kenny
kensworth is offline   Reply With Quote
Old 04-27-2009, 09:50 AM   #10
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
read the sticky at the top of the forum
2.5rs coil wiring for 1.8-2.5n/a swaps! subbyspeed Subaru Conversions 28 05-28-2008 10:30 AM
Wiring for swap, what shop? 05BluePearlGT South West Impreza Club Forum -- SWIC 4 03-21-2007 07:02 PM
Correct Fuel Gauge Wiring for Swaps sith Subaru Conversions 2 07-22-2006 02:01 AM
Wire harness re-work for swap rocketman1 Subaru Conversions 3 08-09-2005 03:23 PM
wiring diagrams for swaps spiralsmurf Normally Aspirated with bolt-on Forced Induction Powertrain 16 08-05-2002 07:44 PM
