Old 04-28-2009, 12:34 PM   #1
Big-Sexy907
Member#: 59057
2004 Impreza, STi.
Default Eboost2 Wiring to ECU, for RPM/Boost Control
Cleaned up the install on my Eboost2 last night and was debating on tapping the ECU for the RPM/Boost feature. Has anyone done this before, opinions, suggestions?
I posted this in the 2.5 forum with no reply.
Big-Sexy907 is offline   Reply With Quote
Old 04-28-2009, 03:16 PM   #2
Atlas1977
Member#: 199185
2005 WRX (RIP)
2000 Outback Sport
I don't think the ECU keeps track of actual boost. I have a new GReddy Touch and it gets all of its info from the ECU and I get a reading from the intake manifold of PSI but it definitely does not correlate with traditional boost numbers attributed to turbos. I need to get an addtional harness to read turbo boost.
Atlas1977 is offline   Reply With Quote
Old 04-28-2009, 06:22 PM   #3
jays05
Member#: 78165
05 STI 35r + e85
For the RPM part, there are AVC-R install instructions around here which show the ECU pinouts, but I don't think they will be able to help you with your '78 Schwinn.
jays05 is offline   Reply With Quote
Old 04-28-2009, 07:35 PM   #4
rkramer
Member#: 118209
2015 WRX Limitec
yep, it does... hint, what do you think controls boost in a stock car?
Old 04-29-2009, 01:21 PM   #5
Big-Sexy907
Member#: 59057
2004 Impreza, STi.
Thanks for the heads up. I'll take a peek and see what I find.
I read that some folks need to use a resistor to keep the stock Tach working, has anyone experienced this?
Old 05-11-2009, 02:34 PM   #6
Big-Sexy907
Member#: 59057
2004 Impreza, STi.
Eboost wired in successfully. Used the power and ground from the clock pod, and tapped the ecu for RPM signal at the 134 block, pin 23, green wire.
where to tap for RPM Wire (on the cluster only) imcabby Interior & Exterior Modification 1 07-23-2014 01:30 PM
FS NYC: 05 WRX Wagon wiring harness, ECU and fuel pump controller rice h8r Engine/Power/Exhaust 37 08-19-2009 09:04 AM
What wire to tap for MAF to Snow Controller Irishman Water/Methanol Injection, Nitrous & Intercooler Cooling 2 08-11-2007 10:22 AM
RPM signal wire to ECU scoobyimprza Engine Management & Tuning 7 08-08-2003 08:09 AM
Which is the RPM wire on ECU for 99 impreza? GimmeScoobySnacks Normally Aspirated Powertrain 2 01-19-2003 12:19 AM
