Old 04-28-2009, 02:13 PM   #1
AVANTI R5
Member#: 73805
2016 Cayman GT4
black
Default Video: Zenvo ST1, Danish supercar in action
Back in December 2008, Zenvo Automotive and Danish Design introduced us to the Zenvo ST1, an insanely fast and aggressive looking super car powered by a 7.0L turbocharged and supercharged V8.
Known as the Zenvo ST1, the Danish supercar produces a whopping 1,104-hp with a peak torque of 1,054 lb-ft. 0 to 62 mph comes in under 3 seconds with a top speed of 233 mph.
The duo will only produce 15 units of the ST1, which will be sold to “special approved customers.”
A Denmark publication has just posted a video of their test drive of the Zenvo ST1 crossing Denmark in under 20 minutes.
Follow the jump for the video
http://www.egmcartech.com/2009/04/28...car-in-action/
Old 04-28-2009, 03:01 PM   #2
flexer
Member#: 111947
the car looks really good
i wonder what the point of producing just 15 of these cars is
to develop a car like that must cost a pretty penny, i can't imagine they will make their money back on just 15 cars
can anyone explain the logic behind this? im sure that theres someone smarter than me developing their business plan lol, im just curious
flexer is offline   Reply With Quote
Old 02-09-2010, 07:54 AM   #3
AVANTI R5
Member#: 73805
2016 Cayman GT4
black
Default Zenvo ST1 V8 supercar
What is it?
Zenvo was started by three people who decided to attempt what the likes of Bugatti, Pagani and Koenigsegg had done before them.
The objective, according to company boss Jesper Jensen, was not to build a road rocket that could outdo the Veyron in terms of raw pace (although the claimed figures – 0-62mph in 3.0sec and 233mph max - aren’t too shabby). Instead, the idea was to come up with car that could easily be driven every day, yet which could also double as a track weapon.
The ST1 was initially designed as a rolling chassis, built around a steel backbone with double-wishbone suspension and three-way Öhlins adjustable dampers.
The massive supercharged and turbocharged V8 was positioned longitudinally directly behind the passenger cell, and the armoury of radiators and other ancillaries were then scattered around the car.
Once all the hardware was in place and functioning to their satisfaction, the Zenvo crew called on Danish designer Christian Brandt to pen the contours of the carbonfibre bodyshell.
The car you see here is the prototype, which has clocked up more than 45,000 miles - and isn't looking at all shabby for it.
The V8 motor is roused into action by twisting an ignition knob on the centre console to the right, depressing the clutch and then pressing the start button atop the chunky piston-shaped gearlever while simultaneously giving the gas pedal a generous prod or two. The 7.0-litre motor erupts into life with a raucous bark, but it immediately settles into a civilised idle.
The clutch doesn’t call for Schwarzenegger-esque quadriceps, but slotting the six-speed Ricardo gearbox into first gear (or any other ratio) requires a firm hand. Zenvo technical guru Troels Vollersten explains the gearshift linkages are a bit worn on the prototype car, and that a new set would make for far easier shifting.
The ST1 has three engine modes – normal, sport and race – liberating 650bhp, 850bhp and 1104bhp respectively, and selection of any of these is a mere twist-knob away. Traction control is fully operational in the normal mode, and partially so in sport… but you’re on your own in the full-power race mode.
The seat of my pants tells me even the 650bhp setting will be enough to see off most rivals, provided you’re deft enough with your clutch and gearchange work. This is no Honda S2000-style rifle-bolt gearchange requiring mere flicks of the wrist. Instead you need to manhandle the alloy knob from one ratio to the next as shifts are neither light nor quick (but perhaps the new linkages alluded to earlier would help).
The engine’s power delivery is relatively smooth and progressive – there’s no alarming peaks or troughs – but the blown V8 doesn’t particularly enjoying lugging at low speeds in high gear. This, plus the stubbornness of the manual gearbox, suggests the six-speed paddle-shift sequential – made by Xtrac – will be the better choice for most.
In no-holds-barred 1104bhp mode the ST1 is virtually as quick as anything I’ve ever driven – Bugatti Veyron included. However, where the Bugatti cossets you and insulates you from much of the violence taking place in the engine room, the Zenvo assaults you with an aural and physical battering.
Unleashing the full quota of power is partially achieved by opening up flaps in the exhaust, which means noise levels instantly escalate to conversation-killing levels, and full-throttle gearshifts are accompanied by a slight twitch from the chassis as 1055lb ft of twisting force does its best to unstick the steamroller rear tyres from the bitumen.
The brakes are massive Brembos (380mm at the front and 355mm at the rear), but given that I’m being intensely scrutinised by Vollersten, who’s riding shotgun, I resist the urge to stomp all over them.
Ride quality is somewhere between firm and rock-hard, but the production car will have a choice of three settings – comfort, normal and sport. Vollersten says shock-absorber specialist Öhlins could provide up to 30 settings for their dampers, but this would be just too much choice for most owners.
Should I buy one?
See more Zenvo ST1 pictures
The key question: is the Zenvo special enough to warrant its exorbitant price tag? To be honest, I can’t quite see £750,000 worth of value in the car, but perhaps the lure of being one of only 15 people to own an ST1 will be the clincher for some. Those that miss the boat will have to hold out for the ST2.
Gautam Sharma
Pictures by Bahr Al-Alum Karim First drive data
How much?
  • Price as tested TBA
  • Price as tested £750,000
How fast?
  • 0-62 mph 3 sec
  • Max speed 233 mph
How big?
  • Weight 1376 kg
How thirsty?
  • Combined no data
  • CO2 emissions no data
Engine
  • Layout V8
  • Max power no data at 6900 rpm
  • Max torque no data at 4500 rpm
Old 02-09-2010, 11:32 AM   #4
sub9lulu
Member#: 36946
damnnnnnn i like how it looks on the outside
(interior looks kinda cheap tho)
sub9lulu is offline   Reply With Quote
Old 02-09-2010, 12:14 PM   #5
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
yay..another super car!
mxpunk is offline   Reply With Quote
Old 02-09-2010, 12:22 PM   #6
SCRAPPYDO
Member#: 873
2014 GLK/allroad
Datsun 71 240Z & 68 2000
isn't that a Porsche dash pod
SCRAPPYDO is offline   Reply With Quote
Old 02-09-2010, 01:08 PM   #7
Chiketkd
Member#: 71634
In hibernation...
+1 Gauge pods definitely look like they were sourced/copied from a Porsche.
I love the exterior!!! Just a wild & crazy design that's unlike anything I've seen before. I felt the same way years ago when Pagani released the Zonda.
Chiketkd is offline   Reply With Quote
Old 02-11-2010, 03:05 AM   #8
sauuce
Member#: 109253
2006 STi
SGM
that interior needs some serious work.
sauuce is offline   Reply With Quote
Old 02-11-2010, 09:18 AM   #9
SCRAPPYDO
Member#: 873
2014 GLK/allroad
most of these 'johnny come lately' supercars need serious work on the interior. That is exactly why they do not last more than the length of these posts. It takes something to make you stand out to last in that market. Something that you can say, I have this, Nobody else does. This is just another boring also-ran. Cars like the Zonda, standout, not just to its crazy styling, that is a given in this market, but because of the way the styling is executed. Cars like the Zonda are have almost a jewelry like quality. Not a fischer price thrown together feel like this car.
Old 02-11-2010, 09:44 AM   #10
mhoward1
Member#: 9481
1832 Steam Buggy
Wood
Not bad
mhoward1 is offline   Reply With Quote
Old 02-11-2010, 12:47 PM   #11
monovich
Member#: 8124
1998 Old Grey Mule
Regacy Rype R
I wish I could tell what it looks like. all the wide angle closeups don't give a good sense.
still, its a better looking exterior than many have managed to conceive lately
monovich is offline   Reply With Quote
Old 02-11-2010, 12:50 PM   #12
Not-EWRX
Member#: 158043
2013 Wrx Hatch
Love all the Carbon Fiber.
Not-EWRX is offline   Reply With Quote
Old 02-11-2010, 01:03 PM   #13
Dirty25RS
Member#: 56731
2004 STi, 00 Insight
10 Volvo C30R-d 11 F150
I'd rather have a Smart ForTwo, its safer and more fuel efficient.
Dirty25RS is offline   Reply With Quote
Old 02-11-2010, 01:56 PM   #14
Iegav05
Member#: 231526
2005 LGT AVO380
2011 E90 M3 ZCP
Really awful looking car--a veritable tribute to a lack of imagination. Good thing it is a performer mechanically.
Iegav05 is offline   Reply With Quote
Old 02-11-2010, 03:06 PM   #15
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
Amen.... I would add cars like the Veyron to that list of supercars that do something different.
It isn't enough just to go fast anymore...
jigga is offline   Reply With Quote
Old 02-11-2010, 04:06 PM   #16
under5
Member#: 188980
2005 WRX
PSM For Sale:(
looks like a certified beast. No way its worth a 1,000,000 though
under5 is offline   Reply With Quote
Old 02-11-2010, 09:38 PM   #17
sniper1rfa
Member#: 141040
07 2.5i wagon
UGM
To do that they would need to sell more than 15 cars.
sniper1rfa is offline   Reply With Quote
Old 02-11-2010, 10:10 PM   #18
SCRAPPYDO
Member#: 873
2014 GLK/allroad
Its just some nut trying to pass off something as a super car and make lots of money buy charging an obscene amount. Supercars of this day and age are far less concerned about ultimate performance than they are about being a fashion icon. They are assessories for rich people.
True performance supercars are in a totally different catagory. Most of these cars cannot out corner a VETTE or a Porsche, who deserve the performance supercar badge.
Just because somebody can learn to tune a megasquirt ECU does not give them permission to call what the build supercars.
Old 02-12-2010, 08:12 AM   #19
Dirty25RS
Member#: 56731
Yeah there's million of these hastily developed "supercars" these days. You never see them on the track though so who cares about em. They're on the same level as printing in color...expensive and useless.
I do like the engine package tho.
Old 02-12-2010, 08:18 PM   #20
blk_wrx
Member#: 83125
2010 EV0 X
Wicked White
Default familar rear end
rear looks a lot like the Lexus super cars....
blk_wrx is offline   Reply With Quote
Old 02-13-2010, 10:39 AM   #21
Dirty25RS
Member#: 56731
did they get that steering wheel out of a 1995 Eagle Talon?
seriously. If they are going for the "lean mean race car" supercar, i get why the interior sucks. But if its a lean mean racecar, than why does it have regular 3 point seat belts?
Old 02-13-2010, 01:43 PM   #22
mhoward1
Member#: 9481
1832 Steam Buggy
Wood
maybe because 99.999 percent of the 5 and 6 pints are not street legal, and 4 points are down right dangerous.
Old 02-15-2010, 12:59 AM   #23
chulooz
Member#: 159438
99 GC8
The interior does look that cheap. It seems like it could complete its mission of being a very street-able car yet track ready quite well. And it certainly needs that $1million+ price tag if they are only making 15 production models, they probably all are already spoken for anyway. Very interesting super + turbo charger design on that V8.
chulooz is offline   Reply With Quote
Old 02-15-2010, 08:12 AM   #24
Dirty25RS
Member#: 56731
Super turbo 427, can't beat that.
Old 02-25-2014, 03:30 PM   #25
torquemada
Member#: 128484
2006 EDM WRX STI
Zenvo and Danish unveil 1,104-hp Zenvo ST1 AVANTI R5 Non-Subaru News & Rumors 20 12-31-2008 04:15 PM
V10-powered Falen supercar in the works AVANTI R5 Non-Subaru News & Rumors 11 12-24-2008 09:55 AM
2009 BMW M10 supercar in the werks? AVANTI R5 Non-Subaru News & Rumors 17 05-24-2008 01:35 PM
Want to build supercars in florida? 02fastWRBLUE South East Region Forum 15 09-29-2007 01:32 PM
Ultima GTR- officially the fastest supercar in the world rich22 Off-Topic 15 12-11-2004 12:19 PM
