Welcome to the North American Subaru Impreza Owners Club Tuesday August 4, 2015
Old 04-28-2009, 04:37 PM   #1
watchunglava
Member#: 168862
2007 ej253n/a 5speed
Red Sox Nation Lifer
Default compression test results please add input
See next post due to blackberry
watchunglava is offline   Reply With Quote
Old 04-28-2009, 04:38 PM   #2
watchunglava
Member#: 168862
ok i have been consuming alot of oil latley .
around 10 qts since my last oil change 3 months ago.
all my spark plug gaskets are leaking but i doubt that its whats causeing so much loss.
no other visable leaks or oil in the coolant.
i ran a vaccum test and a dry compression test .
compression checked out at
cyl#1 160
cyl#2 170
cyl#3 170
cyl#4 168
and here is the vaccum test
im now at a loss . next?
Old 04-28-2009, 06:18 PM   #3
WcW
Member#: 209963
Default possible explination...
you may have lost cam timing. jumping a tooth on the crank will yield a combination of symptoms: low compression and a jumping needle. Checking the timing will diagnose a jumped crank or trigger side intake timing flaw but to completely check the timing you have to remove the front timing covers on both sides. No need to check the crank position or the timing side intake, as they would throw the timing off. crank the engine over to line up the marks on the timing side camshaft then inspect the other marks. If you need more help than this just ask and I can give you more explanation.
WcW is offline   Reply With Quote
Old 04-28-2009, 08:25 PM   #4
WcW
Member#: 209963
oil could be leaking from the front main seal which would explain the jumped cam timing too.
Old 04-28-2009, 09:29 PM   #5
watchunglava
Member#: 168862
im accually seeing higher compression than most other 2.5 n/a's .
im definatly not leaking oil from the front seal. i see no oil anywhere , i even took my hand and rubbed it over the usual suspects .
a timing issue may be the culprit because the dial seems to be a little more jumpy than just valve overlap . but it could just be that thats making it jumpy, valve overlap.
i will have to check the cam timing .
thank you for your positive and informative opinion!
04 sti compression test results, need advice please 85manny Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 16 02-28-2009 06:39 PM
Compression Test Results @ 55,650k PaulRex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 10-12-2003 02:59 PM
EJ25 Compression Test Results at 50,000 miles latinskllz Normally Aspirated Powertrain 4 11-11-2002 02:46 PM
Compression Test Results- 3 Motors dug-e-fresh Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 10-31-2002 11:32 PM
Compression test results numbers Imprezer Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 09-12-2001 01:08 AM
