Old 04-28-2009, 06:21 PM   #1
Wintershredder
Member#: 160089
2008 M5/330xi/328xi
Black/Black/White
Default Need Help: VVT=AVCS
I know about AVCS and such, however, there is a guy locally selling an 08/09 Forester XT long block. He says it has VVT, which i interpret into avcs. SOOOO, did subaru switch to VVT on the new cars or does he mean AVCS. I dont wanna buy a block and heads that i cannot use. I have an 04 STi at the moment. Any response would help!
Thanks everyone,
Garrod
Wintershredder is offline   Reply With Quote
Old 04-28-2009, 07:37 PM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
you wont be able to use the vvt or avcs regardless....if this engine is going into your 04 sti.....your ecu is different
also....the whole intake manifold and throttle system is different
Old 04-28-2009, 08:28 PM   #3
Wintershredder
Member#: 160089
2008 M5/330xi/328xi
Black/Black/White
I already have another built 04 STi block. I was mainly going to get this for the heads. I am also using a intake mani from an 06 2.5i. I am also going with a standalone autronic ecu. My car is equipped with avcs, so i dont see why this wouldnt work. Isn't vvt a toyota thing?
Old 04-28-2009, 08:33 PM   #4
Nuke209
Member#: 108089
2003 WRX
NF Performance
He meant AVCS, some call it vtec, some call it vvt, some call it avcs, whatever floats their boat.
It's still AVCS
You should be able to the run the heads on your car (unless subaru made something different)
Nuke209 is offline   Reply With Quote
Old 04-28-2009, 08:36 PM   #5
Wintershredder
Member#: 160089
2008 M5/330xi/328xi
Black/Black/White
Thank you sir, that is what i am looking for. I just need to find some evidence, before i invest in something that wont work. I am pretty sure it will, but, i am not familiar with the newer subaru's.
It's still AVCS
Old 04-28-2009, 10:37 PM   #6
thepigsti
Member#: 166215
It is my understanding that AVCS and Toyota's similar VVTi only affect timing, they do NOT have a mechanical means of having followers use a completely separate higher lift/longer duration lobe on the cams themselves which is what Honda's VTEC does.
thepigsti is offline   Reply With Quote
Old 04-28-2009, 11:27 PM   #7
zeropsi
Member#: 175453
AE86 GT-S coupe
i <3 alqonquin homosauce
Thanks everyone,
Garrod
Your only worry should be if it's dual AVCS like the 08 and newer STi's. You can get any single AVCS ECU, with the exception of JDM setups, to work with another.
I think it'll work if it's still single AVCS. Dual AVCS, not without the corresponding ECU from the new motor.
zeropsi is offline   Reply With Quote
Old 04-29-2009, 02:02 AM   #8
jamal
Member#: 71875
98 Legacy GT
my wheels fit
Yes, the AVCS solenoids and connectors are the same. You would be able to use your STI cams and solenoids if you wanted to anyway.
In fact, you would be able to use the whole motor as long as you took your wiring harness since the main connectors are different. Even with the plastic manifold, as long as you had a turbo/intercooler to work with it. Those plastic manifolds are really great if you want to flip them around, too.
jamal is offline   Reply With Quote
Old 04-29-2009, 02:12 AM   #9
STIBungy
Member#: 51684
The blocks are junk anyways.
STIBungy is offline   Reply With Quote
Old 04-29-2009, 02:47 AM   #10
zeropsi
Member#: 175453
AE86 GT-S coupe
Block or factory tune?
Old 04-29-2009, 09:44 AM   #11
STIBungy
Member#: 51684
They all had a hole in them.
Old 04-29-2009, 10:00 AM   #12
Uncle Scotty
Member#: 16200
OK buy Nates beans
what the **** are you on about here
they all have LOTS of holes in them.....
Old 04-29-2009, 02:50 PM   #13
EE06STI
Member#: 124580
So, what if he decided to swap the cam gears from his STi onto the new heads?
Or...what if he swapped cams and cam gears?
EE06STI is offline   Reply With Quote
Old 04-29-2009, 03:25 PM   #14
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
nevermind
Old 04-29-2009, 07:39 PM   #15
tallicaguitar88
Member#: 55635
2009 GTR
What are YOU on about? The holes are from SOA punching them into the block to render them useless. Please think before posting. KTHXBAI.
tallicaguitar88 is offline   Reply With Quote
Old 04-29-2009, 10:49 PM   #16
Wintershredder
Member#: 160089
2008 M5/330xi/328xi
Black/Black/White
Yes PANG, i know they had holes(drilled by subaru), but i just got a complete longblock with, complete heads, all sensors, oil filler, dipstick, all pulleys, cam gears, front and rear timing covers, water pump, oil pump, tgv gaskets, coolant crossover, oil pan, and maybe some good internals. I didnt buy this for the block, i already have a machined one at home, i got it for the heads and accessories. Not bad for $200.
You are just sad that you snoozed, and you losed!
Thanks to everyone with helpful responses. **** off Stibungydouche
-Garrod
Old 04-30-2009, 03:53 PM   #17
Uncle Scotty
Member#: 16200
OK buy Nates beans
Old 05-01-2009, 12:00 AM   #18
fateo66
Member#: 130997
Except not all of the blocks had holes in them
fateo66 is offline   Reply With Quote
Old 10-10-2009, 05:20 PM   #19
Wintershredder
Member#: 160089
2008 M5/330xi/328xi
Black/Black/White
That's not what the spraying oil had to say!
VVT/AVCS question? Dodik Built Motor Discussion 3 04-16-2007 01:58 PM
Need help: Need to get car smogged GimmeScoobySnacks Southern California Impreza Club Forum -- SCIC 24 02-26-2007 06:31 PM
Need Help: Need A Flywheel nturino South East Region Forum 2 03-04-2003 04:07 PM
need help: 98RS stock cat. convertor need urgent DarkImpreza Vancouver Impreza Club Forum -- VIC 1 01-03-2002 11:50 PM
Need help: Finally getting a turbo and need to list required parts-Please help! Andrew Normally Aspirated Powertrain 9 01-23-2001 03:06 AM
