Go Back   NASIOC > NASIOC Classifieds > Private 'For Sale' Classifieds > Complete Car Part-Out
Old 04-28-2009, 11:18 PM   #1
Aspen_2.5RS
Member Sales Rating: (473)
Member#: 3310
Update 11/12/15 - new parts added: Yes, this is an old thread, but I do still have parts left. I hate to throw good parts away b/c someone will probably want them the day after.
Please take a second to SEARCH this first post as it is updated & you won't be wasting my time or yours when you ask me if certain parts are available. If you ask me about parts that have already sold or are damaged I will just delete your pm.
To find parts in the list, go to "edit" & "find on this page" & type in what you're looking for. Below the pics is a list of available/sold parts. Check my feedback.
The car had ~128k miles on it.
Pm me with your zip & the part(s) you want if you're not local & want something shipped.
Damaged/Unavailable list
headlights
pass. fog light
pass. fender
hood/scoop
front bumper
grill
radiator/radiator fans
radiator hoses
coolant overflow tank
condensor
timing covers
driver & pass. dash airbags
inlet tube
lid for center console
floormats
bottom half of stock airbox
clock/clock pod
starter
power steering reservoir - small hole (could be repaired, though)
High pressure a/c line
lateral link pass. side - closest to front of car - bent
plastic bcs cover & clips that hold it on
Available: - by no means is this even close to a complete list, but check above and below before asking
Interior- Available parts
hood release lever (sold cable already)
ecu cover kick plate & bracket (have a couple of these)
map light (extra from a prev. car)
dome light (extra from a prev. car)
cruise switch from steering wheel
dash bar/beam
abs g-sensor
interior door cards/panels (1 - pass. front)
complete antenna assembly
passenger rear seat belt & maybe some good fronts from a prev. car (The fronts in this one I assume are no good)
side mirrors control switch (have extras)
third brake light assembly for sedan (pretty scratched up)
rear strut top dust covers - metal
glove box
window motors (random from previous cars)
trim with cupholder that e-brake goes through
center console w/o lid (local pick up only - 2 of these)
interior door handles
door speakers
spare tire/wheel - black narrow steelie (2)
oh crap handles (4)
license plate light assembly housings
fuel pump cover (wrb - also have adjacent cover)
door wiring harnesses (all 4 from a sedan)
rear deck tray (carpet board thing) from a sedan
window switch trim pieces for all doors
right side handle trim (fits front/back)
interior trim: c-pillar, b-pillar, a-pillar (except for driver's side), & trim around bottom of door openings
Engine parts/Engine bay - Available parts
Edit: Another engine I'm parting with more parts here:
http://forums.nasioc.com/forums/show....php?t=1914513
plastic battery box
flywheel inspection plate
oil cap
black metal coolant lines on front of engine
old timing belts (for mock up or whatever - 3+ of these)
used head bolts (for mock up or whatever)
top half of stock airbox
brake booster hose (runs from bb to intake manifold)
tps - throttle position sensor (same as a tgv)
flywheel bolts
steering column
rubber bushing w/white plastic for the steering column
right side valve cover from another engine (the driver's side has some hair line cracks, may scrap it)
misc. nuts/bolts (lots of metric stuff from wrx's) - Just ask!
green brackets of death
misc. hoses - vacuum (t-fitting at turbo is sold)
rubber isolators for lower radiator supports (couple sets of these)
horns
cruise control unit w/mounting bracket (2 of these from previous cars)
thermostat housing neck
windshield washer hose (reservoir to hatch) - long hose
Drivetrain/Suspension - Available parts
clutch fork & pin with allen key cover plug
metal bracket on trans for dog bone mount
dust/debris shields for front rotors
abs sensors (I have a pass. rear & one front (have to check which one))
driver lateral link closest to front of the car
strut to hub bolts/nuts (camber) - front & rear
rear 02 sensor extension harness (prev. car)
trans harness for back up lights & other sensor next to it (prev. car)
bracket that covers bottom of rear differential
5 speed driveshaft
Body parts/glass etc. - Available parts
plastic cowl (covers wiper motor assembly - 2 of these)
metal fog brackets (not perfect, but very usable)
front pass. exterior door handle - psm
glass for pass. front/rear (wagon)
glass for pass. rear (sedan - prev. car)
glass for driver rear (sedan - aftermarket tint - prev. car)
glass for driver front (sedan - prev. car)
fuel door psm (sedan - previous car)
gas cap w/connecting strap (prev. car)
trim that goes over the windows on both sides (wagon specific)
weatherstripping
rear bumper beam
Random other parts - Available parts
lug nut wrench with bag (bag isn't in the greatest of shape)
01 2.5RS stock rear sway bar with mounts/bushings
used stock air filter for 01 2.5RS
2 wrx rods
2 wrx pistons
2 silver wrx round vent trim rings (prev. car)
3 wrx cams
93-01 driver's side Impreza amber corner light
02 wrx rear sway bar end link (just one)
98-01? Impreza new clutch pedal assembly only (the pedal/arm with the long bar that runs across, this is for a hydraulic setup - I bought this before I knew what I was doing & before I put a wrx complete pedal assembly in)
95L Impreza dog bone/pitch mount
95L Impreza rear axles (one may need some work on the threaded end, was a bit seized)
SOLD list
front female seat belts (prev. car) - SOLD
tow hook cover wrb - SOLD
door speakers (have more) - SOLD
lower rad. rubber mounts - SOLD
f&r sways, driver rear exhaust mount, & driver front inner fender lining - SOLD
wiper switch stalk SOLD
gauge pack w/housing, top/bottom steering column covers, & 2 uppipe lower bolts/nuts - SOLD
Low pressure a/c line - SOLD
rear sway mounts/end links - SOLD
stock bpv - SOLD
taillights - SOLD
small center visor below rear view (have more) - SOLD
stock injectors - SOLD
side skirts - SOLD
tgvs - housings/motors/sensors - SOLD
timing cover bolts (prev. car), bracket for smallest idler pulley, water pump bolts - SOLD
roof rack cross bars - SOLD
rear wiper arm & roof rack moldings for both sides w/clips - SOLD
front fender sidemarkers & p/s hose from pump to reservoir - SOLD
exhaust manifolds/intake manifold/throttle body with no sensors - SOLD
power steering lines - SOLD
front 02 sensor - SOLD
gas cap, H pressure a/c cap (light green), oil cap, rear driver's door handle trim , washer nozzles, & firewall grommet under clutch pedal - SOLD
power steering pump (no bracket) & long belt adjuster bolt - SOLD
turbo - SOLD
cam gears (4) - SOLD
A-pillar trim (both sides) - SOLD
oil filler neck, oil cap, dipstick, maf sensor, intercooler splitter, intercooler brackets, power steering pump bracket, a/c compressor bracket - SOLD
blank next to cruise switch - SOLD
brake valve from right strut tower - SOLD
seat bolt covers on back of front seats - SOLD
dead pedal w/clips - SOLD
ecu - SOLD
charcoal canister/2 solenoids near it & crank gear - SOLD
ashtray - SOLD
transmission - SOLD
wheels - 17 x 7, +48, 5x100 5Zigen Heidfeld Mesh
with 215/40/17 bfgoodrich g-force sport tires & STi short shifter - SOLD
front calipers w/brackets/pads - SOLD
Windshield washer reservoir w/motors - SOLD
IACV, turbo heat shield w/bracket, front passenger side door handle trim, & master power window switch - SOLD
foglight brackets - SOLD
Both driver's side doors/windows/window motors/regulators - SOLD
throttle cable - SOLD
Rear diff protector w/hardware - SOLD
Rear seat belt buckles (all) - SOLD - (I do have more of these from a previous car)
fog switch - SOLD
fuel door/lid - SOLD
rear diff. - SOLD
cylinder heads w/cams/cam caps - SOLD
2 switch blanks near armrest - SOLD
manual pedal box - clutch/brake/gas assembly - SOLD
auto dim w/compass rear view mirror - SOLD
hvac controls w/cables - SOLD
crank position sensor - SOLD
Rear lateral links w/brackets for end links & bolts/nuts/washers that connect them to the rear subframe - SOLD
front driver's side axle - SOLD
driver's side fender - SOLD
rear actuator/motor/latch for hatch - SOLD
"U" front subframe - SOLD
radiator support/portion of front frame rails - SOLD
td04 oil feed line - SOLD
front hubs/spindles - SOLD
rear 02 sensor - SOLD
passenger side exhaust manifold heat shield w/bolts - SOLD
rear hatch struts - SOLD
oil pressure sensor & camshaft position sensor - SOLD
spare tire wingnut/washer - SOLD
valve assembly - duty solenoid & valve - purge - SOLD
cruise control unit/cable assembly - SOLD (I have 2 more of these)
shortblock w/oil pan/oil pickup/oil pump - SOLD
hvac/radio silver trim bezel, center vent silver trim, pop out cupholder, & 2 silver trim rings around round vents - SOLD
transmission harness - SOLD
vss - SOLD
battery tray, hooks, nuts - SOLD
front seats - SOLD
roof rails/racks - SOLD
coolant tank reservoir w/hoses & cap (bolts to intake manifold) - SOLD
e-brake handle assembly - SOLD
shift boot & shifter surround - SOLD
floor mat "peg" holder - SOLD
hatch interior trim piece - SOLD
pass. rear door (bare) SOLD
power steering reservoir cap - SOLD
shifter stabilizer bracket/nut/outside bracket/dp bracket & rubber caps for windshield wipers - SOLD
rearview mirror mount - SOLD
tinted glass for passenger rear sedan door - from previous part out (I have one more nontinted) - SOLD
stock 6 disc radio - SOLD
bpv return hose - SOLD
engine harness - SOLD
shift knob - SOLD
complete set of lug nuts (20) - SOLD
driver's side fog light - SOLD
pass. rear abs sensor -SOLD
factory bcs (boost control solenoid) -SOLD
both trailing arms w/brackets to body & associated mounting bolts - SOLD
front/bulkhead/rear wiring harnesses + fp controller - SOLD
steering rack - SOLD
pass. side hood hinge - SOLD
4 coil packs - SOLD
passenger front window switch - SOLD
neutral/reverse trans harness w/sensors - SOLD
front rotors - SOLD
struts/springs/tophats complete (4) - SOLD
HVAC blower motor - SOLD
both front abs sensors (I have more) - SOLD
rear 3rd seatbelt hold clip - SOLD
plastic piece under the gas pedal + clips SOLD
power mirror controls SOLD
front sway bar end links SOLD
knock sensor - SOLD
rear xmember w/bolts to unibody - SOLD
rear diff mount brace w/bolts/nuts (have another one) - SOLD
driver side rear window (sedan - no tint) - SOLD
stock turboback exhaust w/spring loaded bolts - SOLD
driver side rear window switch - SOLD
tool kit - SOLD
coolant temp sensor - SOLD
ecu kickplate/underside ecu bracket/hardware - SOLD
3 hoses with t-fitting at wastegate actuator - SOLD
throw out bearing - SOLD
clutch slave cylinder w/banjo bolt - SOLD
accordian tube to air box -SOLD
rear hubs/knuckles with backing plates - SOLD
rear calipers w/used pads - SOLD
e-brake cables - SOLD
rear rotors - SOLD
rear e-brake hardware (shoes/springs/clips etc.) - SOLD
rear brake lines (rubber) - SOLD
carpet - SOLD
clutch master cylinder w/hard line/soft line - SOLD
fuel dampener valve - SOLD
rear hatch interior convenience light - SOLD
rear most trim piece for headliner - SOLD
passenger side mirror - SOLD
driver side mirror - SOLD
bare shell - SOLD
hatch w/spoiler - SOLD
sunvisors - SOLD
bpv to intercooler bolts - SOLD
bare dash w/defroster trim/vin plate - SOLD
crank pulley - SOLD
tranny mount w/bolts to the trans - SOLD
driver rear abs sensor - SOLD
fuel filter bracket - SOLD
hood latch w/2 bolts (on hood) - SOLD
rear floor carpet (center section/sides/portion directly behind rear seat w/black foam & tray underneath) - SOLD
egt sensor - SOLD
stock jack - SOLD
front pass. bare door with exterior handle/black trim along the top - SOLD
driver rear interior door handle trim - SOLD
pressure plate - SOLD
uppipe - SOLD
valve covers & bolts - SOLD
big bracket that connects uppipe to engine - SOLD
spare vss harness - SOLD
front axle - SOLD
front crossmember (xmember) - SOLD
motor (engine) mounts - SOLD
gauge cluster - SOLD
rear diff brackets that hold diff to outrigger w/nuts - SOLD
rear seat w/headrests/brackets & bolts - SOLD - Joe
latch for hood (bolts to radiator support) w/bolts - SOLD
tweeters - SOLD
2 front oh crap handles (I have more of these) - SOLD
bracket for throttle cable - SOLD
headlight/turn signal stalk - SOLD
rear 02 sensor extension harness - (I have one more) - SOLD
power steering reservoir bracket - SOLD
front bumper beam - SOLD
round pass. side dash vent/housing - SOLD
cruise switch on dash - SOLD
driver's front door card - SOLD
hvac/radio plastic surround - SOLD
round dash vents/housings (1 from a prev. car) - SOLD
2 coolant hard lines off of water pump - SOLD
rear bumper cover - SOLD
front control arms w/ball joints & associated bolts - SOLD
headliner - SOLD
fuel rails w/fpr - SOLD
dome light - SOLD
joint from steering rack to column - SOLD
passenger side interior door handle trim - SOLD
crank pulley bolt - SOLD
intercooler to throttle body coupler - SOLD
gas/fuel tank w/straps/hoses/hardlines/fuel pump/sender assembly/filler - SOLD
rear passenger window switch/main window switch from previous car - SOLD
alternator - SOLD
master cylinder/brake booster - SOLD
hvac/heater core box -SOLD
windshield wiper linkage w/motor (I do have another one) SOLD
map light assembly - SOLD
gauge cluster bezel - SOLD
windshield wiper arms (I have another set) - SOLD
pass. rear door card - SOLD
driveshaft w/all bolts (I have one more) - SOLD
transmission pitch stop/dog bone - SOLD
cubby door for lower dash plastic on driver side (covers interior fuse box) - SOLD
rear outrigger assembly - SCRAPPED
used clutch (have another pressure plate if anyone needs it also) - SCRAPPED
idler pulleys - SCRAPPED
front pass. side psm door (damaged, but repairable) - SCRAPPED
a/c compressor - seems bad - SCRAPPED
rear middle seat belt assembly - SOLD
both rear axles (good boots) - SOLD
steering wheel rim - SOLD
flywheel - SOLD
brake prop. valve - SOLD
coolant crossover pipe - SOLD
driver side rear seat belt assembly - SOLD
lower dash trim on the driver's side that houses the fog/cruise switches - SOLD
a/c tensioner bracket/plastic pulley assembly - SOLD
tmic with y-pipe - SOLD
snorkus - SOLD
center dash vents - SOLD
black metal coolant line that bolts to coolant crossover pipe - SOLD
bracket for front 02 sensor - SOLD
fuel door release assembly - SOLD
2 heater hoses at the back engine block - SOLD
hood release cable - SOLD
trans xmember w/bolts - SOLD
driver side rear door card - SOLD
Last edited by Aspen_2.5RS; 11-15-2015 at 03:27 PM. Reason: updated list, keep finding more parts
Aspen_2.5RS is offline   Reply With Quote
Old 04-28-2009, 11:18 PM   #2
Aspen_2.5RS
Member#: 3310
More pics:
Old 04-28-2009, 11:23 PM   #3
TWR3CKS
Member Sales Rating: (2)
Member#: 194277
2002 wrx
wrb
if you have time pm me with the price of the wheels. i'm looking for wheel and i like those.
TWR3CKS is offline   Reply With Quote
Old 04-29-2009, 01:27 AM   #4
fantomas
Member Sales Rating: (5)
Member#: 87500
2012 Outback 2.5i P
Graphite Gray
how much for the dash harness shipped to 06416
or if you're willing to cut it, all i need are a few of the plugs... (HVAC, cruise control plug and fog light plug (and switch))
fantomas is offline   Reply With Quote
Old 04-29-2009, 09:28 AM   #5
Aspen_2.5RS
Member#: 3310
Pm'd. The bulkhead harness will not be cut - only going to be sold as a whole.
Edit: added more pics...
Old 04-29-2009, 11:51 AM   #6
scoobydude4321
Member#: 209804
hey mate have you still got the wheels ?
scoobydude4321 is offline   Reply With Quote
Old 04-29-2009, 11:52 AM   #7
scoobydude4321
Member#: 209804
alsoo have you still got the momo wheel ? and how much
Old 04-29-2009, 12:28 PM   #8
Aspen_2.5RS
Member#: 3310
Last edited by Aspen_2.5RS; 06-02-2009 at 07:00 PM. Reason: wheels were sold.......added pics
Old 04-29-2009, 01:03 PM   #9
flyinghighlm
Member Sales Rating: (13)
Member#: 156235
2002 Subaru WRX Wgn
PM sent
flyinghighlm is offline   Reply With Quote
Old 04-29-2009, 04:16 PM   #10
NCNBPDC5
Member Sales Rating: (3)
Member#: 102276
2006 WRX Wagon
How much do you want for the gauge pod and gauges? What gauges are included?
NCNBPDC5 is offline   Reply With Quote
Old 04-29-2009, 05:13 PM   #11
vdubvr6
Member#: 189644
how much for entire engine excluding harness?
vdubvr6 is offline   Reply With Quote
Old 04-29-2009, 07:48 PM   #12
Aspen_2.5RS
Member#: 3310
NCNBPDC5, I'll pm you.
vdubvr6, I'm not selling the engine complete b/c I don't know its condition. I will be parting everything off of it.
Old 04-29-2009, 08:12 PM   #13
Letze
Member Sales Rating: (9)
Member#: 143323
1990 Celica Alltrac
Gray
Can I get the PS Line and reservoir?
Letze is offline   Reply With Quote
Old 04-29-2009, 10:57 PM   #14
couse311
Member#: 121657
How much for the crank pulley?
couse311 is offline   Reply With Quote
Old 04-29-2009, 11:29 PM   #15
vdubvr6
Member#: 189644
ok, then how about the short block?
Old 04-29-2009, 11:34 PM   #16
Aspen_2.5RS
Member#: 3310
Pm's replied.
I will have to check the shortblock after I pull the heads.
Old 04-29-2009, 11:52 PM   #17
K.Linchpin
Member Sales Rating: (18)
Member#: 97984
2015 2.5i Foz w/6pd
I need a roll connector for an 02-03 wrx. Please PM me if it's available. Thanks!
K.Linchpin is offline   Reply With Quote
Old 04-30-2009, 12:35 AM   #18
DrKicker
Member Sales Rating: (11)
Member#: 23071
2003 WRX
I'm interested in the rear sway bar, mounts, and end links. PM a price shipped to 75025.
DrKicker is offline   Reply With Quote
Old 04-30-2009, 12:38 AM   #19
Aspen_2.5RS
Member#: 3310
I can sell the mounts and end links, but the bar itself has already been spoken for - see first post.
Old 04-30-2009, 02:51 AM   #20
wannafastsubby
Member Sales Rating: (4)
Member#: 94362
96 Impreza
pm sent...
wannafastsubby is offline   Reply With Quote
Old 04-30-2009, 08:05 AM   #21
DrKicker
Member#: 23071
2003 WRX
Sorry about that, PM me a price for those pieces then.
Old 04-30-2009, 09:51 AM   #22
Aspen_2.5RS
Member#: 3310
Pm'd everyone back. I'm boxing up parts now and I will be shipping some things today.
Cam
Old 04-30-2009, 11:24 AM   #23
DeathPool
Member Sales Rating: (1)
Member#: 186966
2004 WRX Sedan Stg.2
If those are the stock gray, and not faux carbon fiber, interior pieces, I would like a shipping quote on all of those to 60634 (I believe its the cup holder, the radio bezel, front center vent bezel, all the door button panels, and the round air vents.)
Also, if the plastic panel under the engine compartment wasnt damaged, I will take that as well.
DeathPool is offline   Reply With Quote
Old 04-30-2009, 11:26 PM   #24
Aspen_2.5RS
Member#: 3310
All pm's replied again. I have a couple parts to ship out tomorrow. You guys aren't keeping me busy enough....keep the requests coming!
Old 05-01-2009, 12:48 AM   #25
wangless
Member Sales Rating: (16)
Member#: 89648
PM'd you
wangless is offline   Reply With Quote
WTS: 02 WRB WRX. rare parts, tastefull, willing to part out aftermarket stuff wrxkyle RMIC Private Classifieds 18 04-10-2010 08:04 PM
2004 Wrx Wagon Part out. WRB kccobra Complete Car Part-Out 86 01-22-2008 03:18 PM
02 wrx wagon part out eight08impreza Complete Car Part-Out 36 11-10-2006 03:04 AM
02 wrx wagon part out 2.5,V7,6speed,R180,more!! sjl1614 Private 'For Sale' Classifieds 79 06-08-2006 03:25 AM
02 WRX wagon part out I LOVE SIU MAIS Private 'For Sale' Classifieds 13 07-26-2005 12:45 PM
