Old 04-29-2009, 12:22 AM   #1
whatishe
Member#: 65711
2004 WRB WRX Wagon
2.5 Hybrid STI Conversion
Default 5mt to 6mt USDM WRX Wagon Swap Help!
I also posted this in the transmission forum, I don't know which is more correct. I'm doing the 6mt swap into my 04 WRX wagon. I had gotten a rear diff off a turbo legacy (told it was 3.9) and then bought a supposed 4EAT driveshaft off ebay out of a totaled 04 wrx wagon. Axels didn't hook up to the rear diff so I had the guts swapped to the R160. Got this note tonight from my buddy at the shop:
"After setting up the WRX differential in the case with the 3.9 gear pinion, spending two hours getting the correct gear lash and bearing clearance.....then installing it. The driveshaft you provided does not fit, its most likely something wrong with the rear. The problem is the rear flange has holes in a rectangle with the dimensions of:
44mm x 53mm
The driveshaft has square dimensions of:
53mm x 53mm
The dimensions are approximate (+_ 0.3mm), center to center.
Unfortunately, it's not as easy as just changing the flange. With most cars there is a crush collar on the pinion side of the rear end that needs to be changed and setup when changing the flange or any bearing on the pinion side of the rear. This puts the proper amount of preload on the pinion bearing, too much and it vibrates apart, too little and it over heats and locks up.
So;
1) the driveshaft is wrong and we need a new one.
2) the rear is wrong and we need a new one. "
This of course is the last major obstacle in the build and makes me a super
Anyone know the quickest, most effective way (both in cost and quality) to remedy this problem? Answers would be great, part numbers too.
Parts List:
'04 USDM 6mt
'04 stock WRX wagon axles
'9x Turbo Legacy 3.9 Rear
'04 4EAT Driveshaft (what I was told is an auto driveshaft, has a square flange)
'04 Stock 5mt Driveshaft (don't know which flange)
1/2 of a random manual Driveshaft that came with the 6mt (square flange)
Aftermarket DCCD Controller
Thanks a lot everyone!
whatishe is offline   Reply With Quote
Old 04-29-2009, 01:47 AM   #2
gordini69
Member#: 119591
If the flange from your old diff is the same bolt pattern use it. As far as pre-load on pinion bearings just replacing the flange will not affect this, unless you go crazy with the impact gun.
gordini69 is offline   Reply With Quote
Old 04-29-2009, 02:20 AM   #3
whatishe
Member#: 65711
2004 WRB WRX Wagon
I'll make sure to ask.
Old 04-29-2009, 08:43 AM   #4
whatishe
Member#: 65711
2004 WRB WRX Wagon
bump for 2nd opinions?
Old 04-29-2009, 12:05 PM   #5
whatishe
Member#: 65711
2004 WRB WRX Wagon
Bump for justice
Old 04-30-2009, 12:49 AM   #6
whatishe
Member#: 65711
2004 WRB WRX Wagon
issue resolved. thanks to those who replied.
Swap help! 5mt to 6mt whatishe Transmission (AT/MT) & Driveline 10 04-30-2009 12:36 AM
06 STI to 03 wrx wagon swap kite_tmr Subaru Conversions 54 02-05-2007 01:03 AM
6MT into WRX wagon swap questions bluescoobywagon Transmission (AT/MT) & Driveline 4 02-19-2006 08:53 PM
5mt to 6mt help? vvRX7 Transmission (AT/MT) & Driveline 33 11-30-2004 09:41 AM
anyone done a USDM WRX motor swap into a RS? ^jynx^ Tri-State Area Forum 15 01-02-2003 07:27 PM
