Rocky Mountains Impreza Club
Go Back   NASIOC > NASIOC Chapters > Rocky Mountains Impreza Club Forum -- RMIC
Old 04-29-2009, 12:32 AM   #1
Jncominco2
Member#: 170212
02 WRX Sedan
MBP
Default Is my clutch slipping? or something else?
ok well i have been noticing for the past few months that if i am going up an on ramp and i get to 4th before i get into traffic, if i try to get on it a little to speed up, my RPM's will jump
if i get on it with more throttle, it will jump up really fast and climb
if i go slow, it jumps up a little, then comes back down, then back up a little, then back down
i dont see how it can be my clutch slipping seeing as how it was replaced either 15k miles before dan had the car or 15k before i got the car, and it just turned over 100k today
and im not dumb, i know how to drive
so what do you think it is?
it doesnt happen in other gears, maybe fifth but i have never tried it
1 2 and 3 are just fine, nothing wrong with them
oh btw its a stage 1 clutch
Jncominco2 is offline   Reply With Quote
Old 04-29-2009, 12:36 AM   #2
blackout801
Member#: 170059
04 STi Stg 3ish?
BUNANA KING!
sounds like my car and mine is going out just saying
blackout801 is offline   Reply With Quote
Old 04-29-2009, 12:58 AM   #3
EsubaruJ
Member#: 200008
85 AE86
01XJcrawler02WRXsold
Yeah its going out. Thats what happened when mine went out! I had an OEM clutch go out after about 15K. Only launched like 4 times and I let some dumb girl drive it once and she rode the crap out of it.
EsubaruJ is offline   Reply With Quote
Old 04-29-2009, 01:02 AM   #4
Jncominco2
Member#: 170212
02 WRX Sedan
MBP
thats what im thinking happened
my friend is thinking of buying a subie, and was looking at a WRX
so my dumbass let her drive it, and she couldnt drive the stage clutch for crap
she would rev it to like 4500 rpms while slooooooowly letting out the clutch
and her shifts were horrible
that is probably what made it go out more than anything now that i think about it....god damnet
so do i need a new clutch and new flywheel?
Old 04-29-2009, 01:03 AM   #5
Scubiesteve25RS
Member#: 92372
Black on Black
you could prolly just get the flywheel resurfaced if it needs it
Scubiesteve25RS is offline   Reply With Quote
Old 04-29-2009, 01:04 AM   #6
blackout801
Member#: 170059
04 STi Stg 3ish?
BUNANA KING!
upgrade to a stg 2 clutch and fly wheel thats what i would do
Old 04-29-2009, 01:04 AM   #7
EsubaruJ
Member#: 200008
85 AE86
It depends, you can get the flywheel resurfaced. But you will for sure need a clutch.
EDIT: Need to respond sooner before people steal my answers lol
Old 04-29-2009, 01:06 AM   #8
bhhamblin
n00b Moderator
Member#: 99397
'13 BRZ, '13 STi
SRs13 '83 Skyline '93 GTR
resurface the flywheel no matter what. you can also just buy a new disc, you dont have to replace the pressure plate. But it would be a wise decision to just buy a stage2 clutch kit.
bhhamblin is offline   Reply With Quote
Old 04-29-2009, 01:07 AM   #9
Jncominco2
Member#: 170212
02 WRX Sedan
MBP
well wouldnt it be better to just replace it with a stronger/lighter one?
why would i need a stage 2 clutch?! the stage 1 i have now is bad enough, and my car is pretty much stock
Old 04-29-2009, 01:09 AM   #10
Jncominco2
Member#: 170212
02 WRX Sedan
MBP
which company/product would you guys recommend?
Old 04-29-2009, 01:10 AM   #11
pumpkyn
Member#: 156347
1997 Milano EK
2004 Platinum Wrex
whens that coming?
pumpkyn is offline   Reply With Quote
Old 04-29-2009, 01:11 AM   #12
blackout801
Member#: 170059
04 STi Stg 3ish?
BUNANA KING!
if you go stage 2 the clutch will last alot longer and youll have a better clutch if you do do more power mods just saying its be more wise
Old 04-29-2009, 01:12 AM   #13
blackout801
Member#: 170059
04 STi Stg 3ish?
BUNANA KING!
ACT....
Old 04-29-2009, 01:13 AM   #14
blackout801
Member#: 170059
04 STi Stg 3ish?
BUNANA KING!
Originally Posted by pumpkyn View Post
whens that coming?
right now just worring about getting the car up and running then after that itll come
Old 04-29-2009, 01:13 AM   #15
EsubaruJ
Member#: 200008
85 AE86
Was going to say the same thing... I really need to post faster. But ^^+1
Old 04-29-2009, 01:14 AM   #16
Scubiesteve25RS
Member#: 92372
Black on Black
Exedy
Old 04-29-2009, 01:16 AM   #17
Scubiesteve25RS
Member#: 92372
Black on Black
I honestly dont like lightened flywheels, the inertia carried by the heavier flywheel is greater than that of the lighter flywheel. In a practical example, you can notice the difference durring a launch. You will not need to rev as high to launch with a heavier flywheel. The rotating mass of the heavier one is harder to stop than that of the lighter one. when running boost, the heavier flywheel will keep your rpms high and thus keep you spooling more durring gear changes
Old 04-29-2009, 01:16 AM   #18
bhhamblin
n00b Moderator
Member#: 99397
'13 BRZ, '13 STi
To be honest you will be perfectly fine running a stock clutch. Aftermarket stage2 clutches are not going to last as long as a factory one, being that they are being slipped more because they are harder to drive and the engagement is rougher.
If your not planning on big power then stock will be fine and will also be very nice to DD.
I had an ACT streetlite clutch and flywheel in my car. It was kinda loud but was easy to drive after i was used to it.
Old 04-29-2009, 01:17 AM   #19
Jncominco2
Member#: 170212
02 WRX Sedan
MBP
dumb q's...do i want a 4 puck or 6 puck?
and whats the difference in solid/spring?
Old 04-29-2009, 01:18 AM   #20
Jncominco2
Member#: 170212
02 WRX Sedan
MBP
thats what i was thinking, just an OEM one
the MOST i ever plan to do would be a evoIII 16G + supporting mods, but ill be suprised myself if that ever happens
i really doubt ill ever get close to that
so stock clutch/flywheel?
Old 04-29-2009, 01:20 AM   #21
bhhamblin
n00b Moderator
Member#: 99397
'13 BRZ, '13 STi
If you have a stock flywheel in your car right now and there is enough room to have it resurfaced then you can do that. I think an OEM clutch kit is around 500 bones. It would easly hold the power levels you want.
Old 04-29-2009, 01:24 AM   #22
Jncominco2
Member#: 170212
02 WRX Sedan
MBP
k cool
thanks brody
Old 04-29-2009, 01:26 AM   #23
bhhamblin
n00b Moderator
Member#: 99397
'13 BRZ, '13 STi
sent you a pm
Old 04-29-2009, 01:27 AM   #24
Scubiesteve25RS
Member#: 92372
Black on Black
that what i would do, refer to post #17 about lightened flywheels
Old 04-29-2009, 09:14 AM   #25
JokerDMX
Member#: 175664
03 WRX
FP Green/Built&Cam'd 2.5L
Neither, get a street disk. Fastest way to destroy your tranny is use a stock tranny with any puck type disk.
JokerDMX is offline   Reply With Quote
Clutch Slippage Or Something else? Ryans07STI Transmission (AT/MT) & Driveline 4 07-09-2009 04:02 PM
Audio Geeks: Is my Sub blown or something else? fourseasonsandles Off-Topic 12 12-29-2005 03:40 PM
is my clutch slipping gsteclipse33 Transmission (AT/MT) & Driveline 5 04-30-2005 12:43 AM
is my clutch slipping? aznfoos Transmission (AT/MT) & Driveline 1 11-03-2004 11:12 PM
is my clutch slipping or......? NA Impreza Normally Aspirated Powertrain 6 04-30-2001 12:53 AM
Message Board Statistics All times are GMT -4. The time now is 03:40 PM.
