Old 04-29-2009, 12:28 PM   #1
Dokturseuss
Member#: 102009
1999 impreza
Default Will a 99impreza L trans mate up with 02-06 wrx engines?
I searched for this and didnt pull up any info maybe my wording is bad.
I beleive it will mate up no problem with it, i just want to be sure before i go ahead and start the swap train rolling. I dont plan of launching ever or downshifting rough on it all.
the motor will probally be stock for the most part(exhaust,intake, and thats probally it untill i get a better tranny)
Would the L transmission hold the power for daily driving with a good clutch setup reliably?
sorry if this has been answered a thousand time just checking my p's and q's
Dokturseuss is offline   Reply With Quote
Old 04-29-2009, 03:43 PM   #2
207STi
Member#: 197062
1998 Swapped Impreza
black
From what I understand the L's transmission is almost structurally identical to the rs transmission minus the gear ratios, and I've heard of plenty people running RS transmission for a ton of miles. I think Zephyr has over 200,000 on his, just don't drive like a tool and you should be fine. I'm not sure if the L gearing is optimal for the power band of the 205 though.
207STi is online now   Reply With Quote
Old 04-29-2009, 04:44 PM   #3
Dokturseuss
Member#: 102009
1999 impreza
How much would the gearing effect the performance? eventually i would like to get 6 speed setup in but im a upgrade after it breaks sort of guy.
Old 04-30-2009, 01:42 PM   #4
Ranger83
Member#: 210120
I am also in the Huntsville area and looking to do put a 02-06 WRX engine in my 99 Impreza. Is it implied that the new engine your looking at includes a turbo? I was wanting to add a turbo to whatever I end up doing, but saw your question about the transmission holding up to the power so I didn't know. Are you buying the motor brand new? Lots of questions, I know. I am still in the planning stages..
Ranger83 is offline   Reply With Quote
Old 04-30-2009, 02:38 PM   #5
ghostdriver
Member#: 137795
1998 Impreza L
i dont think you have too much to worry about. the gear ratios arent that far off from the year model WRX you are talking about. Your 1-4th gear are just slightly longer than the wrx. The gearing is actually almost identical to an older JDM WRX. get an STI 6MT soon. it is soooo good.
ghostdriver is offline   Reply With Quote
Old 04-30-2009, 02:46 PM   #6
linsavy
Member#: 11620
1997 GF4-STiV3 clone
The L tranny has a smaller input shaft. Stock power should be OK.
linsavy is offline   Reply With Quote
Old 04-30-2009, 07:32 PM   #7
RobK0000
Member#: 62230
It will mate up, i literally pulled out an 03 wrx motor off my L tranny and just put in a 257 block. No fitment problem.
RobK0000 is offline   Reply With Quote
Old 05-01-2009, 02:45 PM   #8
Dokturseuss
Member#: 102009
1999 impreza
Thanks for all the useful information, this has eased my mind quite a bit on the suituation.
I do plan on getting at least a wrx 5sp when i do start modding for more power and if funds can swing it def a 6sp
Old 05-01-2009, 05:03 PM   #9
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
wanted to pass this along. Hopefully it'll help you.
http://forums.nasioc.com/forums/show....php?t=1689781
FuJi K is online now   Reply With Quote
Old 05-01-2009, 09:36 PM   #10
Dokturseuss
Member#: 102009
1999 impreza
yes this will be mostly my dd, maybe with an occasional autoX day, never drag though, so that info is very much appreciated. Gives me some good ideas on the transmission i would like to eventually get for a good dd and occasional track day. A usdm 07+ sti 6spd looks like it would fit my needs spot on.
thanks for the great read.
2000 2.5RS with 02-03 WRX engine swap overheating Xcasinonightzone Subaru Conversions 12 01-21-2009 11:17 PM
Will an 05 STi splitter mate up with on 02-03 STi scoop? tn04xt Interior & Exterior Modification 3 11-02-2008 06:44 PM
Will the APS 70mm CAI mated up with the Perrin Inlet? Irishman Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 04-06-2007 06:52 PM
will stromung cb mate up with my txs dp? Fitz12444 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 06-12-2005 06:17 PM
Will an STi JDM motor mate up to an auto tranny? SubaruWRC Transmission (AT/MT) & Driveline 12 05-29-2003 07:18 AM
