Old 04-29-2009, 01:57 PM   #1
Wakeforce
Member#: 196079
2005 Forester STI
Default Installing gauges using clock power
I'm installing gauges right now and I want to use the power from the clock, except I can't see which is the constant power on the schematic. I could whip out the multimeter but I can't find it anywhere. I could also touch the wires to the ground but that's definitely a bad idea. I could also take a guess and try it but I don't feel like doing it twice if it doesn't work.
Here's a link to the schematic:
http://www.whatanight.net/7-WIRING-clock.pdf
So YG is accessory, B is ground (obviously), but are the other 2 constant or is only one constant and the other one something else?
Also, is there a way to connect the wires to the original connector or do I really need to cut the connector and strip the wires? I'd prefer keeping the connector if I ever have to reconnect the clock for some odd reason.
Wakeforce is offline   Reply With Quote
Old 04-29-2009, 04:51 PM   #2
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
The blue/red wire tied to fuse #2 is the hot lead at all times to the clock. Just tap into the wire and don't cut off the connector.
Help w/ Boost Gauge Install using clock wiring astrange22 Electrical & Lighting 1 09-14-2008 12:38 PM
Installed gauges... dash clock gone Weakness Electrical & Lighting 24 01-24-2007 03:23 AM
FS: Carbon fiber gauge pod - clock replacement, with gauges ST3 Private 'For Sale' Classifieds 7 05-15-2006 10:38 PM
Omori gauges using clock wiring? quazimoto Electrical & Lighting 2 01-06-2005 11:01 PM
A/F meter gauge installation and use question tmat3 General Forum Archive 4 01-26-2001 08:11 PM
