Old 04-29-2009, 05:07 PM   #1
subadrew99
Member#: 204755
Default MAP or MAF
Hey just looking for some insight
i was under the impression that the 98 impreza 2.5rs had a MAF sensor and that in 99 it changed to a MAP sensor; however, my 99 just pulled a MAF sensor circuit low CEL so i'm wondering what's up.
if you guys can help me out that would be great
subadrew99 is offline   Reply With Quote
Old 04-29-2009, 05:09 PM   #2
shanemono4
Member#: 173332
2003 2.5rs
PSM.
if the sensor is by the throttle body it's map, if it's on the end of the intake almost near the filter it's maf. Not the most precise answer haha but there it is.
EDIT: You might get flamed for not searching, btw.
shanemono4 is offline   Reply With Quote
Old 04-29-2009, 10:01 PM   #3
euro_tech
Member#: 206785
1999 legacy outback
come again?
Maf sensor is located in the intake tract near the air box. Map sensors are mounted directly to the intake manifold or have a vac line from the manifold connected to them. (if they are remotely mounted..
euro_tech is offline   Reply With Quote
Old 04-29-2009, 10:39 PM   #4
Odyknuck
Member#: 192866
2006 Impreza
99 was the trasnsition year from DOHC to SOHC motor. I believe the DOHC still used the MAF and the SOHC used the MAP.
Odyknuck is offline   Reply With Quote
Old 04-29-2009, 10:54 PM   #5
euro_tech
Member#: 206785
1999 legacy outback
correct
Old 04-29-2009, 11:12 PM   #6
subadrew99
Member#: 204755
any possible way to have a SOHC with a MAF sensor? It's actually my buddy's car and he swears it is a SOHC. I'm going to check it out tomorrow what is the easiest way to check if it's a SOHC or DOHC?
Old 04-29-2009, 11:38 PM   #7
Storm
Member#: 5218
96L Most Over-
Developed Beater
^^^Yes, that was possible and actually quite common for the 2.5RS. It mighta been different for the Legacy or Forester, but most of the 99 2.5RS' had MAF based SOHC engines. FWIW....the MAF sensor for the 99 model year is notorious for going bad. Fortunately, you can replace the element part and keep the old housing. High flow air filters (and over-oiling them) have been blamed for many of those failed MAFs.....
Jay Storm
Old 04-29-2009, 11:51 PM   #8
subadrew99
Member#: 204755
^^^thanks jay!
MAP or MAF projectrally Newbies & FAQs 5 02-11-2004 01:44 AM
WRX MAP or MAF electricpork Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 02-08-2002 01:12 PM
What do I have? MAP or MAF? Borjaq Normally Aspirated Powertrain 4 01-22-2002 11:27 PM
MAP or MAF jersey judge Normally Aspirated Powertrain 2 10-28-2001 09:14 PM
2001 legacy gt--MAP or MAf? nitrohuffer Normally Aspirated Powertrain 4 08-05-2001 12:22 AM
