Old 04-29-2009, 06:38 PM   #1
Silver WRX 420
Member#: 37498
2002 PSM WRX w/
JDM STI V7 motor swap
Default Rubbing sound from front passenger area
I have a 2002 WRX with about 180k miles on it. It has recently started to make a rubbing/dragging(best way I can describe it) sound coming from the front passenger side of the car. It only make the sound when I am making a left hand turn. It sounds like it is coming from the suspension area but it is tough to tell as I am driving while its happening.
Any suggestions? I tried searching but didn't find a definite answer.
Thanks guys!
Justin
Silver WRX 420 is offline   Reply With Quote
Old 04-30-2009, 01:02 AM   #2
Silver WRX 420
Member#: 37498
2002 PSM WRX w/
bedtime bumpity bump
Old 04-30-2009, 02:04 AM   #3
Gonz
Member#: 18642
2005 Impreza WRX STi
I'd bet you a $1 it's the wheel bearings....
Gonz is offline   Reply With Quote
Old 04-30-2009, 02:23 AM   #4
seanvetter123
Member#: 174476
2002 Impreza RS
BRP
possible breaks hanging up, i have an 02 with 125k and i have gone through 2 sets of calipers cuz they get stuck.
seanvetter123 is offline   Reply With Quote
Old 04-30-2009, 10:17 PM   #5
Silver WRX 420
Member#: 37498
2002 PSM WRX w/
To give a comparable sound, it sounds a rotor being grinded( not sure if thats a word) as if a brake pad was completely worn down. I just had my front pads off a week ago and it was making the sound before and after. I am running the 4 pot calipers in the front.
If it is a wheel bearing, or brakes hanging up, would it only make it when i was turning left, and not right? The faster and sharper I take the turn, the louder it is. If I am under 7-10 mph, it does not do it at all.
How can I check if it is a wheel bearing?
Old 05-01-2009, 10:20 AM   #6
Silver WRX 420
Member#: 37498
2002 PSM WRX w/
Anybody??
Anyone live near Reading, PA? I'll take ya for a ride to hear the sound for yourself.
Old 05-01-2009, 10:37 PM   #7
Silver WRX 420
Member#: 37498
2002 PSM WRX w/
Bump again...somebody help!! please
Old 05-02-2009, 03:06 PM   #8
Gonz
Member#: 18642
Pretty much that's what my wheel bearing symptoms were. I have over 100,000 miles and have been through a few of them.
To check them you are supposed to raise the wheel off the ground, grab the top and bottom and see if you can feel a wiggle when pulling pushing on it. You may need to pull the brake pads out with 4 pots.
Not sure if you need to remove the axle nut. Did you read the "wheel bearing 101 thread? " Tons of information there.
Old 05-02-2009, 10:56 PM   #9
Silver WRX 420
Member#: 37498
2002 PSM WRX w/
Gotcha...so if it is the wheel bearing, if I can find a used hub with a bearing already in it for a decent price to avoid having to go through removing the old hub assembly and taking it to get the old/new bearing pressed in/out, would it be worth it, in your opinion, to do it vs. going through getting a new bearing. I did not check the wheel bearing thread but I am on my way there now.
Thanks!
Justin
Old 05-02-2009, 11:45 PM   #10
Butt Dyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 05 Saabaru
Bearing is one possibility - check your brake dust shields too just to be sure they're not rubbing your rotors.
Old 05-03-2009, 12:16 AM   #11
Silver WRX 420
Member#: 37498
2002 PSM WRX w/
I am changing my F&R brake pads tomorrow, weather permitting, so I wll check that out too.
Thanks for the tip!!
Old 05-04-2009, 12:58 PM   #12
bige1919
Member#: 146333
there's a thread about this too:
http://forums.nasioc.com/forums/show....php?t=1269334
bige1919 is offline   Reply With Quote
loud noise from front passenger wheel area pizdets Transmission (AT/MT) & Driveline 1 07-28-2009 01:32 PM
Weird Rubbing sound from front driver side ogboot Brakes, Steering & Suspension 17 05-09-2008 07:39 PM
Interesting occurance - Squeeling.grinding,rubbing, sound from drivetrain. MidnightScooby Brakes, Steering & Suspension 0 02-18-2002 02:16 PM
Rubbing sound from rear of car Ryan24 North West Impreza Club Forum -- NWIC 7 07-10-2001 11:59 PM
Rubbing sound from rear Ryan24 Brakes, Steering & Suspension 0 07-08-2001 11:46 AM
