Welcome to the North American Subaru Impreza Owners Club Sunday May 26, 2013
Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 04-29-2009, 06:18 PM   #1
Arctic Assassian
Member#: 91875
91 legacy TD04
04 WRB/carbon fibre STI
Default I have an 04 sti... how do I know which utec is for me?
My friend has a utec for sale. He's not sure how to tell if it would work with my car. The only numbers I could find and remember easily are "revision 6b" and txs005 stamped on the circuit board. Can anyone help me out? thanks.
-Adam
Arctic Assassian is offline   Reply With Quote
Old 05-01-2009, 04:09 PM   #2
CKxx
Member#: 33458
Your BOV sounds lame
93 RX7+09 Forester
I don't have an STi, so I am not 100% sure, but I'm pretty sure there is a totally different STi UTEC. By that, I mean that I recall back in the day that the 02-03 UTEC definitely did not work on the STi.
What car is it coming out of?
CKxx is offline   Reply With Quote
Old 05-01-2009, 04:35 PM   #3
Arctic Assassian
Member#: 91875
91 legacy TD04
No idea. It's not installed. I guess I should get into contact with turboxs. They SHOULD know...
Old 05-04-2009, 09:43 AM   #4
04MODWRX
Member#: 210363
2004 Modded WRX
I have an 04, with STI build up, I have the UTEC system piggybacked on the WRX computer(difference is variable valve timing), which my motor does not have. I have a local tuner, who is having a bit of a problem tuning the car b/c the UTEC is not letting him do adjustments above 22-23psi. It will still push more. but he just can not tune it. I probably would not have picked it.
04MODWRX is offline   Reply With Quote
Old 05-04-2009, 12:43 PM   #5
BlackJavaPearl04
Member#: 198522
98 LGT Limited
10 Forester
you need to install a bigger MAP sensor and/or BCS
BlackJavaPearl04 is offline   Reply With Quote
How do i know which wheels will fit my car? ivanbih Tire & Wheel 4 04-14-2010 01:28 PM
How do I know which rotor is bad Hazardous Brakes, Steering & Suspension 9 04-01-2008 11:40 AM
How Do You Know if Knock is Real (and how do you kill it?) williaty Service & Maintenance 4 12-16-2007 11:45 PM
how do i know which injectors to get? flon3y Factory 2.5L Turbo Powertrain 4 08-17-2006 05:38 AM
how do you know which injectors you need? attitude Factory 2.5L Turbo Powertrain 8 06-29-2004 08:57 AM
Message Board Statistics All times are GMT -4. The time now is 04:41 AM.
