Welcome to the North American Subaru Impreza Owners Club Saturday July 2, 2016
Old 04-29-2009, 11:50 PM   #1
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
Question Manual fan switch or lower temp?
Has anyone done a manual fan switch or a lower temp fan switch?
How did you do it or where did you get it?
Old 04-30-2009, 10:32 PM   #2
573
Member#: 144821
1994 LS1 Miata
2015 white WRX
I think that the thermostat does a good job of operating the fans, and if you're having heat problems despite that, something is wrong. However, if you're still inclined to do this, I'd assume a simple switched relay would do the job nicely. You'll just have to splice the wires from that to the wires driving the fan.
573 is offline   Reply With Quote
Old 04-30-2009, 11:49 PM   #3
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
No problems just want more air flow.
Old 05-04-2009, 03:57 PM   #4
namdoogwerdna
Member#: 165205
Mishimoto just came out with a low temp thermostat.. I haven't had a problem with any of their products, including a thermostat we put in my friend's GSX.
namdoogwerdna is offline   Reply With Quote
Old 05-04-2009, 04:12 PM   #5
eastcoastbumps
Member#: 29201
BMW M3
Honda S2000x2
You should be able to wire one in yourself easily. Run a switched ground to the fan relays under the hood. I wouldn't recomend disconnecting the factory controls. You might just forget to turn them on once.
Another thing you can do is disconnect your A/C compressor (very easy) and then turn on the A/C. The fans should come on, but your A/C won't.
eastcoastbumps is offline   Reply With Quote
Old 05-05-2009, 12:44 AM   #6
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
I have critical low temp thermistat.
Yes I know the risk if I forget. Yet I will likely use it more often then not for the summer. The hook the factory back for the rest of the year. I already have a spare plug.
Just need to see about how to.
I wish I could figure out a way to override the oem setup and power the fan
Old 05-06-2009, 12:28 AM   #7
DeathSStar
Member#: 202982
I've done this for years with GM cars I've owned with electric fans.
Run a second switched ground wire from the relay coil, leaving the OE wiring intact. Place a diode in-line so nothing can backfeed into the ECM. This way the ECM still has control over the the fans, but you can activate them whenever you want.
I have always wired them so I can turn on each fan individually, but you could wire it so both come on at the same time.
DeathSStar is offline   Reply With Quote
Old 05-06-2009, 01:01 AM   #8
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
Can you give me more detail info on this. Please!
Old 05-06-2009, 01:54 AM   #9
DeathSStar
Member#: 202982
I was going to look at the Subie's wiring tomorrow, so I will get back to you then...
*edit*
Each fan has a relay (duh) and the whole relay module pops right out of the holder, so getting at the wires is no problem. I don't have time today to start wiring it, but I may tomorrow. I'll take pics when I do.
Old 05-07-2009, 06:49 AM   #10
indytruckboy
Member#: 192599
2004 STI
2007 Outback Wagon
Won't work, fans are activated by pressure not engagement.
indytruckboy is offline   Reply With Quote
Old 05-07-2009, 07:31 AM   #11
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
*edit*
Nice!!! thanx
Old 05-07-2009, 07:35 AM   #12
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
Yea no sorry that wont work. This fan is activated 3 ways.
1) a/c switch. but the correct freon must be in the system.
2) higher temps
3) a/c switch with the car off, but key on.
Old 05-15-2009, 12:32 AM   #13
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
*edit*
Still waiting on more info on your idea.
Old 05-18-2009, 06:31 AM   #14
indytruckboy
Member#: 192599
2004 STI
2007 Outback Wagon
You know...........
..........You can use Opensource tuning and just lower the temp the fan stages come on.
Old 05-18-2009, 12:33 PM   #15
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
By grounding the red/blue wire of the main fan relay it will turn on the fan.
Old 05-18-2009, 10:10 PM   #16
Geek Guy
Member#: 8151
2002 WRX Rally Car
Atlantic Rally Cup Champ!
change the ECU temperature thresholds?
Geek Guy is offline   Reply With Quote
Old 05-19-2009, 01:28 AM   #17
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
interesting idea
Old 05-19-2009, 09:33 PM   #18
indytruckboy
Member#: 192599
2004 STI
2007 Outback Wagon
Yup.
FS: New Mishimoto Aluminum Radiator, Two 12" Slim Fans, Cap, Fan Switch, 02~07WRX/STI wrx_limited Engine/Power/Exhaust 12 04-03-2009 07:44 AM
Who has a Crucial thermostat...or a lower temp thermostat? modaddict North West Impreza Club Forum -- NWIC 16 07-25-2006 06:25 PM
Installing fan switch WRXBob Electrical & Lighting 14 06-29-2005 03:15 AM
Lower Temp Fan Switch? blk04 Service & Maintenance 4 07-21-2004 09:50 AM
radiator fan switch smew Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 05-16-2003 07:23 PM
