Old 04-28-2009, 11:13 PM   #1
scoobystas
Member#: 26568
2003 Yellow Bugeye
Version 8-Vf37
Default cost for longblock install?
How much do you guys think it should cost to install a longblock into an 03 wrx.
basically the tech would have to pull the downpipe, disconnect the old engine from the tranny and drop it out or use an engine hoist and pull it up and out.
install new engine, connect to tranny, connect downpipe and done.
i'm planning on having the tech also install a new clutch disk while the engine comes out. most likely exedy oem from subaru.
btw, this will be a jdm version 8. The ecu swap i can do myself as i've had the oem unit out when i shipped it to cobb to have accessecu software installed.
scoobystas is offline   Reply With Quote
Old 04-28-2009, 11:14 PM   #2
scoobystas
Member#: 26568
2003 Yellow Bugeye
Version 8-Vf37
this is a side job and would not be the 105/hr charge that the dealer charges.
Old 04-29-2009, 12:47 AM   #3
suberdave
Member#: 101865
88 GL-10 STi
for a tech. to do this as a side job you should look at paying around $600. flat rate is ~13hrs.
thats what i would charge you if i were to do it as a side job. and i have done a few of them at this rate.
-=Suberdave=-
suberdave is offline   Reply With Quote
Old 04-29-2009, 12:16 PM   #4
scoobystas
Member#: 26568
2003 Yellow Bugeye
Version 8-Vf37
thanks suberdave, i sent you a pm with a few more questions.
Old 04-30-2009, 01:11 AM   #5
gordini69
Member#: 119591
dropping in a v8 into wrx is a little more than plug and play. if you want to take advantage of the jdm engine you will have to wire in additional cam sensors, avcs solenoids, and charge temp sensor. no?
gordini69 is offline   Reply With Quote
Old 04-30-2009, 01:16 AM   #6
snwboard4life69
Member#: 166788
2003 subaru wrx
stage 3 race car
^^^ agreed but im sure you have the engine wiring harnnes? since you do have the ecu
snwboard4life69 is offline   Reply With Quote
Old 04-30-2009, 01:41 AM   #7
scoobystas
Member#: 26568
2003 Yellow Bugeye
Version 8-Vf37
the engine is said have uncut wiring harness. this will make it easier right? I've also downloaded instructions on how to activate AVCS, that part doesn't seem to complicated.
Old 04-30-2009, 09:36 AM   #8
suberdave
Member#: 101865
88 GL-10 STi
read this how to, for more info...
http://elementtuning.com/technical/ej25_install.htm
-=Suberdave=-
NoVa labor costs for clutch install (>$600 normal?) mr_f00 Mid Atlantic Impreza Club -- MAIC 43 07-17-2008 03:20 PM
cost for installation for coilovers? sonic_wrx Brakes, Steering & Suspension 9 02-09-2006 10:14 PM
cost for shortbock install? BlackoutWRX Newbies & FAQs 9 01-25-2005 11:33 AM
DFW Shop and cost for uppipe install jnmarshall Texas Impreza Club Forum -- TXIC 3 09-03-2003 10:52 AM
What is the total cost for a body kit painted and installed? Jasno999 Interior & Exterior Modification 6 10-15-2001 12:10 PM
