Welcome to the North American Subaru Impreza Owners Club Saturday August 29, 2015
Old 04-30-2009, 09:26 PM   #1
T R3V
Member#: 206397
Default URGENT!!! Can 02 wrx stock struts and springs go on an 05 wrx
Just what the title says... Need to find out asap! Thanks!
T R3V is offline   Reply With Quote
Old 04-30-2009, 09:48 PM   #2
sonic rex 03
Member#: 62313
2003 16G 38mm ewg
sonic yellow
front is no problem,but you will need 04 and higher rear top hat.
sonic rex 03 is offline   Reply With Quote
Old 04-30-2009, 09:51 PM   #3
PARANOID56
Member#: 22035
2003 Brocoma DCab
71 FJ40, 13 DRZ400SM
if you need help so fast, maybe try searching LOL
a quick look at teh FAQ at the top gave me the answer.
and the answer is YES
now search next time
man, i hope i am right LOL
PARANOID56 is online now   Reply With Quote
Old 04-30-2009, 09:54 PM   #4
T R3V
Member#: 206397
lol, what did you type in the search, i tried...
Old 04-30-2009, 09:57 PM   #5
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
UkNuck is offline   Reply With Quote
Old 04-30-2009, 10:07 PM   #6
T R3V
Member#: 206397
got it... thanks... So my understanding is that the 05 will need 05 top hats to work with my 02 struts and springs...?
Old 04-30-2009, 10:09 PM   #7
subarusaurus
Member#: 209533
yeh... so ill need to keep my top hats
subarusaurus is offline   Reply With Quote
Old 04-30-2009, 10:14 PM   #8
subarusaurus
Member#: 209533
so the 2002s will go on the 2005 ok too? someone told me i needed to run a spacer
Old 05-01-2009, 02:45 AM   #9
GDR
Member#: 34924
03 WRX Wagon
81 Scirocco S
NO
02/03 struts and springs need 02/03 tops.
GDR is offline   Reply With Quote
Old 05-01-2009, 08:31 AM   #10
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
Guys if you think about how it fits together instead of just 'someone told me' it may be clearer
02-03 rear springs are straight (same coil dia top and bottom) whereas 04-07 rear springs taper to a smaller dia at the top. The rear upper spring perch is formed by the tophat so the spring year and the rear tophat year need to match.
Once you've determined what style rear tophat you need (based on the springs) you need to make sure the struts mate to that. Due to slight differences in the top portion of the rear strut shaft it has been found that 02-03 struts need a spacer under the tophat to fit tight with 04-07 rear tophats.
02 wrx stock struts and springs $75 Woodhoodwrx Suspension/Brakes/Handling 3 06-02-2010 12:23 PM
Will 06 OEM sti struts, tophats, and springs fit on an 09 wrx? stidriver31 Brakes, Steering & Suspension 1 03-25-2009 03:01 PM
02 wrx stock struts and springs anthonyrb98 Private 'For Sale' Classifieds 6 10-24-2005 06:30 PM
02 wrx stock struts and springs anthonyrb98 Private 'For Sale' Classifieds 18 05-24-2005 08:13 PM
Gauging Interest on 02 WRX Stock Struts and Springs silversilver Private 'For Sale' Classifieds 1 05-10-2005 12:58 PM
