Welcome to the North American Subaru Impreza Owners Club Sunday May 3, 2015
Go Back   NASIOC > NASIOC Subaru Models > Baja Forum
Old 04-30-2009, 10:17 PM   #1
seanr2
Member#: 62697
2003 BAJA
Garnet Red
Question Air Conditioner Not Working
It shot up into the 90's for a few days this week in the Philly area. I naturally turned on my AC and got no cold air! It blows just fine but nothing cold. I'm not sure if it needs a charge but I haven't done anything to the AC since I bought it in 03 and I have 165000 miles. One other thing and I'm not sure if its related, I hear a hissing sound coming from under the drivers side dashboard whenever the defroster or AC is on. Any thoughts?
seanr2 is offline   Reply With Quote
Old 05-02-2009, 12:22 PM   #2
SOFBaja
Member#: 180907
I had the same thing happen... topped off the freon works fine now
SOFBaja is offline   Reply With Quote
Old 05-03-2009, 10:14 PM   #3
moonzie
Member#: 128537
2004 Baja Turbo
Red/Silver
Yup. low on charge. Especially if it's making a hissing or whistling sound from the inside when you turn it on. Charge the system up with freon and it should go away and your air should be cold again.
It seems as though Subaru has some pretty piss-poor A/C designs. Most Subaru owners I've encountered have had their freon leak out at some point or another too.
NOTE: the 134A is fairly environmentally friendly. Not as bad as some of the older freon that they used to put in cars.
moonzie is offline   Reply With Quote
Old 05-04-2009, 01:03 AM   #4
Hawk296
Member#: 14555
1995 Impreza L
Baja
the big question is, where is the refrigerant going? Add some dye into the system when you refill it and use a UV light to find the leak. Then fix the leak before you refill it again.
Hawk296 is offline   Reply With Quote
Old 05-04-2009, 11:25 AM   #5
moonzie
Member#: 128537
2004 Baja Turbo
Red/Silver
I just hope that if you do that you can find your leak. My dad has a hot heavy UV spotlight that we looked through my car ~everywhere~ and could not find a single point that looked like it was leaking. He works on refrigeration systems by profession; he said sometimes if the leak is small enough (usually around gaskets) you won't see any dye. My best bet is to wait until the system runs dry again someday, open up and replace the line gaskets connecting to the compressor, do a system evacuate and re-charge.
It's on my list...
Old 05-05-2009, 12:02 AM   #6
Guzzler
Member#: 79616
Actually, go find an A/C tech that uses a "sniffer".
A sniffer is literally and electronic nose, which can have the sensitivity changed.
On my older vehicles I found an AMAZING mobile A/C repair guy. The guy worked on automotive A/C for years and used every method known to find refrigerant leaks. He said his life improved 1000% when the sniffer was made available. No more dye's, no more lights, no more missing leaks. He was able to find the smallest leaks that other shops couldn't.
Example: I had an old Mazda pickup that would constantly loose it's refrigerant, with no sign what-so-ever. Every year, I would go to a different shop, they would put the dye in and they couldn't find the leak. This went on for 4 years I finally gave this guy a chance (I was reluctant because he was literally half the cost of the "Pro" shops) and he shows up at my house, tops off the refrigerant, and goes to work sniffing the A/C lines.
In less than 10 minutes, he finds TWO leaks. One at the compressor, and one at the inside exchange. Unfortunately, the compressor was to far worn out and had to be replaced. So we upgraded my truck to R134A.
Guzzler is offline   Reply With Quote
Old 05-05-2009, 02:23 PM   #7
moonzie
Member#: 128537
2004 Baja Turbo
Red/Silver
Yup, we tried using one of those too - with mixed results. After going over every possible point in the refrigerant system at least 3 times we came to the conclusion that the most likely place it would be leaking would be at the compressor return line (low side - same line you would put your charge into) We also tried a device that "listens" for any kind of air leak with no luck.
A friend of mine's `02 WRX leaked it's freon out. I believe it's on his low-side maintenance port cuz directly behind it on the firewall there was a thin film of oil with a layer of dust/dirt collected.
I've got a thin layer of oil/dirt directly behind my compressor return line, problem is that's also very close to where you fill the engine oil with, so it's possible that that could be blow-back but I'd say it's refrigeration oil.
Old 05-15-2009, 02:46 PM   #8
xxthecapnxx
Member#: 183665
2003 WRX
I had the exact same problem. fan works but whenever i hit ac i just got a hissing sound and no cold. I took it in to midas for a recharge and they told me that the compresssor is bad. ever since the recharge, when i hit the ac button it now makes an awful screeching sound and noticeably drains horsepower. Also there was kinda a burning smell, could it be that the compressor's clutch seized and the belt's slipping? Does getting the system charged put added stress on the compressor?
xxthecapnxx is offline   Reply With Quote
Old 05-15-2009, 03:09 PM   #9
moonzie
Member#: 128537
2004 Baja Turbo
Red/Silver
Wow. And I'm assuming you've asked Midas about this? Did they say this was normal?
I've had hit and miss experiences with Midas. West side Bloomington Midas - the manager there is an absolute dick. South side Bloomington, they're fantastic. *sigh*
It sounds very much like Midas over-charged your system with too much refrigerant. Too little freon and it won't work. Too much freon and it won't work AND could eventually ruin your compressor AND/OR your belts! That squealing you hear - that's your belt slipping cuz the compressor is being slugged with too much liquid freon! Turn your AC on, pop the hood and see if your compressor pulley is turning or digging in it's heels while the belt just smokes.
Take it back and have them look at it. And watch them. If you find they put too much charge in, I'd make `em replace your belts for free.
Of course, you could have a problem with your belts not being tight enough/worn or your compressor going out. If your system has the proper amount of charge in it and it's not overcharged - then yes your compressor is bad and it may very well cause your belts to slip and smoke.
Air conditioner not working - AT ALL. RallyFord Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 09-01-2004 10:28 AM
air conditioner not working FinalBean Service & Maintenance 5 04-27-2004 07:53 PM
my air conditioner isnt working dashiet Service & Maintenance 2 03-13-2004 11:13 AM
help! my air conditioner isnt working dashiet Service & Maintenance 3 01-10-2004 06:24 PM
Rear lights out... air condition not working?? Impreza2.5RSTi Normally Aspirated Powertrain 2 11-06-2002 10:23 AM
