#1 |
Member#: 198714
International
Vehicle:04' JDM STi EJ207 437whp/357wtrq Dom3 24psi |
Engine Mods (so far)
- Fujitsubo Power Getter 3" Exhaust Titanium - Custom P&L Racing 3" Cat-less Downpipe (The Jamaican P&L) - Zero Sports Radiator Cooling Panel - Custom Grounding Kit - Perrin Crank Pulley - Injen cold air intake - Cusco Oil Catch Can - Cosworth Oil Pan Baffle - Walbro 255 lph High Pressure Fuel Pump - Perrin Turbo Inlet Hose - Samco Sports Radiator Hoses (Black) with Stainless Steel T-Bolt Clamps - Cusco Radiator Cap * 2 - Cusco Motor Mounts - Fluidyne Aluminum Radiator - AMS Lightweight Battery Kit - Gizzmo Thermal Intake Manifold Gasket - Perrin Top Feed Fuel Rail Kit - Black - M Factory Oil Cooler & Filter Relocation Kit - 20lbs Actuator Spring - Perrin Electronic Boost Control Solenoid (3 port) - Perrin FMIC Kit (Stealth Black) - Synapse Synchronic BOV (w/ Anti- Stall Valve) - Fuel Injector Clinic Top Feed Injectors 876cc The red mods were from last year and the blue is what I've done so far this year.........the car is road tuned and the boost tapers from 24psi to 20psi at redline.....on the STOCK MOTOR...... We get 90oct here in Jamaica, so meth will be going on the car pretty soon, i know you guys don't get much JDM cars in here so enjoy..... The dyno is a DynoJet, stock JDM STi's put down 230-240whp on it.......My AFR's are in the 10.7 - 10.9 range... It's an opensource tune by SWIFFY the great ![]() When we logged the car it makes full boost by 3,750rpm, so i don't know why the peak trq is so late on the graph....... Pic of the car: ![]() Link to the build: http://www.wheelsjamaicahost.com/whe...?topic=89097.0 ENJOY GUYS, i sure am ![]()
#2 |
Member#: 170910
Vehicle:2003 Subaru LegacyB4 Silver |
That's a Mad Ride
#3 |
Member#: 101484
International
Vehicle:2002 jdm sti {gt35r} sti blue |
Tuned by ian{swiffy}
Yardie build an produce |
#4 |
Member#: 205318
This ride is definitely off the scales thats one sweet subbie sweeter than even lemonade
#5 |
Member#: 107290
South East
Here's your daddy
#6 |
Member#: 134516
Vehicle:o2 WRX BlankitaRIP o6 STi Blanca |
beautiful ride my yout....good luck with the future progress
#7 |
Member#: 184267
#8 |
Member#: 143860
SCIC
Awesome! A Synapse Syncronic (THE CHRONIC) made it all the way to Jamaica!
YAY FOR PETER! Great lookin STI! Love the Prodrives. |
#9 |
Member#: 135927
Vehicle:2002 Impreza WRX RA PSM |
Oh there is no running away from me Mr. Jody DuCash lol.
#10 |
Member#: 8512
South East
Vehicle:2002 WRX chassis... stage-infinity.com |
Something's not ideal. It could be a number of things, but you should be able to make 24psi earlier than 3700RPM with that setup. What elevation are you at?
#11 |
Member#: 68647
Vehicle:07 STI Rotated 35R Jorge Tuned |
Nice ride. I can't help but read posts from Jamaica with a Jamaican accent.
#12 |
Member#: 116330
South East
Vehicle:2006 300C 5.7 Hemi Grandpa Gold. |
#13 |
Member#: 152345
Vehicle:2000 R34 GTS-T sedan silver |
damn i am at work if i could i would post a pic of my 01 jdm sti
#14 |
Member#: 113183
Vehicle:2001 996TT |
Those are some great results man! Keep up the good work!
#15 |
Member#: 198714
International
#16 |
Member#: 198714
International
#17 | |
Member#: 198714
International
#18 | |
Member#: 198714
International
![]() Thanks.....just figured out the multi- quote ![]() |
#19 |
Member#: 132365
Vehicle:'02 WRX EPL B5 S4 & B6 USP |
The FMIC isnt helping your late torque issue. I mean I guess you might need it down there, but for the most part an STi TMIC or an aftermarket will cool that turbo no problem and move your torque curve left. Im not an expert or tuner, just my $0.02
#20 | |
Member#: 198714
International
Swiffy (my tuner) & I re-tuned the car for the 20lbs spring we put in the factory actuator (threw away the factory 8 lbs) & the Perrin EBSC....after the road tune i went to the dyno, my results @ that time were 303whp & 305wtrq, this was done with the Stock STi TMIC @ the same psi....... I usually wet the TMIC before a pass on the dyno and during the pass I watched the water turn to steam. It never happened before.... I had the Perrin FMIC sitting, just wanted to max the STi TMIC and don't forget this is the tropics........ , also i need it to support future mods...... |
#21 |
Member#: 194804
International
Vehicle:2004 VF43 WRX - sold WRB |
word big up jamrock , nice STI
#22 |
Member#: 53451
Vehicle:2000 JDM Impreza SRX w/ AVCS Silver |
Whats you drag time?
#23 |
Member#: 26568
NESIC
Vehicle:2003 Yellow Bugeye Version 8-Vf37 |
i'm guessing thats a version 8 motor? add a few gallons of toluene from a paint store to raise your octane up to 94-95. but that gets expensive and is a hassle to for every tank.
#24 |
Member#: 162882
NWIC
Vehicle:04 wrx WRb |
i know this is dumb to say but damn i didn't know people had subys in Jamaica....frikn tight...
#25 | |
Member#: 78516
Vehicle:2003 WRX Rally Blue |
http://www.socojforum.org/forum/inde...pic,339.0.html http://www.wheelsjamaicahost.com/whe...topic=107193.0 |
| Thread Tools | |
| Display Modes | |
| vf-37 twin scroll set-up, and front sti brembo's | swiftone | SCIC Private Classifieds | 6 | 08-15-2007 01:28 PM |
| getting a jdm ver. 7 sti motor to pass emissions in ct | legacy2003 | New England Impreza Club Forum -- NESIC | 4 | 11-28-2005 04:03 PM |
| I need vf36 or vf 37 twin scroll set up | subabusa | Normally Aspirated with bolt-on Forced Induction Powertrain | 0 | 06-21-2005 05:26 AM |
| ihi vf 37 twin scroll info... | deathinacan | Normally Aspirated with bolt-on Forced Induction Powertrain | 0 | 12-15-2004 12:19 AM |
| JDM vs EDM STi projectors: why the difference in price? | lawn boy | Interior & Exterior Modification | 14 | 02-10-2004 05:54 PM |
