Welcome to the North American Subaru Impreza Owners Club Sunday May 24, 2015
Old 04-30-2009, 11:50 PM   #1
ShlowShtuph
Member#: 188240
95.5 Impreza
MAaarooooon
Default wiring question
I've just about finished the build portion of my swap. I'm using an ej22e block (phase 1) and ej25 sohc heads and intake manifold. I still haven't decided what would be the best way to go with the differences in wiring under the hood. I figured the only complication the manifolds would present would be the injector harnesses. Today I found that the tps, the ignition coil, injectors.. all are different enough that I can't just swap them out with phase 1 parts and I don't really want to hack into my stock wiring for every sensor on the manifold.
So my questions....
How difficult/time consuming is it to swap all the engine wiring and ecu?
If I used an 01 RS ECU does that still use the same dash wiring as my 96?
Any other suggestions?
ShlowShtuph is offline   Reply With Quote
STi swap wiring question BMXspears Subaru Conversions 7 06-04-2010 02:32 PM
6 spd swappers - Semi-famous Tranny 6 wire to 4 wire question gotboost02 Transmission (AT/MT) & Driveline 15 09-05-2008 08:27 PM
Wiring gauges, connecting wires, question shamrock 05 Electrical & Lighting 5 06-06-2008 04:19 PM
quick wiring headlight wiring question Lordhowe Electrical & Lighting 0 11-23-2005 07:00 PM
wiring question- keep the amp power, speaker wires away from input wire? garie Car Audio, Video & Security 5 06-20-2003 06:25 PM
