Old 05-01-2009, 08:35 AM   #1
CouponAlbum
Member#: 210105
Default Is there an easy way to remove pinstriping without taking the car paint off??
Hello,
I want to redo the pinstriping on my car as the original ones are "rubbing off" or fading, looks terrible. Is there a way to remove them without taking the cars paint with it? The car paint is black and the striping is either white or gray.
Please suggest a way.
Thanks.
CouponAlbum is offline   Reply With Quote
Old 05-01-2009, 08:47 AM   #2
scprs
Member#: 172359
2005 STi
buffer pad and a dremel take it right off just dont keep it at full speed and dont push down hard.
scprs is offline   Reply With Quote
Old 05-01-2009, 09:58 AM   #3
djosbun
Member#: 202176
2004 WRX wgn P1RANHA
'07 Tribeca
Is the pinstripe painted on or of the decal-type? I have pulled off decal-types in the past without removing any paint. Just have to take your time and go sloooooooooow.
djosbun is offline   Reply With Quote
Old 05-01-2009, 10:10 AM   #4
Jack
Add Lightness
Member#: 13699
2004 Outback, 13 XV
(From General)
Depends how old the stripe is. When I used to pinstripe/letter for a living, I advised using draino. Use at your own risk.
jack
Old 05-01-2009, 10:19 AM   #5
Dougbugeye
Member#: 169781
2003 Impreza 2.5RS
Midnight black pearl
Originally Posted by CouponAlbum View Post
Hello,
Thanks.
I once had a black toyota mini truck that came from the factory with adhesive stripes on the sides. I used lots of bug & tar remover, and rolled the graphics off slowly and carefully. Kinda like getting the stickie off after debadging my Subie.
Dougbugeye is offline   Reply With Quote
Old 05-01-2009, 10:49 AM   #6
BeatLA
Member#: 182396
2005 WRX Wagon
2004 FXT for Mrs. BeatLA
Removed mine last year. Used bug and tar remover. Sprayed it on, let it set a few minutes, then peeled it back slowly. It takes a lot of time. Followed it up with some wax and it's gone.
BeatLA is offline   Reply With Quote
Old 05-01-2009, 11:02 AM   #7
dangerousatom
Member#: 70710
2002 04STi Swaped RS
w/PPGS & 02 Wagon w/PPGs
Heat gun at a distance of 6-8" should let you peel it off or scrape it off with a plastic blade scraper. Bug-Tar remover claybar ect... should take off any remaining residue. Like BeatLA stated its time consuming. If the pin striping has been on the car for years it may leave a permanent mark-depression-line in the paint that can only be fixed with repainting
dangerousatom is offline   Reply With Quote
Old 05-01-2009, 12:00 PM   #8
Super_HKS
Member#: 154434
2009 WRX Hatch <@_@>
just get the corner of the pinstrip and start getting it off. Just go slow and it will come off easy.
Super_HKS is offline   Reply With Quote
Old 05-01-2009, 12:02 PM   #9
AlxSti
Member#: 94615
|'06 STi 341/356|
Delaware REALTORŪ
just peel it off.. use a blow dryer to heat the adhesive if needed.. then wash/polish/wax.
AlxSti is offline   Reply With Quote
Old 05-01-2009, 03:20 PM   #10
Chi_San
Member#: 53558
2005 Baja Sport
Gray/Silver two tone
Wait for a day when it's 112 degrees and use a pressure washer. That's what I did when I worked at the Saturn dealership... It was 112, and as I washed the cars on the lot, I blew the ****ing pinstriping off a car.
Chi_San is offline   Reply With Quote
Old 05-01-2009, 03:40 PM   #11
girodisc
Member#: 177674
Go to a car paint place and get a vinyl eraser wheel. Its basically an eraser wheel you put in a drill and just rub it off. Then its just a little lacquer thinner and your done. That's what we used at the body shops I have worked at and I us it at home for pinstripe as well as decals.
Johann @ Girodisc
girodisc is offline   Reply With Quote
Old 05-01-2009, 03:45 PM   #12
p2adan
Member#: 176574
2008 2.5i
Johann @ Girodisc
+5 for the eraser! Smells funny and takes off stuff off quick!
p2adan is offline   Reply With Quote
Old 05-01-2009, 05:40 PM   #13
BLACKBUG03
Member#: 193604
this. exactly how i did mine
BLACKBUG03 is offline   Reply With Quote
Old 05-01-2009, 09:01 PM   #14
rkramer
Member#: 118209
2015 WRX Limitec
Johann @ Girodisc
this is how you are SUPPOSED to do it. I've removed numerous pinstripes with my wheel, as well as countless decals and stickers. Haven't damaged any paint yet, just watch it on white fiberglass, it WILL burn fiberglass if you aren't careful. (not a worry with a vehicle though)
Old 05-01-2009, 09:29 PM   #15
CynicX
Member#: 48199
06 WRX
I also had a black mini truck that came with adhesive pinstripes. Hairdryer/heat gun on low + patience....
CynicX is offline   Reply With Quote
Old 05-01-2009, 11:04 PM   #16
austinramage
Member#: 178367
2002 WRX-WRB-309AWHP
2007 Ninja 250-Flatblack
Eraser wheel, get it at autozone/baxtors/pepboys
austinramage is offline   Reply With Quote
Is there an easy way to modify a large XML file? -itunes libary SjYankee006 Off-Topic 11 02-12-2010 02:35 PM
Is there an easy way to backup an oracle database? OriginalSin Off-Topic 3 12-21-2009 10:47 AM
Is there an easy way to replace spark plugs?? Skin Irritant Newbies & FAQs 20 07-07-2009 10:54 AM
Is there an easy way to identify a WRX rear lsd? (markings, ect.) soulbazz Transmission (AT/MT) & Driveline 5 08-22-2008 07:37 AM
Is there an easy way to... MAD REX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 05-17-2003 05:45 PM
