Welcome to the North American Subaru Impreza Owners Club Tuesday January 27, 2015
Old 04-19-2002, 01:52 PM   #1
JohnW
Member#: 14583
2002 WRX Wagon
Default Tein Wagon Coilover and Rota Subzero on Wagon
Took these last night after installing Rota Subzero with S03s (225/45/17) on WRX Wagon with Tein Wagon Coilovers. As you can see, the car is a little too low and rubbing will occur during hard cornering due to tires extruding from fender. (rubbing confirmed this morning on both front and rear)
The stock RE92s did NOT rub even when the car was lowered another 1/4 inch on back. When I put the Rota Subzeros on, I immediately noticed that the gap in the rear was only about 1 inch so I raised it to 1 1/4 for this pictures.
But, 1 1/4 isn't enough. Currently, the car is running about 1 1/2 inch gap in front (2 and 1/2 fingers).
Tonight, I'll raise both by 1/2 inch on front and rear.
BTW, any know why the rear driver side sits lower than the rear passenger side? gas tank?
JohnW is offline   Reply With Quote
Old 04-19-2002, 02:25 PM   #2
kenchan
Member#: 15106
you might wanna take it to the body shop and see what they say about rolling the fenders.
it's corner weight. almost all cars have different weights on the corners so that's why it is always good to get coilovers instead of just springs.
i use the HA's btw with 52mm offset wheels.
kenchan is offline   Reply With Quote
Old 04-19-2002, 02:56 PM   #3
JohnW
Member#: 14583
2002 WRX Wagon
Default corner weight
so, you are saying that I should increase the height (via coilover height adjustment) on that low corner until the gap is the same on both driver and passenger side?
Old 04-19-2002, 05:16 PM   #4
AllWheelDrift
Member#: 9191
2002 Impreza 2.5TS
Blue Ridge Pearl
Depends on why you bought coilovers.
For optimal performance you should check your corner weights. Get some scales and adjust your coilovers such that the sums of weights across the diagonals are equal. I.e. (rf + lr) = (lf + rr)
Otherwise, you might as well adjust things so the gaps are equal and things look 'nice'.
AllWheelDrift is offline   Reply With Quote
Old 04-19-2002, 05:48 PM   #5
amolaver
Member#: 13301
2002 WRX Wagon
Bashed in rear-end Silver
Unhappy Fugh
I'm planning on the SubZero's w/DMS Golds, so this is not what I wanted to see - I assume the fitment will be similar between the Tein Wagon's and the DMS'.
Can anyone give a rough cost for rolling the fenders? I mean, for good work, would normally be a $400 job? $1000?
ahm
edit: Actually, do you have any more pics of the car w/the Silver SubZero's on it? I'm waiting for a response from Revolutions on availability of 17", but it would be nice to see what its going to look like. Thanks!
amolaver is offline   Reply With Quote
Old 04-19-2002, 06:19 PM   #6
JohnW
Member#: 14583
2002 WRX Wagon
Default pics
OK. I ran outside my office just now and tooks some pics. I didn't bother to move the car to a more scenic background.
Old 04-19-2002, 06:20 PM   #7
JohnW
Member#: 14583
2002 WRX Wagon
Default one more from side
side view:
Old 04-19-2002, 06:34 PM   #8
kelley
Visiting NASIOC Timeout
Member#: 5681
94 legacy turbo
04 sti
would they rub sittin about 3/4'' down.
kelley is offline   Reply With Quote
Old 04-19-2002, 07:42 PM   #9
deepbeep
Member#: 1392
Hey John,
How's the ride quality with the Teins?
I recently installed a set of DMS Golds, but think it may be a bit overkill for my needs. I like the ride height adjustability, but I think I will rarely, if ever, adjust the rebound settings. Maybe I'm a set-and-forget guy after all... That's what I did with the AGX/Eibach combo on my RS too...
deepbeep is offline   Reply With Quote
Old 04-19-2002, 08:16 PM   #10
Silver_SportTrac
Member#: 15052
Do u have to ask?
Oh *****!
How did you get my truck in the background there!? Very nice pictures........sorry to hear about the problems with your coilover's.
anyways.......WAY TO GIVE ME SOME EXPOSURE THERE!
Silver_SportTrac is offline   Reply With Quote
Old 04-19-2002, 10:52 PM   #11
amolaver
Member#: 13301
2002 WRX Wagon
Unhappy At least they look good...
That bites man... They do look great though. What are your alignment settings? I think a number of people have resolved rubbing with some negative camber out back - how much room do you need (can you see the scuffs on the tire? How much tread needs to move inside the fender)? From what others have said, I believe -1.5 degrees is close to optimal, although someone please correct me if I'm way off-base there.
ahm
edit: And dips on deepbeep's DMS Gold's
Old 04-19-2002, 11:06 PM   #12
deepbeep
Member#: 1392
man, you -are- trigger-happy!! LOL
Old 04-19-2002, 11:08 PM   #13
amolaver
Member#: 13301
2002 WRX Wagon
Talking
Wax on. Wax off.
The spider must move quickly to catch the fly - or some other flocking thing...
ahm
Old 04-19-2002, 11:13 PM   #14
deepbeep
Member#: 1392
Now would that make you Mr. Miyagi, or Ralph Macchio? Hmmmm....
Old 04-19-2002, 11:15 PM   #15
amolaver
Member#: 13301
2002 WRX Wagon
Neither...
I am Godzilla.
You are Japan!
ahm
Old 04-19-2002, 11:46 PM   #16
deepbeep
Member#: 1392
Ok John, you can have your thread back now
Old 04-20-2002, 02:50 AM   #17
JohnW
Member#: 14583
2002 WRX Wagon
Default thanks.
I tried to take titsataki, rex_ruther, bobski, and bobski's friend out for a ride tonight. We drove about 100 feet before we turned around and parked.
The car was sitting so low in the rear, the inside fender lip was sitting on the tires!
After taking a look at the rubbing, I decided that I'm going to go get the fender's rolled. I'm pretty sure that if I don't, I'd have to raise the car back to stock height or higher. This doesn't seem very appealing to me since part of the reason for coilovers was so that I can lower the car.
So, it looks like I'm putting the stock RE92s back on for the time being...
John
Old 04-20-2002, 02:01 PM   #18
deepbeep
Member#: 1392
That doesn't sound good!! I thought the Teins had spring rates quite a bit higher than stock? Do you think the root of the problem lies more in the width of the tires, or in the actual suspension?
Old 04-20-2002, 02:54 PM   #19
Rocky WRX
Member#: 9837
2002 White WRX Wagon
7800 ft
The stock wagon rear springs are 140 lbs/in, the Tein Wagon rear springs are 168 lbs/in (3kg/mm). This is 20% stiffer than stock.
Maybe stiffer rear springs would help. If Tein offers 4kg/mm (224 lbs/in) springs, they would be 60% stiffer than stock.
Rocky WRX is offline   Reply With Quote
Old 04-20-2002, 04:52 PM   #20
RimRockaz
Member#: 2947
2000 GC6 ej20 swap
fast n furious pt III
the problem is tire size.
IIRC, sedan will be ok with 225/45/17 because of its wider track than the wagon. but you have a wagon, so 225/45/17 will cause major rubbing unless you adjust the ride height.
with that said, i think the proper tire size is 215/45/17 for the wagon.
RimRockaz is offline   Reply With Quote
Old 04-20-2002, 05:53 PM   #21
gtguy
Member#: 2184
2005 Legacy GT wagon
Platinum Silver Metallic
Raise the car, and you won't rub. If you measured stock ride height before putting on the Teins (please tell me that you did...at all four corners from wheel center to fender lip), subtract an inch from those measurements, and you should be about right.
The Tein spring rates are 280/170 or some such, which should be sufficient to keep you from rubbing. Your car looks pretty low in the piccies. I also wonder about damping if the car is diving/leaning that much.
Kevin
gtguy is offline   Reply With Quote
Old 04-20-2002, 07:21 PM   #22
spshultz
Member#: 1415
2005 OBS 3.0R
'12 SantaFe
JohnW,
Big thumbs up on the look! Are those the "silver" subzero's?
spshultz is offline   Reply With Quote
Old 04-20-2002, 08:10 PM   #23
mav1c
Hoodbridge!
Member#: 560
2006 STi, '11 A4
Crystal Gray, Silver
I have the same set-up, but with Falken Azenis tires. I rub in the rear also, but from what I can see, it's just barely, so I think the removal of the rubber strip should solve the problem. If not, I'll get them rolled.
Old 04-21-2002, 01:42 AM   #24
amolaver
Member#: 13301
2002 WRX Wagon
Question No one answered the first time, so...
Can someone give an estimate for rolling the fenders. I'm hoping (per mav1c's setup w/Azeni's) I might not need it, but... In the event that I do, how large a dent in my wallet should I plan for?
ahm
Old 04-21-2002, 01:55 AM   #25
Cosworth
Member#: 3887
08 Taco, 98 M3/4/5
'00 RC51, '08 KTM
Instead of rolling the fenders, an alternative might be to get some rear camber bolts from whiteline or Ingalls (www.ingallseng.com) and give it a bit more negative static camber. With a bit more negative static camber and the dynamic camber of the rear suspension, it might be enough to clear the fenders of the wagon. It a very inexpensive experiament. bolts are usually 20-40$ and the cost of an alignment. not too bad for some piece of mind for your new investment! Hope this helps some.
Cosworth is offline   Reply With Quote
Tein wagon coilover and sti top mounts- No good? paulw Brakes, Steering & Suspension 10 02-06-2004 09:48 AM
Tein wagon coilovers and aftermarket upper mounts wrxinsc Brakes, Steering & Suspension 1 04-01-2003 10:13 PM
18in. Rota Subzeros on a wagon??? Rexkid Brakes, Steering & Suspension 0 12-14-2002 05:37 PM
FS: TEIN WRX wagon Coilovers and some other goodies Silky Bay Area Impreza Club Forum -- BAIC 10 06-29-2002 04:05 PM
Silver WRX Wagon with Tein Wagon coilover and Rota Subzero JohnW Member's Car Gallery 5 04-30-2002 05:03 PM
